MSDS process audit - Can any one give idea for checklist of the same
Dears,
As company, We have a MSDS process which to be audited during incoming days.
Could any one give idea for checklist of the same.
The fact is MSDS generated by company is not updated as per GHS but the supplier MSDS is updated, what is the impact on audit findings
Jen Kirley
Quality and Auditing Expert
Welcome to The Cove!
I think of MSDS (now SDS) as documents of external origin. As such, the organization is not responsible for controlling their revision (content) but is expected to provide up-to-date information to personnel as needed. What do your procedures say about them? ISO 45001:2018 requires (7.5.3) that "Documented information of external origin determined by the organization to be necessary for the planning and operation of the OH&S management system shall be identified, as appropriate, and controlled." Are SDS necessary for the planning and operation of your OH&S management system?
There were good reasons for MSDS to move to their new format. They used to be so different - some needed a PhD in Chemistry to understand, others left out large sections of information and said "proprietary." The new format is not perfect, but I think it is an improvement.
The task of keeping these up to date is thankless, and can be enormous depending on the number and type of chemicals you have. Some manufacturers provide a copy of SDS with every bulk shipment, while others must be researched on line or requested by telephone. This can become awkward as manufacturers go out of business, are acquired, change their names etc.
As an auditor I have issued nonconformances for failure to keep these documents current, but largely did so if the organization claimed to have control of it and I found truly ancient MSDS... I am talking about 1992 vintage. A lot can change in that much time, based on updated medical understanding of effects some of these chemicals can have.
As far as checklists go... are you required to keep a list of chemicals you store/use on site? If so, that is a place to start. I would even consider using such a list to periodically check if these chemicals have expired, or are even still needed at all, are stored properly etc. That is a big effort too, but it can occasionally be worthwhile. I would not feel the need to use anything more elaborate than a matrix that lists the chemicals, and has boxes to indicate with X the found acceptable criteria. For those that do not conform, I would indicate with a circled 1, 2, 3 etc. and indicate the meaning of these at the bottom of the page. Simple methods are good for a job like this.
I hope this helps!
Firstly thanks for your reply..
Let me clarify some things; my company is producing chemicals and status is
Raw material MSDS which received from suppliers is updated as per GHS.
But MSDS for products which generated by my company is not updated as per GHS...
What is the impact for that form audit side of any another side ...
Thanks in advance.
Thanks in advance.
What type of audit are you anticipating? What are the documented requirements for the issue that concerns you?
Jen Kirley
Do I correctly understand that you produce chemicals but are not supplying Safety Data Sheets to customers who purchase your chemicals?
We are located in Saudi Arabia,
Our products going to many countries as well as locally..(Africa Arabian countries...)
For Europe we generated SDS as per reach for that material only..
I just joined this organisation and I feel this in correct practice..
P MSDS for MVQ FDA White, Vinyl Methyl Silicone Rubber EU Medical Device Regulations 4
R Material safety data sheet (MSDS) related clause in IATF 16949 manual IATF 16949 - Automotive Quality Systems Standard 17
T MSDS Language Requirements for Reach Purposes REACH and RoHS Conversations 3
D MSDS / GHS Walk-through / Auditing Occupational Health & Safety Management Standards 6
P Specification Subscription Services - Eg: Things like MSDS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D SDS (MSDS) for complex products such as a TV, computer, cars, etc Miscellaneous Environmental Standards and EMS Related Discussions 3
Q Kraft Paper / Core Paper MSDS - Plastic Specs IATF 16949 - Automotive Quality Systems Standard 4
N Do Material MSDS's Need To Be Controlled? Document Control Systems, Procedures, Forms and Templates 3
A Is it mandatory to revise MSDS every three years? ISO 14001:2015 Specific Discussions 3
A Where I can get MSDS for Penetrant, Cleaner, and Developer Taseto Aerosol? Miscellaneous Environmental Standards and EMS Related Discussions 2
M Old MSDS Sheets vs new HCS Standard - Format Requirements Manufacturing and Related Processes 18
S Excel format for cataloging MSDS Sheets Occupational Health & Safety Management Standards 2
Q Medical Device with Lead (Pb) - Do I need to create an MSDS sheet? Other US Medical Device Regulations 1
D MSDS Datasheet Retention Requirements and Responsibilities RoHS, REACH, ELV, IMDS and Restricted Substances 6
N What to do about very old MSDS Sheets Occupational Health & Safety Management Standards 24
Q Do we need to keep MSDS documents for all "chemicals" used in the factory? Occupational Health & Safety Management Standards 4
J MSDS Sheets on Purchased Steel - Do we need them? Occupational Health & Safety Management Standards 18
R MSDS Sheets for Products - How much is too much - Or is there ever too much? Occupational Health & Safety Management Standards 12
somashekar Chemical Storage Design based on MSDS Study Occupational Health & Safety Management Standards 5
N MSDS (Material Safety Data Sheet) Management Services - Advice needed Miscellaneous Environmental Standards and EMS Related Discussions 1
H Hazardous Chemicals Specified in MSDS (format of MSDS) Occupational Health & Safety Management Standards 10
Q Control of MSDS (Material Safety Data Sheets) - Document Control required? Miscellaneous Environmental Standards and EMS Related Discussions 8
S MSDS Records - Is a hard copy required if I have a scanned copy? Miscellaneous Environmental Standards and EMS Related Discussions 14
S MSDS for Forklift Battery - Do I need to get an MSDS for our forklift batteries? Miscellaneous Environmental Standards and EMS Related Discussions 15
S Should we Retain MSDS Sheets for chemicals not in use? Miscellaneous Environmental Standards and EMS Related Discussions 5
M Dissemination of MSDS regarding your product in your company? ISO 13485:2016 - Medical Device Quality Management Systems 6
R Are MSDS sheets or books a part of ISO9001 or QSI audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
T MSDS Software - Anyone know of any affordable, yet good, stand alone MSDS software? Miscellaneous Environmental Standards and EMS Related Discussions 6
B Thermometer Vendor that can Supply MSDS General Measurement Device and Calibration Topics 3
C MSDS/IMDS forum needed RoHS, REACH, ELV, IMDS and Restricted Substances 6
C MSDS Sheets in ISO-14001 2004 - Should MSDS sheets be "controlled documents"? ISO 14001:2015 Specific Discussions 22
S Do MSDS's (Material Safety Data Sheets) need to be controlled. If yes, HOW? Document Control Systems, Procedures, Forms and Templates 9
P I need to make an MSDS for PCB (Printed Circuit Board) Assembly Product Miscellaneous Environmental Standards and EMS Related Discussions 10
V MSDS information in cellular site shelters? Miscellaneous Environmental Standards and EMS Related Discussions 2
K MSDS - Hazardous Material List - Where can I find the list? Miscellaneous Environmental Standards and EMS Related Discussions 7
L Annual Chemical Inventory and MSDS Sheets Miscellaneous Environmental Standards and EMS Related Discussions 1
R IMDS (Automotive MSDS) for Lead Free Components and Solder RoHS, REACH, ELV, IMDS and Restricted Substances 10
L Material Safety Data Sheet - MSDS should specify how to make the material innocuous Miscellaneous Environmental Standards and EMS Related Discussions 10
C MSDS & EMS (Environmental Management System) Linkage Miscellaneous Environmental Standards and EMS Related Discussions 5
J Are MSDS Sheets required on ALL items of a chemical nature? Miscellaneous Environmental Standards and EMS Related Discussions 3
DuncanGibbons How to determine process stability for a process whose outputs should be steadily increasing? Capability, Accuracy and Stability - Processes, Machines, etc. 1
J Document hierarchy for Process mapping for ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
A Cosmetic product registration process EU Medical Device Regulations 0
A Sample size selection for process validation - continuous data Reliability Analysis - Predictions, Testing and Standards 3
Q Failure mode, Process Excursion and Failure mode cause ISO 14971 - Medical Device Risk Management 3
Sidney Vianna IAQG News IAQG 9401-1:2022 Changes & Organization Certification Analysis Process - OCAP Demo AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
E Process capability in a single batch Capability, Accuracy and Stability - Processes, Machines, etc. 3
Ashland78 IATF Process Control Plans not including customer name Manufacturing and Related Processes 13
S Sample size considerations in medical process qualification Reliability Analysis - Predictions, Testing and Standards 11
M Process flowcharts ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
