Good morning all. I had some situations come up that I wanted to run by you. We are under the IATF16949 automotive standard at our facility. My questions are:
1) Are studies required for gauges that are used for sorting if they are not normally used on production parts/material? Some gauges we only purchase for sorting purposes. The general rules I have heard before are "If its on the control plan/inspection plan, it has to have an MSA" and "If its used to determine conformance of parts, it must be". If the second rule is true, then that would mean any sorting gauges must undergo an MSA study, correct?
2) What about gauges that are just used to determine a particular model or size? We use one machine to take a length measurement to determine if we are checking the correct model because some of the model numbers only vary by a few millimeters. If we run our parts in that machine just to ensure that that part falls within the part program being ran based off of a reference measurement, will that also need an MSA? I know that sounds crazy, but its checking friction welding seam to seam, and this measurement is just a reference based on the length of the part minus the material on each end that is removed or "curled over" during welding. Its even a reference dimension on the print, but its more used to ensure that we dont send out the wrong product.
Thoughts?
Thoughts?
