MSA (% Tolerance: 10 %)
Black arrow
One question i got from my colleague which also made me unsure what to answer:
If MSA turns out to be acceptable for example (only for inspection), no actions needs to be taken.
% Tolerance= 10 % => Total Gage R&r: 2 microns
Tolerance: Up to 20 microns
___________________________________________________________
The MSA is ok, the measuring equipment can be used to detect parts, whether they are within tolerance or not. So far so good.
The colleague asked me this:
"In practice, the operator measure the part and gets 19.2 microns. We know that the measuring system spreads 2 microns, should we decrease sorting limits from 20 microns to 18 microns? To be sure that the part is not out of sec. limits?"
You don't know for sure what the uncertainty is if you're using only the R&R output. There are problems with the standard AIAG GR&R that make those kinds of conclusions unreliable. For more information I recommend
An Honest Gauge R&R Study [PDF] from Donald Wheeler to help you understand the limitations and potential pitfalls.
If you assume that you are indeed losing 10% of your tolerance to measurement error, you need to do some guardbanding to account for it. Amost any time a process approaches a specification limit there is risk. There is an economic decision to be made--how many "good" parts can you afford to lose by reducing the tolerance in production? Can the process be moved away from the limit, thereby reducing the risk? There are details and factors other than GR&R results that need to be known and taken into account for these kinds of decisions.
Z
zancky
from my undertanding,
MSA make sense if You are using the device for the X-r/X-s chart i.e when you are measuring cp cpk. In such a case you can not be so close to the limit.
If you are deciding on a signle part about compliance ok the limit should be reduced in my opinion in order to avoid type II error
Black arrow
As i understand the % Tolerance it should be used when your measurement equipment is used for inspection and i saw in a thread in this forum and it says that "... to determine whether it is in specification or not".
Wether part is in specification or not? Please explain more what does that mean in practice? So an acceptable % Tolerance for example 10 % , means that the measuring eq. is ok for determine if the parts is within spec. or not? I would like to have an example which explains this a little bit better or picture which shows this. The measurement error vs tolerance range.:confused:
Thanks in advance!
Please explain more what does that mean in practice? So an acceptable % Tolerance for example 10 % , means that the measuring eq. is ok for determine if the parts is within spec. or not? I would like to have an example which explains this a little bit better.
Thanks in advance!
GR&R results categories are not absolute rules. They're guidelines, and some would say that they're not very good guidelines. Rather than just looking at the output numbers (percent of tolerance, percent of variation, e.g.) you need to look at the contributors as well. It's not a good idea to make a decision based on GR&R results alone. MSA is tool use in helping you to make decisions.
Black Arrow: I strongly recommend that you read soem of Donald Wheeler's articles on MSA. it is a complicated topic and I know that if you invest soem time to understand the fundamentals from an expert (and of course you should read Miner's blogs here at the cove) you will accelerate your understanding. it will be faster - and less confusing - for you than a series of 'disjointed' questions.
I am not trying to discourage you from askign questions here - I am merely trying to provide you wiht additional high value references.
In addition to the article that Jim referenced I would direct you to the following:
How to Establish Manufacturing Specifications
Good Data, Bad Data and Process Behavior Charts
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
B One sided tolerance Cylindricity - Result from MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
B How do you specify a one sided tolerance for an MSA in Minitab v 16 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
A MSA (Measurement System Analysis) for Characteristics with One Tolerance Limit Capability, Accuracy and Stability - Processes, Machines, etc. 10
T MSA - Should I compare my GRR to tolerance or to my sample? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
M MSA - According to the formula cg how much tolerance should be put in place? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Z MSA (Measurement System Analysis) for a .0003" tolerance feature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Miner Intro to MSA of Continuous Data - Part 9: %Tolerance for One-sided Specs Imported Legacy Blogs 3
V MSA - Which edition constants are these? What is definition of Tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Sample Selection for MSA Study - Entire range of the Tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
F How to use Total Variation based on Process or Tolerance? Page 60 of the MSA manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Tolerance vs Total Variation in Gage R&R report - MSA 3rd edition pg. 116 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
Stuart Andrews MSA results on % Tolerance charts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S MSA Manual - Page 60 states that "If the analysis is based on tolerance... Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
Bev D MSA Misc. Quality Assurance and Business Systems Related Topics 46
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
