Murphy's Law
U
Umang Vidyarthi
Friends
I have recently come across these seeds of wisdom entitled "Murphy's Law". Some thing unique like "Dilbert's Principle".
Enjoy !!
Murphy's Laws
Whenever I find the key to success, someone changes the lock.
To Err is human, to forgive is not a COMPANY policy.
The road to success??.. Is always under construction.
Alcohol doesn't solve any problems, but if you think again, neither does Milk.
In order to get a Loan, you first need to prove that you don't need it.
All the desirable things in life are either illegal, expensive or fattening or married to someone else.
Since Light travels faster than Sound, people appear brighter before you hear them speak.
Everyone has a scheme of getting rich?.. Which never works.
If at first you don't succeed?. Destroy all evidence that you ever tried.
You can never determine which side of the bread to butter. If it falls down, it will always land on the buttered side.
Anything dropped on the floor will roll over to the most inaccessible corner.
As soon as you mention something?? if it is good, it is taken?. If it is bad, it happens.
He who has the gold, makes the rules ---- Murphy's golden rule.
If you come early, the bus is late. If you come late?? the bus is still late.
Once you have bought something, you will find the same item being sold somewhere else at a cheaper rate.
When in a queue, the other line always moves faster and the person in front of you will always have the most complex of transactions.
If you have paper, you don't have a pen??. If you have a pen, you don't have paper?? if you have both, no one calls.
Especially for engg. Students----
If you have bunked the class, the professor has taken attendance.
You will pick up maximum wrong numbers when on roaming.
The door bell or your mobile will always ring when you are in the bathroom.
After a long wait for bus no.20, two 20 number buses will always pull in together and the bus which you get in will be more crowded than the other.
If your exam is tomorrow, there will be a power cut tonight.
Irrespective of the direction of the wind, the smoke from the cigarette will always tend to go to the non-smoker
Z
zancky
I would like to change:
"Anything dropped on the floor will roll over to the most inaccessible corner."
into
Anything dropped on the floor will roll over to the most inaccessible corner. Nevertheless it will be the most visible point for the auditor and the first to be inspected.
Randy
The odds of the jelly side of the bread landing face down is directly proportional to the value per square yard of the carpet under the table. Here are some others.........
Murphy's Laws of Combat
1. If the enemy is in range, so are you.
2. Incoming fire has the right of way.
3. Don't look conspicuous, it draws fire.
4. There is always a way, and it usually doesn't work.
5. The problem with the easy way out is that it has already been mined.
6. Try to look unimportant, they may be low on ammo.
7. Professionals are predictable, it's the amateurs that are dangerous.
8. The enemy invariably attacks on two occasions:
when you're ready for them.
when you're not ready for them.
9. Teamwork is essential, it gives them someone else to shoot at.
10. If you can't remember, then the claymore IS pointed at you.
11. The enemy diversion you have been ignoring will be the main attack.
12. A "sucking chest wound" is nature's way of telling you to slow down.
13. If your attack is going well, then it's an ambush.
14. Never draw fire, it irritates everyone around you.
15. Anything you do can get you shot, including nothing.
16. If you build yourself a bunker that's tough for the enemy to get into quickly, then you won't be able to get out of it quickly either.
17. Never share a foxhole with anyone braver than yourself.
18. If you're short of everything but the enemy, you're in a combat zone.
19. When you've secured the area, don't forget to tell the enemy.
20. Never forget that your weapon is made by the lowest bidder.
21. Friendly fire isn't.
22. If the sergeant can see you, so can the enemy.
23. Never stand when you can sit, never sit when you can lie down, never stay awake when you can sleep.
24. The most dangerous thing in the world is a second lieutenant with a map and a compass.
25. There is no such thing as an atheist in a foxhole.
26. A grenade with a seven second fuse will always burn down in four seconds.
27. Remember, a retreating enemy is probably just falling back and regrouping.
28. If at first you don't succeed call in an air-strike.
29. Exceptions prove the rule, and destroy the battle plan.
30. Everything always works in your HQ, everything always fails in the colonel's HQ.
31. The enemy never watches until you make a mistake.
32. One enemy soldier is never enough, but two is entirely too many.
33. A clean (and dry) set of BDU's is a magnet for mud and rain.
34. Whenever you have plenty of ammo, you never miss. Whenever you are low on ammo, you can't hit the broad side of a barn.
35. The more a weapon costs, the farther you will have to send it away to be repaired.
36. Field experience is something you don't get until just after you need it.
37. Interchangeable parts aren't.
38. No matter which way you have to march, its always uphill.
39. If enough data is collected, a board of inquiry can prove ANYTHING.
40. For every action, there is an equal and opposite criticism. (in boot camp)
41. The one item you need is always in short supply.
42. The worse the weather, the more you are required to be out in it.
43. The complexity of a weapon is inversely proportional to the IQ of the weapon's operator.
44. Airstrikes always overshoot the target, artillery always falls short.
45. When reviewing the radio frequencies that you just wrote down, the most important ones are always illegible.
46. Those who hesitate under fire usually do not end up KIA or WIA.
47. The tough part about being an officer is that the troops don't know what they want, but they know for certain what they DON'T want.
48. To steal information from a person is called plagiarism. To steal information from the enemy is called gathering intelligence.
49. The weapon that usually jams when you need it the most is the M60.
50. The perfect officer for the job will transfer in the day after that billet is filled by someone else.
51. When you have sufficient supplies & ammo, the enemy takes 2 weeks to attack. When you are low on supplies & ammo the enemy decides to attack that night.
52. The newest and least experienced soldier will usually win the Congressional Medal Of Honor.
53. A Purple Heart just goes to prove that were you smart enough to think of a plan, stupid enough to try it, and lucky enough to survive.
54. Murphy was a grunt.
