MSDS Records - Is a hard copy required if I have a scanned copy?
SheliaB
Hi everyone,
If I have our MSDS sheets scanned in on the computer do I need to keep a hard copy also?
Thanks,
SheliaB
Randy
Re: MSDS Records
Answer this...........Can people that need them acess them regardless of you method of storage and retrieval?
Remember, they must be accessable to people using hazardous materials as defined by 29CFR 1910.1200 and according to OSHA requirements.
Doug Tropf
Hi everyone,
Thanks,
SheliaB
Hard copies are not required. Be sure you have the computer versions backed up and that there are no barriers to immediate employee access.
somashekar
Hi everyone,
Thanks,
SheliaB
The quick availability of the MSDS at the place of storage or usage of the material is of importance. Perhaps the MSDS is your first document and if you can make required extracts from it for specific DO's and DON'Ts at your place of storage and use that is well seen and understood (language requirement / pictures) its better.
SteelMaiden
Re: MSDS Records
I think it is not necessery, but you have to back up on CD-rom
Really? Can you cite the requirement to back up on CD-rom? I have never seen any requirements that name the media/storage that must be used.
To tell you the truth, we don't have hard copies, scanned copies or any copies at all. We get the MSDS, call a company that we have contracted with to manage our MSDSs and tell them that we are adding it to our list. It then becomes their job to have copies/information available 24/7/365.
There truly is more than one way to skin a cat, as long as you have the ability to lay your hands on the MSDS for chemicals used. :notme:
samsung
Re: MSDS Records
In my opinion, the MSDS shouldn't form part of, in particular, an EMS since they are meant to address safety related requirements.
Re: MSDS Records
Dear Samsung,
Often MSDS contains information on: (a) what to do in case of spillage, (b) how to dispose of the unused chemical/container, (c) transportation guidelines, (d) first-aid in case of inhalation (remember Bhopal), ingestion, skin contact, eye contact (e) decomposition products in case of fire etc. These are information required to maintain a good EMS. At least in India MSDS is required as a part of the Manufacture, Storage and Import of Hazardous Chemicals Rules, which is a rule issued under the Environment (Protection) Act. So MSDS should be available for access under 4.3.2: Legal and Other requirements. MSDS also is required for preparing on-site and off-site emergency plans as per the said rules (and so required, as a source of information, for emergency preparedness: 4.4.7).
With kind regards,
Ramakrishnan
samsung
Re: MSDS Records
Dear Samsung,
With kind regards,
Ramakrishnan
I have studied a lot of MSDS and have come to conclude that most often (if not at all) the information required for the effective operation of an EMS (based on 14001) with regard to use, handling and disposal of chemicals isn't provided in an MSDS. e.g.
1. Spill Control: mostly you will find the following advice in an MSDS: "prevent entry of the chemical into sewers and waterways and dispose the collected spill in accordance with the applicable regulations". That's all.
2. As far as 'transportation' of chemicals matter, you will get a (circular) UN ref. no. applicable for transportation of dangerous goods. e.g.
Shipping Name and Description: BENZENE
UN Number: UN1114
CAS Registry Number: 71-43-2
Class: 3 Flammable Liquids
3. Disposal of decomposition products after a fire incidence: One is directed to refer to the regulatory requirements as applicable.
In short, there's not much in an MSDS that can really help maintain an EMS. Ofcourse, you will get tonnes of information related in particular to human health and safety. Please see the attached sample MSDS.
In India, although the 'Manufacture, Storage and Import of Hazardous Chemicals Rules' (MSIHC) were made under the Environment Protection Act but they are enforced by the Chief inspector of Factories, a regulatory agency responsible for enforcement & regulation of H&S rules in the concerned state.
Thanks.
P MSDS for MVQ FDA White, Vinyl Methyl Silicone Rubber EU Medical Device Regulations 4
M MSDS process audit - Can any one give idea for checklist of the same Occupational Health & Safety Management Standards 14
R Material safety data sheet (MSDS) related clause in IATF 16949 manual IATF 16949 - Automotive Quality Systems Standard 17
T MSDS Language Requirements for Reach Purposes REACH and RoHS Conversations 3
D MSDS / GHS Walk-through / Auditing Occupational Health & Safety Management Standards 6
P Specification Subscription Services - Eg: Things like MSDS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D SDS (MSDS) for complex products such as a TV, computer, cars, etc Miscellaneous Environmental Standards and EMS Related Discussions 3
Q Kraft Paper / Core Paper MSDS - Plastic Specs IATF 16949 - Automotive Quality Systems Standard 4
N Do Material MSDS's Need To Be Controlled? Document Control Systems, Procedures, Forms and Templates 3
A Is it mandatory to revise MSDS every three years? ISO 14001:2015 Specific Discussions 3
A Where I can get MSDS for Penetrant, Cleaner, and Developer Taseto Aerosol? Miscellaneous Environmental Standards and EMS Related Discussions 2
M Old MSDS Sheets vs new HCS Standard - Format Requirements Manufacturing and Related Processes 18
S Excel format for cataloging MSDS Sheets Occupational Health & Safety Management Standards 2
Q Medical Device with Lead (Pb) - Do I need to create an MSDS sheet? Other US Medical Device Regulations 1
D MSDS Datasheet Retention Requirements and Responsibilities RoHS, REACH, ELV, IMDS and Restricted Substances 6
N What to do about very old MSDS Sheets Occupational Health & Safety Management Standards 24
Q Do we need to keep MSDS documents for all "chemicals" used in the factory? Occupational Health & Safety Management Standards 4
J MSDS Sheets on Purchased Steel - Do we need them? Occupational Health & Safety Management Standards 18
R MSDS Sheets for Products - How much is too much - Or is there ever too much? Occupational Health & Safety Management Standards 12
somashekar Chemical Storage Design based on MSDS Study Occupational Health & Safety Management Standards 5
N MSDS (Material Safety Data Sheet) Management Services - Advice needed Miscellaneous Environmental Standards and EMS Related Discussions 1
H Hazardous Chemicals Specified in MSDS (format of MSDS) Occupational Health & Safety Management Standards 10
Q Control of MSDS (Material Safety Data Sheets) - Document Control required? Miscellaneous Environmental Standards and EMS Related Discussions 8
S MSDS for Forklift Battery - Do I need to get an MSDS for our forklift batteries? Miscellaneous Environmental Standards and EMS Related Discussions 15
S Should we Retain MSDS Sheets for chemicals not in use? Miscellaneous Environmental Standards and EMS Related Discussions 5
M Dissemination of MSDS regarding your product in your company? ISO 13485:2016 - Medical Device Quality Management Systems 6
R Are MSDS sheets or books a part of ISO9001 or QSI audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
T MSDS Software - Anyone know of any affordable, yet good, stand alone MSDS software? Miscellaneous Environmental Standards and EMS Related Discussions 6
B Thermometer Vendor that can Supply MSDS General Measurement Device and Calibration Topics 3
C MSDS/IMDS forum needed RoHS, REACH, ELV, IMDS and Restricted Substances 6
C MSDS Sheets in ISO-14001 2004 - Should MSDS sheets be "controlled documents"? ISO 14001:2015 Specific Discussions 22
S Do MSDS's (Material Safety Data Sheets) need to be controlled. If yes, HOW? Document Control Systems, Procedures, Forms and Templates 9
P I need to make an MSDS for PCB (Printed Circuit Board) Assembly Product Miscellaneous Environmental Standards and EMS Related Discussions 10
V MSDS information in cellular site shelters? Miscellaneous Environmental Standards and EMS Related Discussions 2
K MSDS - Hazardous Material List - Where can I find the list? Miscellaneous Environmental Standards and EMS Related Discussions 7
L Annual Chemical Inventory and MSDS Sheets Miscellaneous Environmental Standards and EMS Related Discussions 1
R IMDS (Automotive MSDS) for Lead Free Components and Solder RoHS, REACH, ELV, IMDS and Restricted Substances 10
L Material Safety Data Sheet - MSDS should specify how to make the material innocuous Miscellaneous Environmental Standards and EMS Related Discussions 10
C MSDS & EMS (Environmental Management System) Linkage Miscellaneous Environmental Standards and EMS Related Discussions 5
J Are MSDS Sheets required on ALL items of a chemical nature? Miscellaneous Environmental Standards and EMS Related Discussions 3
G Does FDA allows remote approvals of quality documentation. Is there any specific guidance on signing any quality records remotely? Document Control Systems, Procedures, Forms and Templates 1
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Complaint Records - Accessing records on Easy Track Software Records and Data - Quality, Legal and Other Evidence 3
P IDEs and Clinical Investigators - Advice About Records? Other US Medical Device Regulations 3
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 2
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
J Requirement for Retention of Records of Withdrawn Documents of External Origin Document Control Systems, Procedures, Forms and Templates 3
