K
Hi, I hope you people can assist me. I am in the process of implementing ISO 17025 for a Test laboratory testing vehicle tow bars. Test requirements are as per SANS 1505-1:2007 sections 4.2 and 5.0.
I need to compile a procedure for measurement uncertainty. The complete test is controlled by a pc program applying set forces through a load cell and it records the cycles and control the frequency (not exceeding 35Hz) the test duration is 2,000,000 cycles. The only calibrated equipment is the load cell, torque wrench (to tighten the mounting bolts) and a protractor to set the ram rod angle to the spec (15 ̊±1 ̊), any sample or advice will be highly appreciated.
