Resource icon
MSA 2019-11-11
Bill Levinson
Industrial Statistician and Trainer
I looked briefly at the download, and it raises a very interesting point; inspectors are fixed rather than random factors. This means that, if one were to bring in other inspectors, the reproducibility variation component could indeed be different. I wonder if the key deliverable from the R&R study should be, rather than the specific reproducibility component (although this is mandatory and must be reported) is the fact that there is appraiser variation which means we should look at how the measurement is done to remove it regardless of magnitude.
A simple example is a micrometer whose instructions say "finger tight," the perception of which will vary from one inspector to another, and a micrometer with a slip clutch to make the amount of pressure constant.
The Youden Plot looks like it is useful for interlaboratory comparisons (ASTM for example) and I can see how it can apply to MSA as well. 1.3.3.31. Youden Plot
Jack Youden developed the Youden plot when he was the head of NBS and yes it is applicable to any measurement system comparison that utilizes 2 repeated values. There is a great history of his career at the AMSTAT site.
It is important to note that that the ‘popular’ Gauge R&R method is only ‘mandatory’ in some industries. Primarily the automotive industry as that is where it originated. Many industries do not require this approach; those that do often have required without much thought - they just copied the automotive industry. As my Mother used to say: “if all of your friends were going to jump off a bridge would you?” I choose to not jump.
Golfman25
unfortunately too many people just blindly copy the automotive industry. It creates a lot of unnecessary heartache.
Bill Levinson
I trust the AIAG's manuals because they make a lot of sense, and are entirely consistent with generally accepted methods. This is not to say there is never room for improvement. As but one example, Donald Wheeler pointed out quite accurately that risk priority numbers are products of ordinal ratings and might therefore not reflect the actual risk level. The AIAG-VDA FMEA manual now addresses this. On the other hand, I am now very interested in the Youden plot and how it might be used to supplement traditional MSA.
Bill Levinson
Wheeler makes sense, and I never paid much attention to "percentage of total variance." All most people care about is the precision/tolerance ratio which is based on the gage standard deviation as calculated from the appraiser and equipment variation only.
I don't pay much attention to part variation either because, with only 10 parts, we don't have enough data for a good estimate; we will rely on the process capability study instead (with 30 or more measurements for a good one). And of course part variation, which we expect, does not have anything to do with the gage precision.
Bill - did you read my paper? From what you just said you clearly don’t trust several critical items of the method AIAG has adopted.
Bill Levinson
Your article raises some good points; I am going through it in a little more detail.
On page 26, "A subgroup size of 10 can be biased by one outlier" ... the outlier should be evident in the MSA assessment such as the range chart and also in anything supporting, like a normal probability plot. At this point, we know something is wrong with the study (or that there is a risk of non-random assignable cause measurement errors).
Also, 10 is a clearly inadequate sample for estimating the part variation; I see part variation as more of an academic exercise where we compare what we get from the MSA to what we get from a process capability study that uses 30 or more parts. I would not rely at all on the MSA's part variation to reflect the actual process performance. Also, I am not sure why part variation is even relevant (unless one wants to compare part variation to gage variation) because the key metric is the ratio of the gage standard deviation to the specification width or tolerance, and not to the process standard deviation.
I would also, as you point out on page 28, be hesitant to add %EV and %AV as calculated for exactly the reason you describe. The deliverable is the total gage standard deviation for which a precision/tolerance ratio can be calculated. I know that various software reports these things but my webinar on MSA does not bother with them at all because the deliverable is the P/T ratio.
I am going to continue looking through your presentation, and I will also see what I can find on the Youden plot, which looks very interesting.
Ashland78 MSA clause or wording needed. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA clause 7.1.5.1.1 - Statistical studies on counting weight scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 2
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA When an Instrument Measures More than One Parameter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O MSA Study for a steel ruler Manufacturing and Related Processes 6
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
G MSA on a Counting System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Test Method Validation or MSA for Batch Manufacturing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA on a process using different fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
