Must every Process have a Quality Objective?
Y
yoosuf
Dear Covers,
Clause# 5.4.1 of ISO 9001:2008 requires that Top management shall ensure that quality objectives, including those needed to meet requirements for product, are established at relevant functions and levels within the organization. The quality objectives shall be measurable and consistent with the quality policy.
Does this mean that each and every process ( core and support processes) should have quality objective(s) ?
Yoosuf
somashekar
Re: Quality Objectives
Hi Yoosuf.
The standard sets directions, and does not dictate what has to be done.
So it is necessary that the organization determines and decides which are those core / support process, where a quality objective when set and measured and found meeting the objective, helps the organization to progress towards meeting the quality policy.
In simple terms if you have to be into office at or before 9am per the company policy, then your objective may be to start from your home at 8am, while the objective of your colleague could be to start around 8:45am. These objectives are dependent upon your distance, traffic and mode of transport.
John Broomfield
Yoosuf,
No. Think more in terms of what top management requires from their management system in context with their quality policy.
Then help TM to explain their objectives to the employees and those who are responsible for resourcing, monitoring, reporting and invoking the necessary preventive action to ensure the quality objectives are achieved.
Clause 8.4 lists useful topics for quality objectives.
As to process objectives take a look at clause 4.1c.
John
Big Jim
The short answer is no, but there is more to it.
You are correct in recognizing that relevant functions and levels are specified in 5.4.1. Just what those levels and functions are isn't defined so for the most part the organization gets to make that determination.
There is an additional term that is becoming more and more prevalent in the ISO 9001 world, even though it isn't specifically in the standard. That term is Key Performance Indicators (KPI). Although the term is not there, the spirit of it strongly is. Strongly enough that KPI is part of what auditors are being trained to look for when auditing. AS9100 auditors are driven to looking for KPI (and/or other things) when filling out the PEAR (Process Effectiveness assessment Report). Some Certification Bodies Workbooks for ISO 9001 have a KPI chart that covers similar ground for auditors to complete.
The basis for KPI being tied to ISO 9001 is from several places in the standard. In 4.1, organizations need to determine what their processes are, how they function, how they relate to each other, the criteria and methods to make sure they are effective, and how to monitor (and where applicable, measure) them.
You are already familiar with 5.4.1 about the relevant functions and levels. There seems to be an attitude that this would be applied to your core business processes.
8.2.3 gets very specific in that it tells you to monitor (and where applicable, measure) your processes.
There also seems to be an attitude that monitoring only without measuring is a rare exception.
Then as an earlier poster noted, 8.4 provides some insight to the types of things to measure. There are four topics that must be addressed. How and if you apply them to your core processes isn't specified. It is not uncommon to create quality objectives that also double as KPI and also fulfill the requirements for 8.4.
Cutting to the chase, what auditors are trained to look for then is some sort of performance data that tells you the health of each of your core business processes.
There is nothing that prevents you from using the same indicator for more than one process. If you have four quality objectives that are based on the required topics for 8.4, you could determine which ones of the four apply to each of your core business processes.
For example, a quality objective/KPI for purchasing might be 8.4 d supplier performance. A quality objective/KPI for manufacturing might be 8.4 b product quality and 8.4 c which is often tracked as on-time delivery. I think you can get the picture.
I realize that this response may raise the eyebrows of some here, but I'm only reporting on what I see.
So the long answer might be more like the Jacques Cousteau universal response of yes/no.
JaneB
No. Choose the ones that make sense in your organisation.
Avoid the mistake of attempting to set them for processes that are already concerened with measurement/improvement (eg, there's little point in setting metrics /KPIs for the internal audit process for example).
K
kgott
Dear Covers,
Yoosuf
Think of it this way Yoosuf. One could argue that the purpose of document control is to ensure that the most up to date information is in the right place at the right time.
You could write that into your 'objectives at lower levels .. ' i.e. into your document control procedure.
The next step is ask what data and from where do we get it, do we need to collect to measure the effectiveness of our document control process.
rickpaul01
Involved in HankyPanky
Big Jim is spot on. But some auditors will disagree with this statment. "There is nothing that prevents you from using the same indicator for more than one process."
They would argue that each process will have its own KPI.
JaneB
You could. But is it really going to be valuable to do this for document control? I very much doubt it.
x-files
Should every procedure have a KPI? What if the auditor asks "How do you measure your process?" or "What are your KPIs for the process?" or "Where are the objective evidences that you measured the process performances (black on white)?"
What KPIs from the procedure are to be shaped and promoted to Objectives?
I saw many sample procedures which mandatory table of contents structure provides "Process monitoring and measurement methods".
We have "Document control" procedure (and many others) in which we measure nothing.
For example (DCP is just example) we can measure number of requests per month, and time from receipt and closing a DC request form.
Further there are two problems in this particular (imaginary about DCP) scenario:
1. We do not have any problems with Document Control process, that's why we are not measuring it, ie recording times diffs etc
2. We'll mix apples and oranges when forming a KPI, if we try to summarize number of requests. We'd rather want to find out what department is lazy to improve it's process by periodically revising the procedures. When I join all numbers into one number, than I haven't got a real KPI, I just got something to satisfy the auditor. On the other hand, not all months in a year are the same, so sometimes we could collect fake information about laziness. In fact vacation was the cause of absence of requests. With all that said, we must provide pretty complex analysis and methodology to calculate KPI.
My question is where is that methodology (event if the methodology is complex as A/B) supposed to be documented? I assume it's 8.4 point of ISO 9001:
a) in the procedure itself, in the appropriate section
b) in a separate procedure, which is a placeholder for all potential methodologies
c) something other
Other question related to this /process monitoring section from a procedure found on internet/:
Process Objective(s): Control QMS documents in an efficient and effective manner that meets ISO requirements
Information or Data Collected: Number of document changes requested per month and average processing time
Review/Report Cycle: QMS Audits; Management Review
Should the process owner of DCP have a special intermediate document where he made a calculation about "Number of document changes requested per month", before he embeds that information into Management Review report?
Best Regards,
Vladimir Stefanovic
Mikishots
Dear Covers,
Yoosuf
No, it simply means that a decision needs to be made as to which processes need objectives set. If they are set, they need to align with the policy and business objectives of the organization as well.
U Must every procedure be proceeded by a policy? Document Control Systems, Procedures, Forms and Templates 2
K Must every CCP (Critical Control Point) have a (documented) procedure? Food Safety - ISO 22000, HACCP (21 CFR 120) 4
N Must you Sign on every Page of A Calibration Report General Measurement Device and Calibration Topics 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
John C. Abnet Must COPQ always be quantified as a monetary ($) amount? IATF 16949 - Automotive Quality Systems Standard 2
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
A Read instruction manual - What Graphic Symbol must I use? US Food and Drug Administration (FDA) 7
M What kind of instrument that must be calibrated? General Measurement Device and Calibration Topics 3
Q Must product name be listed the same name in FURLS, UDI, GUDID and Company Website? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Customer VDA Audit - We must provide refresher training? VDA Standards - Germany's Automotive Standards 4
J Any diverging opinions regarding audit findings or conclusions must be resolved no later than the closing meeting ISO 13485:2016 - Medical Device Quality Management Systems 13
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
M Which documents must be updated upon product validation? Document Control Systems, Procedures, Forms and Templates 1
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
T Must all Disposable Medical Devices be DEHP Free for MDR? EU Medical Device Regulations 1
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
P Quality objectives - must they include CAPA and internal audit topic? ISO 13485:2016 - Medical Device Quality Management Systems 28
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
I Is risk acceptability really needed if all risks must be reduced as far as possible? ISO 14971 - Medical Device Risk Management 6
A ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
N Must Bioburden Sampling Procedures be Documented? Other Medical Device Related Standards 5
M Contacting a "Must Use" (aka Sole Source) Supplier's Registrar Supplier Quality Assurance and other Supplier Issues 6
T Auditor states my Oven Thermocouples must be Calibrated General Measurement Device and Calibration Topics 18
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
B Must a Design Outsourcing Company have ISO13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
P Must all parts of a product be RoHS compliant? EU Medical Device Regulations 5
N Must electrodes for Rx/prescription stimulators be Rx only? Other US Medical Device Regulations 2
V Is there an approach to define the "must 'or' should" in supplier audits? US Food and Drug Administration (FDA) 2
F Electronic Signatures (21CFR Part 11) - Must They Appear on Printed Documents Document Control Systems, Procedures, Forms and Templates 9
R What are the "Must Have" Specs and Standards for AS9100 Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
L Must we do Receiving Inspection for everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
U Once upon a QMS - Is a Statement of Uncertainty a must for ISO 17025 accredited labs? ISO 17025 related Discussions 8
C Must we identify steps taken to identify the Root Cause of a failure Nonconformance and Corrective Action 15
L Must the Signature on a Quality Record be Legible? Records and Data - Quality, Legal and Other Evidence 33
N Must Employees Be Evaluated Annually? Training - Internal, External, Online and Distance Learning 19
A Calibration system must meet ISO 10012, ISO 17025 or ANSI/NCSL Z540? ISO 17025 related Discussions 38
D How long must we provide service parts to Ford? IATF 16949 - Automotive Quality Systems Standard 7
E Must Patent Numbers be Shown on Product Labels? Other Medical Device and Orthopedic Related Topics 18
Ronen E FDA Must Have New Authorities to Regulate Pharmacy Compounding US Food and Drug Administration (FDA) 8
P Trip to the USA - Must-Eat Food? Holiday Planning Coffee Break and Water Cooler Discussions 57
Colin What QMS Internal Audits must cover and ISO 9001 Internal Auditing 19
R Is insulation between F type applied part and other parts a must? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
D Must Forms be referenced in applicable Procedures? Supplier Quality Assurance and other Supplier Issues 6
U Must We Audit Critical Suppliers? How often? Supplier Quality Assurance and other Supplier Issues 7
S Integrating a Multi-Management System - What documents & records must we have? Various Other Specifications, Standards, and related Requirements 6
R Risks which must be Distinctly Identified - Harm, Hazard, Severity ISO 14971 - Medical Device Risk Management 7
