Must chairs be grounded for ESD (electrostatic discharge)?
Bunny
We are in the process of improving our ESD workroom. We have ESD workbenches set up with continous monitors. We use sheilded lab coats. Soon we will be applying ESD floor wax so the workers can use foot straps instead of wrist straps (they find them too confining). Much of the assembly work is done on benches designed for the worker to be in a seated position. Here are my questions. Do they chairs need to be grounded even if the workers are instructed to keep both feet on the floor while sitting? Do the chairs need to be replaced with ESD protective chairs?
Re: Must chairs be grounded for ESD?
Why not use ESD floor mats instead of expecting people to sit with their feet on the floor all day?
(The link is not an endorsement)
CarolX
I know very little about ESD - but I think it is unrealistic to expect both feet to be kept on the floor all day. The ability to shift position throughout the day minimizes discomfort while sitting.
But if this is your requirement make sure there are no foot rests on the chairs or benches. People will place their feet on these things without even thinking about it.
I know it doesn't answer your question - sorry I couldn't help.
Bunny
So if we get floor mats, are the chairs OK left as they are?
blewispunk
If you have anything on the floor grounded (mats or otherwise) and are relying on that and the folks doing the work are seated then I recommend using grounded chairs (with the little chain that drags on the floor). Otherwise, you may not be making contact with the grounding system (I agree with Carol that it is not realistic to expect a seated person to always keep both feet on the floor).
Alternatively, you may consider using ESD workbench mats and/or wrist straps.
Bunny
We already use ESD workbenches and wrist straps. The workers do not want to wear the wrist straps because they complain they get in the way. I am trying to find an alternative solution otherwise, they won't comply at all.
Bunny
Are ESD mats needed on top of an ESD waxed floor?
Do the use of an ESD floor mat relieve you of the burden of wearing foot straps?
Will using a drag drain on the chair work on an ESD waxed floor?
jayquality
I have only 25 years experience in the electronics industry and gave training on esd do and don'ts in a previous position.
Much depends on how sensitive the products are, is it an internal requirement or a customer requirement?
Handling bare parts of assembled parts?
It's like the weakest link, if you miss one weak part it can go wrong, no matter how good some of your protection is.
For the 'ideal' setup:
- benches with grounded esd mats on top
- esd ground separate from mains ground
- use stranded flat cables instead of normal wire to wire up the esd chain
- hook up any metal parts of tooling
- esd shoes
- esd clothing
- wrist straps (maybe with continues monitoring)
- esd chairs (these have conductive cloth and wheels, some use a chain)
- conductive esd floor (use conductive epoxy floor, painted esd floors will deteriorate fast and are interrupted by cracks in the floor or expansion gaps)
- esd safe handling materials, trays, carts, bags and so on
- test stand for straps and shoes near punch clock, use a log
- regular inspection and testing of mats and floor
and most important, strict rules:
- taped off esd area with signs
- no-one without protection in the esd area, not even management
- no loose hanging hair, no brushing of hair
- no rolling up the sleeves and wollen sweater sleeves exposed for example
- no plastic cups (drinks) on desks
- pcb's inside an esd bag when moving, dont use the bag as glove
- beware of creeping things like caps from spray cans ending up as screw tray
- internal esd audits
- make sure the esd 'safety' chain is not broken, for example moving with product in hand from one bench to another
Sounds like a lot of overkill but this is what it 'should' be, i installed setups like these when we had customers like HP, IBM, Philips, Hitachi and so on.
Again, it depends on the product.
If you have a good concrete floor, that is good enough if you use wrist wraps.
If you want to use heal straps, always use 2 and still when seated, hook up with wrist wrap since not all workers have their feet on the floor (don't count on it).
Some will sell you plain cotton t-shirts in blue with esd logo printed on them as expensive esd shirts so beware.
Common sense is good.
Educating the workforce is a must, use staic generators and meter to show difference between types of bags, cloths and so on.
N Must PFMEA Occurrence Factor be Changed Periodically? FMEA and Control Plans 17
H Does this clause mean i must be in compliance with AS9100 or is 9001 enough? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Does ISO state in anyway that we MUST keep physical first piece parts? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Y Must Initial importers have any QMS? US Food and Drug Administration (FDA) 1
S How long the QMS must be maintained after device EOL? ISO 13485:2016 - Medical Device Quality Management Systems 6
W Must VDA 6.3 be assigned to certain project? VDA Standards - Germany's Automotive Standards 0
M Must a company be 17025 accredited to perform internal calibrations? ISO 17025 related Discussions 10
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
John C. Abnet Must COPQ always be quantified as a monetary ($) amount? IATF 16949 - Automotive Quality Systems Standard 2
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
A Read instruction manual - What Graphic Symbol must I use? US Food and Drug Administration (FDA) 7
M What kind of instrument that must be calibrated? General Measurement Device and Calibration Topics 3
Q Must product name be listed the same name in FURLS, UDI, GUDID and Company Website? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Customer VDA Audit - We must provide refresher training? VDA Standards - Germany's Automotive Standards 4
J Any diverging opinions regarding audit findings or conclusions must be resolved no later than the closing meeting ISO 13485:2016 - Medical Device Quality Management Systems 13
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
M Which documents must be updated upon product validation? Document Control Systems, Procedures, Forms and Templates 1
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
T Must all Disposable Medical Devices be DEHP Free for MDR? EU Medical Device Regulations 1
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 9
P Quality objectives - must they include CAPA and internal audit topic? ISO 13485:2016 - Medical Device Quality Management Systems 28
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
I Is risk acceptability really needed if all risks must be reduced as far as possible? ISO 14971 - Medical Device Risk Management 6
armani ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
N Must Bioburden Sampling Procedures be Documented? Other Medical Device Related Standards 5
M Contacting a "Must Use" (aka Sole Source) Supplier's Registrar Supplier Quality Assurance and other Supplier Issues 6
T Auditor states my Oven Thermocouples must be Calibrated General Measurement Device and Calibration Topics 18
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
B Must a Design Outsourcing Company have ISO13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
U Must every procedure be proceeded by a policy? Document Control Systems, Procedures, Forms and Templates 2
P Must all parts of a product be RoHS compliant? EU Medical Device Regulations 5
N Must electrodes for Rx/prescription stimulators be Rx only? Other US Medical Device Regulations 2
V Is there an approach to define the "must 'or' should" in supplier audits? US Food and Drug Administration (FDA) 2
F Electronic Signatures (21CFR Part 11) - Must They Appear on Printed Documents Document Control Systems, Procedures, Forms and Templates 9
R What are the "Must Have" Specs and Standards for AS9100 Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
L Must we do Receiving Inspection for everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
U Once upon a QMS - Is a Statement of Uncertainty a must for ISO 17025 accredited labs? ISO 17025 related Discussions 8
C Must we identify steps taken to identify the Root Cause of a failure Nonconformance and Corrective Action 15
Y Must every Process have a Quality Objective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
leftoverture Must the Signature on a Quality Record be Legible? Records and Data - Quality, Legal and Other Evidence 33
N Must Employees Be Evaluated Annually? Training - Internal, External, Online and Distance Learning 19
A Calibration system must meet ISO 10012, ISO 17025 or ANSI/NCSL Z540? ISO 17025 related Discussions 38
D How long must we provide service parts to Ford? IATF 16949 - Automotive Quality Systems Standard 7
E Must Patent Numbers be Shown on Product Labels? Other Medical Device and Orthopedic Related Topics 18
Ronen E FDA Must Have New Authorities to Regulate Pharmacy Compounding US Food and Drug Administration (FDA) 8
P Trip to the USA - Must-Eat Food? Holiday Planning Coffee Break and Water Cooler Discussions 57
