MSA vs. Measurement Capability Analysis - What are the differences?
E
errolreyes - 2005
Hello people,
Just want to know about the difference between MSA and Measurement Capability Analysis? Hope to hear your reply.
Thanks!
Errol
Atul Khandekar
Welcome to the Cove, Errol! :bigwave:
Yes, they are basically the same. The whole exercise of MSA helps you quantify the two types of variation (position variation - bias, linearity and width variation-GRR) for measuring a particular characteristic.
Various indexes can be computed.
A. Based on a Bias/Repeatability Study
(Ref: My old notes based on the booklet "Capability of Measuring Instruments": Robert Bosch)
Take repeated measurements (25-50) on a production master, calculate average and Repeatability StDev.
The two indexes calculated are:
1. Cgm = (0.2 * Tolerance) / (6 * Rpt_Stdev)
2. Cgmk = Least of
( RefValue + (0.1 * Tolerance) - XBar) / (3 * Rpt_StDev)
-OR-
( XBar - (RefValue - (0.1 * Tolerance)) ) / (3 * Rpt_StDev)
Both should be >= 1.33; and bias (XBar-RefValue) not significant.
B. Based on GRR, typically two indexes are recommended:
1. Measurement Capability Index (MCI_I) based on Process Variation is defined as:
MCI_I = 100 (Sigma_GRR/Sigma_process)
Sigma_Process is calculated from ongoing SPC studies: RBar/d2
2. The other index, (MCI_II) is based on tolerance:
MCI_II = 100 (5.15 * Sigma_GRR/ Tolerance )
In place of 5.15 you can also use 6 to cover 99.73% spread.
Acceptance criteria for both these are:
<=20% :Good
>20 - <=30% :Marginal
>30% :Unacceptable
E
errolreyes - 2005
MSA vs Measurement Capability Analysis-what the differences ?
Thank you so much for your replies.It's help me a lot :thanx:
darkgelap
Actual GR&R Constant ?
Found that the Constant for GR&R shown on the example in page 114 of MSA 3rd edition is not same as the sample shown in SPC manual.
i.e Trial (3) k1 = 0.5908 in MSA manual but in SPC manual
Trial (3) K1 = 3.05 .
Is there a reason for this. Am i missing something big ?
Need help !!! Spiderman, Superman , Super-Consultant..
Thanks and Regards.
Howard Atkins
Forum Administrator
The constants changed between the 2nd and 3rd edition of MSA.
I am afraid that I cannot explain the statistics but the effect is supposed to be minor.
darkgelap
Thanks for the reply howard.
The new constant stated in the MSA 3rd edition. Which page is this. Sorry to ask but im really confused and cant find it.
Thanks and regards.
darkgelap
Wow. and i thought that's an example only. And there'll be the actual constant in the manual somewhere in a nice table format.
Confused and dumb-founded ...
Thanks and regards.
Statistical Steven
Statistician
What ever happened to the old "10:1" rule for measurement systems? Seems like MSA and other analyses are just rehashing the idea that the measurement system should not take up more than 10% of your total process variation. Where did I lose it? :D
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M MSA Chicken and Egg - Process Capability and Measurement System Capability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Automated Measurement Machine MSA - Small Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA (Measurement System Analysis) - Process Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S MSA (measurement system analysis) on Flammability tester? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Non-replicable tests in MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
W Does TS16949 require MSA on all measurement systems in the Control Plan? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Interpreting Type 1 MSA (Measurement Systems Analysis) Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Selecting Parts for an MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
T MSA on Camera Vision System and other Process Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G MSA (Measurement System Analysis) and Dimensional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M MSA (Measurement System Analysis) on a Photospectrometer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T MSA (Measurement System Analysis) Competency Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
P MSA for Counting Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A MSA (Measurement Systems Analysis) for Humidity Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Is MSA useful to prove a Measurement System after Relocation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Very interesting article concerning MSA (Measurement System Analysis) Book, Video, Blog and Web Site Reviews and Recommendations 8
B Wait or not wait? MSA (Measurement System Analysis) Actions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B MSA (Measurement System Analysis) - Results and Actions Taken Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
E Company-wide MSA - Measurement Equipment Bias, Linearity & Stability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A MSA (Measurement System Analysis) for Characteristics with One Tolerance Limit Capability, Accuracy and Stability - Processes, Machines, etc. 10
O Conducting MSA on Multiple Measurement Mystems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
SATHYABALARAMAN MSA (Measurement Systems Analysis) Study plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
I Interpretation of MSA (Measurement Systems Analysis) Linearity and Bias Study Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C MSA (Measurement Systems Analysis) Variables Template Document Control Systems, Procedures, Forms and Templates 0
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
A Measurement Systems Analysis (MSA) - Who Developed it? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D MSA (Measurement System Analysis) on a Bore Measurement - Good or bad result? Six Sigma 9
R MSA (Measurement Systems Analysis) on a CMM for Special Characteristics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D MSA (Measurement Systems Analysis) on Visual Color Check IATF 16949 - Automotive Quality Systems Standard 13
M Is MSA (Measurement System Analysis) Required for Degradation Testing? IATF 16949 - Automotive Quality Systems Standard 1
M MSA (Measurement System Analysis) - Do we have control of all states in the chart? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA for criteria Automatic Video Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Calibration of Load Cells - ISO 17025 & MSA (Measurement Systems Analysis) ISO 17025 related Discussions 5
G Traceability Studies and Requirements for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
optomist1 Is a MSA (Measurement System Analysis) needed on these two tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
B Nonconformance about MSA (Measurement Systems Analysis) in ISO/TS16949:2009 IATF 16949 - Automotive Quality Systems Standard 9
