MSA When an Instrument Measures More than One Parameter
ADSJT
Quality Engineer
I am preparing for MSA studies on an instrument that measures density and specific gravity. The question was asked whether we need to do two studies, one for density and one for specific gravity. The instrument prints both results for each test. Some feel that it is not necessary to run separate tests when specific gravity can be calculated once density is known. I would like to purchase separate standards and run separate tests, at least for the initial set of studies. I need to justify allocating the resources to do that. I am also flexible enough that I will adjust my thinking if there is justification for relying on the instrument's conversion between the two.
Ninja
Looking for Reality
MSA studies (I assume by this you mean Gage R&R) are for the test method...not the equipment.
That said, Specific gravity and density are pretty much the same thing...but wildly different all the same.
One is for g/cc of a solid (density) and one is for g/cc for a liquid (Specific Gravity).
One measuring a solid, the other a liquid...you're pretty much in for two GRRs regardless.
Density of a liquid is a misnomer. Specific Gravity of a solid is a misnomer.
When you measure a solid, the density reading counts, the Sp.Grav doesn't. And vice-versa.
Run the GRRs for the things you will use the equipment for...if both, GRR both...liquid and solid.
Ninja
Looking for Reality
And BTW...the standard for Specific Gravity is water...at 1atm and 25degC. Don't buy it, get it from the tap...unless your spec is ridiculously tight...
Eredhel
Quality Manager
Had a print call out for "Specific Gravity" on a product line once, the engineer removed it before we started running them. I've learned a bit more today :).
ADSJT
Quality Engineer
Thank you Ninja,
I am not purchasing water, I plan to purchase standards that are traceable to specific readings. I cannot use our product for the test that I am currently running. And by MSA, I mean GR&R ,Accuracy, Linearity, Matching and Correlation, and Long Term Stability.
ADSJT
Quality Engineer
It is my understanding that specific gravity has no units because it is a ratio of the density of a substance to the density of a standard. It is also called relative density. That is why the question came up regarding using the results of the density studies to also cover specific gravity.
Ninja
Looking for Reality
You are correct in this...but the "standard" being water at STP...which is 1.000 g/cm3...the specific gravity ends up being correct either with or without units.
THe specific gravity of Kerosene at 60degF is 0.820 ...that means both that it is 82% the "density" of water at STP...and that it is 0.820 grams/cm3
Formally, it is a unit-less figure...but I rarely dress up that much :cool:
With GRR on that type of equipment being so easy and quick to run...I would just run it and remove all question.
Ninja
Looking for Reality
A good move...but for linearity you'll want to use water as well.
Make sure you understand the full formality behind sample prep of your standards...temperature and purity matter...to the degree dictated by your needs in your spec range...
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B For a measuring instrument, should MSA be done first or the Capability studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
Bev D MSA Misc. Quality Assurance and Business Systems Related Topics 46
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O MSA Study for a steel ruler Manufacturing and Related Processes 6
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
G MSA on a Counting System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Test Method Validation or MSA for Batch Manufacturing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA on a process using different fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
