MSDS for Forklift Battery - Do I need to get an MSDS for our forklift batteries?
dkmnem
#11
I asked the question due to the findings of an environmental audit that was performed at our facility in PA. We have 36 electric forklifts and have been told that we do need to report Sulfuric Acid on our PA. Tier II reports. We do occasionally add water to a battery but, other than that activity, charging in the forklift is the normal interaction our people have with the battery. I certainly want to comply with the governmental requirements but find there is confusion even among experts as to just what those requirements are. Our company had the audit performed in preparation for ISO 14000 certification.
Doug Tropf
#12
If the battery is a consumer commodity do you still need to report the acid on your Tier II report? The threshold for Sulfuric Acid is 500# but if we do not service the battery, other than charging in the forklift, is there a need to report? Thanks
This is from a Tier II Reporting Guide regarding lead-acid batteries:
If the total amount of sulfuric acid in all the batteries is above 500 pounds, the sulfuric acid must be reported. Determine the total weight of sulfuric acid in the batteries by using the following formula:
Weight of battery x 0.18 (factor) = estimated weight of sulfuric acid
bobdoering
Stop X-bar/R Madness!!
#13
MSDS's are primarily a safety document for workers in the workplace and are required of manufacturers to generate.
... Now if someone is adament about a MSDS sheet for a battery in a forklift then they better come up with an emergency shower that can be kept within 10 feet of that worker at all times that he/she is around the battery because the battery contains corrosive material.
I am not doubting you are right, but I am thinking that it is pitiful. So, your lift truck driver rolls it off the dock. The batteries crack and are leaking all over the dock. But, because you were worried about a liability of an emergency shower, you opted not to have an MSDS sheet. I guess you hose it down the drain and dump the batteries in the dumpster...
Now, MSDS for water-based white out? Might as well have a NFPA label on the drinking fountain. :cool:
Randy
#14
9 times out of 10 the msds will only say clean up any spill according to regulations or a defined spill control procedure.
Now the problem in the case you provide isn't the battery, it's the competence of the driver or the situation or hazards present that were the cause of the forklift accident to begin with.
bobdoering
#15
True. Sometimes it has some information that is not always obvious - on occasion better than guessing. Most MSDSs are watered down to protect the guilty. Thank the lawyers.
Ya think? Now, this couldn't really happen in real life, could it? :sarcasm: Even with a towmotor license....:rolleyes: Net result is Professional Liquid Plumber down the drain...:tg:
Randy
#16
The actual net is if the stuff goes down the drain the local POTW will probably levy a big fine and issue a NOV.
And kinda as Doug said.....ya gotta have about a gazillion batteries before you need to do the Tier 2...........Been there, done that.
P MSDS for MVQ FDA White, Vinyl Methyl Silicone Rubber EU Medical Device Regulations 4
M MSDS process audit - Can any one give idea for checklist of the same Occupational Health & Safety Management Standards 14
R Material safety data sheet (MSDS) related clause in IATF 16949 manual IATF 16949 - Automotive Quality Systems Standard 17
T MSDS Language Requirements for Reach Purposes REACH and RoHS Conversations 3
D MSDS / GHS Walk-through / Auditing Occupational Health & Safety Management Standards 6
P Specification Subscription Services - Eg: Things like MSDS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D SDS (MSDS) for complex products such as a TV, computer, cars, etc Miscellaneous Environmental Standards and EMS Related Discussions 3
Q Kraft Paper / Core Paper MSDS - Plastic Specs IATF 16949 - Automotive Quality Systems Standard 4
N Do Material MSDS's Need To Be Controlled? Document Control Systems, Procedures, Forms and Templates 3
A Is it mandatory to revise MSDS every three years? ISO 14001:2015 Specific Discussions 3
A Where I can get MSDS for Penetrant, Cleaner, and Developer Taseto Aerosol? Miscellaneous Environmental Standards and EMS Related Discussions 2
M Old MSDS Sheets vs new HCS Standard - Format Requirements Manufacturing and Related Processes 18
S Excel format for cataloging MSDS Sheets Occupational Health & Safety Management Standards 2
Q Medical Device with Lead (Pb) - Do I need to create an MSDS sheet? Other US Medical Device Regulations 1
D MSDS Datasheet Retention Requirements and Responsibilities RoHS, REACH, ELV, IMDS and Restricted Substances 6
N What to do about very old MSDS Sheets Occupational Health & Safety Management Standards 24
Q Do we need to keep MSDS documents for all "chemicals" used in the factory? Occupational Health & Safety Management Standards 4
J MSDS Sheets on Purchased Steel - Do we need them? Occupational Health & Safety Management Standards 18
R MSDS Sheets for Products - How much is too much - Or is there ever too much? Occupational Health & Safety Management Standards 12
somashekar Chemical Storage Design based on MSDS Study Occupational Health & Safety Management Standards 5
N MSDS (Material Safety Data Sheet) Management Services - Advice needed Miscellaneous Environmental Standards and EMS Related Discussions 1
H Hazardous Chemicals Specified in MSDS (format of MSDS) Occupational Health & Safety Management Standards 10
Q Control of MSDS (Material Safety Data Sheets) - Document Control required? Miscellaneous Environmental Standards and EMS Related Discussions 8
S MSDS Records - Is a hard copy required if I have a scanned copy? Miscellaneous Environmental Standards and EMS Related Discussions 14
S Should we Retain MSDS Sheets for chemicals not in use? Miscellaneous Environmental Standards and EMS Related Discussions 5
M Dissemination of MSDS regarding your product in your company? ISO 13485:2016 - Medical Device Quality Management Systems 6
R Are MSDS sheets or books a part of ISO9001 or QSI audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
T MSDS Software - Anyone know of any affordable, yet good, stand alone MSDS software? Miscellaneous Environmental Standards and EMS Related Discussions 6
B Thermometer Vendor that can Supply MSDS General Measurement Device and Calibration Topics 3
C MSDS/IMDS forum needed RoHS, REACH, ELV, IMDS and Restricted Substances 6
C MSDS Sheets in ISO-14001 2004 - Should MSDS sheets be "controlled documents"? ISO 14001:2015 Specific Discussions 22
S Do MSDS's (Material Safety Data Sheets) need to be controlled. If yes, HOW? Document Control Systems, Procedures, Forms and Templates 9
P I need to make an MSDS for PCB (Printed Circuit Board) Assembly Product Miscellaneous Environmental Standards and EMS Related Discussions 10
V MSDS information in cellular site shelters? Miscellaneous Environmental Standards and EMS Related Discussions 2
K MSDS - Hazardous Material List - Where can I find the list? Miscellaneous Environmental Standards and EMS Related Discussions 7
L Annual Chemical Inventory and MSDS Sheets Miscellaneous Environmental Standards and EMS Related Discussions 1
R IMDS (Automotive MSDS) for Lead Free Components and Solder RoHS, REACH, ELV, IMDS and Restricted Substances 10
L Material Safety Data Sheet - MSDS should specify how to make the material innocuous Miscellaneous Environmental Standards and EMS Related Discussions 10
C MSDS & EMS (Environmental Management System) Linkage Miscellaneous Environmental Standards and EMS Related Discussions 5
J Are MSDS Sheets required on ALL items of a chemical nature? Miscellaneous Environmental Standards and EMS Related Discussions 3
Awais Forklift Reliability Analysis Manufacturing and Related Processes 6
J ISO 9001 Competency - Forklift License and Internal Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M What are the major causes of Forklift Accidents? Occupational Health & Safety Management Standards 13
A Forklift Integration into the Quality Manual AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M CE Marking - Forklift Trucks Imported Legacy Blogs 5
B Required Wall Thickness for Forklift Extensions Manufacturing and Related Processes 5
L OSHA Forklift Training Requirements - Qualification of the "trainer" Occupational Health & Safety Management Standards 9
H Forklift Safety - Driver loses control in warehouse (Video) Occupational Health & Safety Management Standards 2
Jim Wynne Forklift Safety, or Lack Thereof Coffee Break and Water Cooler Discussions 4
Ajit Basrur Driving License for Forklift operators Manufacturing and Related Processes 9
