Multiple time zones in the Audit Trail
Hi all,
We are software vendor and are moving our software to be capable to work in global setup (across multiple time zones). Until now we only supported its use in single time zone.
DB stores date/time in non-changeable format.
The idea of implementation was:
- in the UI, in all tabs time is presented according to user's client local time zone for easier overview, e.g. I open it in CET so I see 11:02:00
- in the Audit Trail each entry is stamped with two static time stamps: Record time (with originator time zone indication) & UTC Record time, e.g. Record time: 05:02:00 EST (record was generated in EST time zone), UTC Record time: 10:02:00
However in the details of each audit trail entry we also store some fields which contain time too e.g. "Instrument last seen: 15-Feb-22 11:01:00". These fields relates to the fields in UI. I am not sure how they should be presented?
In my opinion:
- They have to be 1:1 to what is displayed in the UI
- Audit Trail details shall not be dynamically updated between different clients from different time zones
Then with the idea of implementation I have no idea how to handle time fields in the audit trail details.
Tagin
I'm not clear on this: is "Instrument last seen: 15-Feb-22 11:01:00" a single text string, or is there a defined field or value for "Instrument last seen" and then a separate datetime field for "15-Feb-22 11:01:00"?
yodon
A bit unclear, myself. However, I think you may be mixing audit trail data with how the audit trail data is presented? It sounds like the audit trail contains all the necessary information to allow it to be displayed (through some application) as local time. In other words, the data isn't dynamically changed but the way it's presented is adapted. You may need to look at the truly raw data.
Hey, so let's imagine in the UI in the "Instrument" tab we have list of instruments with many associated fields, one of them is "Instrument last seen" with the value in the separate datetime field "15-Feb-22 11:01:00". There was a change in the Instrument1 so the audit trail records that Instrument1 has been modified and in the audit trail details of this entry there is for the field "Instrument last seen": Old value: "15-Feb-22 11:01:00" and New value: "15-Feb-22 14:03:00".
In the Instrument tab: the value of "Instrument last seen" is adapted to be presented in Client's local time (that is based in CET): 15-Feb-22 14:03:00
In the Audit Trail tab: entry "Instrument1 modified" is stamped with not adapted values, that is original local time: Record time: 08:03:00 EST (record was generated in EST time zone), UTC Record time: 13:03:00
Can the details of audit trail entry be also adapted? E.g. Old value and new value for "Instrument last seen" fields? Or should they rather not be changed depending on who display them? (meaning it is not changed in the db)
D Multiple amendments at same license Canada Medical Device Regulations 0
F Multiple Intended Use Statements US Food and Drug Administration (FDA) 1
P IMDS Multiple parts RoHS, REACH, ELV, IMDS and Restricted Substances 1
E How to isolate multiple APPLIED PARTS IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Can you have one Core Process (PEAR) with multiple plants? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C Multiple Part Numbers, IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 2
D Control chart selection of multiple batches review Statistical Analysis Tools, Techniques and SPC 4
M Reference to an archived template in multiple SOPs ISO 13485:2016 - Medical Device Quality Management Systems 2
Z GRR for multiple automated metrology tools Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
L 1 product multiple factories EU Medical Device Regulations 0
C Custom Injection Molding - Multiple Cavities and Subgrouping Capability, Accuracy and Stability - Processes, Machines, etc. 4
A One-factor and multiple-response Minitab optimization Using Minitab Software 2
I Multiple Indications in SaMD Other US Medical Device Regulations 8
K Multiple importers EU Medical Device Regulations 2
S Instructions for use multiple manufacturing locations ISO 13485:2016 - Medical Device Quality Management Systems 0
S Defibrillator Protection applicability When using Multiple applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
V Software as medical device (SaMD) replicated for multiple clients through APIs IEC 62304 - Medical Device Software Life Cycle Processes 5
C Multiple owners for one listed device Medical Device and FDA Regulations and Standards News 1
A CE-IVD Technical File with Multiple IFUs EU Medical Device Regulations 5
K One CE Mark holder - multiple manufacturing sites EU Medical Device Regulations 3
K Multiple function device products EU Medical Device Regulations 0
O Are power distribution units Multiple Socket Outlets (MSOs)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
shimonv FDA News FDA guidance on Multiple Function Device Products (8/2020) Other US Medical Device Regulations 1
C Contract Review with Multiple Line items ISO 13485:2016 - Medical Device Quality Management Systems 7
I Cannot Export multiple sections from Excel to PDF without losing pagination Excel .xls Spreadsheet Templates and Tools 23
Q Legal Manufacturing Address Change – multiple registrations at same address 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B QMS question in regards to multiple medical devices/products and N/A activities Other Medical Device Related Standards 12
Proud Liberal Power Query to combine multiple tables of unequal number of columns Statistical Analysis Tools, Techniques and SPC 1
D Reduction of software class based on multiple external risk controls IEC 62304 - Medical Device Software Life Cycle Processes 5
S Samples for GR&R - Can we get the 10 samples from multiple models Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
C FDA Registration Requirements for Multiple Sites 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
C Can a manufacturer (in South of Korea) have multiple Brazil Registration Holder (BRH) for same brend name? Other Medical Device Regulations World-Wide 1
S Multiple Authorized Reps in the EU for the same device? EU Medical Device Regulations 3
S Providing IFU (Instructions for Use) in multiple languages EU Medical Device Regulations 0
C FMEA - Multiple function failures considerations FMEA and Control Plans 3
B AS9100 Multiple Distributor warehousing locations under same Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
W SOP for Vigilance reporting covering multiple requirements Document Control Systems, Procedures, Forms and Templates 7
E Informational Internal Audits - Wear multiple hats what can and can't I audit (so I'm not auditing my own work) Internal Auditing 149
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J DoE (Design of Experiments) - Multiple responses with different factors Using Minitab Software 4
leftoverture Control Plan - Multiple Process Steps FMEA and Control Plans 8
K Internal Auditing - Umbrella QMS and Multiple Standards Oil and Gas Industry Standards and Regulations 4
M Multiple missed POs grounds for SCAR? ISO 13485:2016 - Medical Device Quality Management Systems 32
G Single DFU for multiple medical devices in one box Other Medical Device Regulations World-Wide 0
J Brazil GMP license work with multiple BRH? Other Medical Device Regulations World-Wide 3
