Must a vernier caliper and a rule be calibrated according to ISO 9001?
John Nabors - 2009
#31
Oops - forgot about the OP's other question about the CNC welder..
I'm a big fan of periodic volumetric testing ("ballbar testing") of CNC equipment. Most CNC's nowadays have software that allow a volumetric test to feed backlash and lead error compensation into the control to effectively 'rejuvenate' the CNC from error due to wear in the lead screws and slideways. I certainly wouldn't think of this as a calibration system requirement, but it's a nice tool for preventing errors before they happen as opposed to detecting them and reacting to them after the fact.
One quick and dirty way to see if you need backlash compensation: in each axis, drive the CNC in one direction to various points in its travel. Place the measuring point of a test indicator on some part of the driven component (spindle, welding head, etc.) so that the indicator is secured on a magnetic base or by other means to the table of the machine. Move the machine in the opposite direction and compare the results from the indicator to the distance the machine 'thinks' it has moved. If there is a discrepancy between the two, you need backlash compensation.
Kind Regards -John
John Nabors - 2009
#33
Re: Must a vernier caliper and a rule be calibrated?
If you know that your device is adequate to the task (which is often the case with tape measures) you shouldn't have to be concerned about calibration, even in the broadest sense of the term.
I must kindly and respectfully disagree. I don't know anything until I verify it.
I'll borrow one of Marc's signature lines: "One test is worth a thousand expert opinions!"
Hope Marc won't put out a hit out on this poor old river rat for borrowing his quote..
Kind regards -John
bobdoering
Stop X-bar/R Madness!!
#35
Even if a gage has no moving parts whatsoever (such as a 6"/15cm steel rule), usage results in some wear, possibly infinitesimal, but wear nonetheless.
Excellent point! Physical fact - two things always happen with a contact measurement gage: the measured parts wears the gage, and the gage wears the measured part - even if it is a molecule at a time.
If a steel rule is not in contact with the part (non-contact steel rule measurement?), then you are assured of parallax error, at least to some degree.
JaneB
#36
It's a question about whether it's worthwhile to worry about whether a device is measuring "correctly." If you know that your device is adequate to the task (which is often the case with tape measures) you shouldn't have to be concerned about calibration, even in the broadest sense of the term.
For the types of tasks I'm referring to, R&R shouldn't be necessary either. We should make sure that operators know how to read a tape measure and then let them do it.
Yes, that's what I was getting at. I quite agree Bob, that if the measurement needs to be accurate, then one should calibrate. But there are occasions when it isn't required.
An example: at a business involving valuing property, they used measuring wheels/long tape measures just to roughly check the land dimensions were about what was on the certificate of title. There was no requirement to be accurate - we are not talking surveying or exactitude. Frankly, if it was within 1/2 - 1 metre or so, that was good enough; presumably if it was a lot outside that (never yet happened), they'd query further.
Yet one little self-important and rigid auditor attempted to insist that these measures should be calibrated! Quite ridiculous. (And no, he didn't return. And the replacement - competent - auditor agreed with excluding it from scope.)
#37
Kind regards -John
I'll borrow one from Peter Drucker (iirc): There's nothing so wasteful as doing something well that doesn't need to be done at all.
Managers should be allowed a bit of latitude in discerning these things and shouldn't be bound by platitudes and obsessive-compulsive behaviors. "One test" isn't necessary to tell whether it's raining or not.
#38
I was reminded of this Jane. A globally known parcel carrier was written an NC for not having the delivery van maintenance techs 'feeler' gauges (used in engine maintenance) calibrated!!
bobdoering
#39
... roughly check ...no requirement to be accurate ...good enough
Great criteria for Quality Level TCE. More support to add it to the standard. The committee really missed this one.
#40
I'm assuming that this is sarcasm, so please correct me if I'm wrong. If you feel that "the committee" should be an omniscient body that can account for every contingency in the day-to-day operation of a business, or that the committee's wisdom should always prevail, you're probably right. Some of us think that our experience in the world should count for something, however, and that we shouldn't have to run to the book every time a decision is made.
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
John C. Abnet Must COPQ always be quantified as a monetary ($) amount? IATF 16949 - Automotive Quality Systems Standard 2
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
A Read instruction manual - What Graphic Symbol must I use? US Food and Drug Administration (FDA) 7
M What kind of instrument that must be calibrated? General Measurement Device and Calibration Topics 3
Q Must product name be listed the same name in FURLS, UDI, GUDID and Company Website? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Customer VDA Audit - We must provide refresher training? VDA Standards - Germany's Automotive Standards 4
J Any diverging opinions regarding audit findings or conclusions must be resolved no later than the closing meeting ISO 13485:2016 - Medical Device Quality Management Systems 13
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
M Which documents must be updated upon product validation? Document Control Systems, Procedures, Forms and Templates 1
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
T Must all Disposable Medical Devices be DEHP Free for MDR? EU Medical Device Regulations 1
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
P Quality objectives - must they include CAPA and internal audit topic? ISO 13485:2016 - Medical Device Quality Management Systems 28
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
I Is risk acceptability really needed if all risks must be reduced as far as possible? ISO 14971 - Medical Device Risk Management 6
A ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
N Must Bioburden Sampling Procedures be Documented? Other Medical Device Related Standards 5
M Contacting a "Must Use" (aka Sole Source) Supplier's Registrar Supplier Quality Assurance and other Supplier Issues 6
T Auditor states my Oven Thermocouples must be Calibrated General Measurement Device and Calibration Topics 18
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
B Must a Design Outsourcing Company have ISO13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
U Must every procedure be proceeded by a policy? Document Control Systems, Procedures, Forms and Templates 2
P Must all parts of a product be RoHS compliant? EU Medical Device Regulations 5
N Must electrodes for Rx/prescription stimulators be Rx only? Other US Medical Device Regulations 2
V Is there an approach to define the "must 'or' should" in supplier audits? US Food and Drug Administration (FDA) 2
F Electronic Signatures (21CFR Part 11) - Must They Appear on Printed Documents Document Control Systems, Procedures, Forms and Templates 9
R What are the "Must Have" Specs and Standards for AS9100 Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
L Must we do Receiving Inspection for everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
U Once upon a QMS - Is a Statement of Uncertainty a must for ISO 17025 accredited labs? ISO 17025 related Discussions 8
C Must we identify steps taken to identify the Root Cause of a failure Nonconformance and Corrective Action 15
Y Must every Process have a Quality Objective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
L Must the Signature on a Quality Record be Legible? Records and Data - Quality, Legal and Other Evidence 33
N Must Employees Be Evaluated Annually? Training - Internal, External, Online and Distance Learning 19
A Calibration system must meet ISO 10012, ISO 17025 or ANSI/NCSL Z540? ISO 17025 related Discussions 38
D How long must we provide service parts to Ford? IATF 16949 - Automotive Quality Systems Standard 7
E Must Patent Numbers be Shown on Product Labels? Other Medical Device and Orthopedic Related Topics 18
Ronen E FDA Must Have New Authorities to Regulate Pharmacy Compounding US Food and Drug Administration (FDA) 8
P Trip to the USA - Must-Eat Food? Holiday Planning Coffee Break and Water Cooler Discussions 57
Colin What QMS Internal Audits must cover and ISO 9001 Internal Auditing 19
R Is insulation between F type applied part and other parts a must? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
D Must Forms be referenced in applicable Procedures? Supplier Quality Assurance and other Supplier Issues 6
U Must We Audit Critical Suppliers? How often? Supplier Quality Assurance and other Supplier Issues 7
S Integrating a Multi-Management System - What documents & records must we have? Various Other Specifications, Standards, and related Requirements 6
R Risks which must be Distinctly Identified - Harm, Hazard, Severity ISO 14971 - Medical Device Risk Management 7
O ISO 9001 requirements for what Internal Audits must cover Internal Auditing 7
