Must every Process have a Quality Objective?
JJC1979
#11
Should every procedure have a KPI? What if the auditor asks "How do you measure your process?" or "What are your KPIs for the process?" or "Where are the objective evidences that you measured the process performances (black on white)?"
What KPIs from the procedure are to be shaped and promoted to Objectives?
I saw many sample procedures which mandatory table of contents structure provides "Process monitoring and measurement methods".
We have "Document control" procedure (and many others) in which we measure nothing.
For example (DCP is just example) we can measure number of requests per month, and time from receipt and closing a DC request form.
Further there are two problems in this particular (imaginary about DCP) scenario:
1. We do not have any problems with Document Control process, that's why we are not measuring it, ie recording times diffs etc
2. We'll mix apples and oranges when forming a KPI, if we try to summarize number of requests. We'd rather want to find out what department is lazy to improve it's process by periodically revising the procedures. When I join all numbers into one number, than I haven't got a real KPI, I just got something to satisfy the auditor. On the other hand, not all months in a year are the same, so sometimes we could collect fake information about laziness. In fact vacation was the cause of absence of requests. With all that said, we must provide pretty complex analysis and methodology to calculate KPI.
My question is where is that methodology (event if the methodology is complex as A/B) supposed to be documented? I assume it's 8.4 point of ISO 9001:
a) in the procedure itself, in the appropriate section
b) in a separate procedure, which is a placeholder for all potential methodologies
c) something other
Other question related to this /process monitoring section from a procedure found on internet/:
Process Objective(s): Control QMS documents in an efficient and effective manner that meets ISO requirements
Information or Data Collected: Number of document changes requested per month and average processing time
Review/Report Cycle: QMS Audits; Management Review
Should the process owner of DCP have a special intermediate document where he made a calculation about "Number of document changes requested per month", before he embeds that information into Management Review report?
Best Regards,
Vladimir Stefanovic
Vladimir~
Every process does not need to have a KPI. Only use KPIs to truly measure something that you want to measure (Customer Complaint Closure, for example). Something that is tied back to the product that you supply, is what I normally use as a rule of thumb. First Pass Yield percentage, CAPA closure, etc...those all tie back to the product/service or the service of the product/service.
Also don't make up KPIs that tell you nothing. If the thought is, "so what", the odds are, it is not the most ideal KPI and it will mean nothing to the Management team.
Those are my two cents:)
JJC1979
#12
I say that every process will have objectives. Not because they are mandated by any standard, but because they are mandated by necessity. The question is: "How does the process owner the process is working?" Each process will have some sort of goal or objective, even if it is informal. And tracking them may very well be informal as well. If I can't seem to find the right employee, then perhaps my hiring process is not working properly. The same holds true for late shipments or quality issues. Quality goals and late shipments may be formal and we may keep pretty good records of those, but the hiring goals... not so much. We may not even be able to agree on what we will be measuring for hiring goals.
If an organization has pain, one of their processes are not working right. We base "working right" on our objectives. Not meeting the objectives results in pain.
Now, let's throw the standard back into the mix. Now, we have a different type of pain. 4.2.1a requires objectives to be documented. So much for those informal goals. What we document, we really need to track. Now, how formal does that have to be? So what do we do? Those important goals, we document and track. Those informal goals are still there, but now they are kept and monitored in secret. So we formally track on-time shipping and quality metrics, but nothing is kept on percent of new hires who successfully make completely through the process and become regular employees.
LUV-d-4UM
#13
Thank you Big Jim. I found it difficult to audit the effectiveness because most of the processes do not have key performance indicators. Do I give the process a nonconformance against 8.1.1 or 5.4 ?
Big Jim
#14
8.2.3 would be the most likely fit, monitoring and measurement of processes.
JaneB
#16
Yes, of course every process has at least one objective - what it intends to achieve. (Otherwise, why do it?). But not every process requires measurement.
You measure processes where it's valuable to do so and where the results of that measuring will be useful. I'd certainly be measuring whether services to clients (for example) are being delivered on time, whether they met the requirements and whether clients were satisfied with them. All of those are going to yield useful data.
But I would not measure, say, the process for controlling documents or the internal audit process, because measurements there aren't useful. Monitor, yes. Measure, no.
x-files
#17
[...] Monitor, yes. Measure, no.
Sorry for this very basic question. What is the core difference between monitoring and measurement, in context of process?
Is monitoring the informal way to track/watch something?
Is measurement formalized/shaped monitoring?
Reading the (8.2.3.), monitoring includes the word "suitable methods". If the auditor asks "How do you monitor Document control process?", what should I say or show? (employees never complained about the process, internal audits never detected nonconformance...)
Best regards,
Vladimir Stefanovic
JaneB
#19
Nothing to apologise for. Ask away - someone will answer.
Measuring implies something that involves gathering "hard" or specific data, such as temperature, variation, dollars, time to mention a few. For example, if onetime delivery was important for a particular process or system, then you'd expect to measure your deliveries, whether they're on time, and if not, how much they're outside acceptable time, etc.
Whereas monitoring, as you suggested, is less formal, and includes activities such as observing, watching, 'walking around', "keeping an eye on things", etc. it might also involve noting the absence of indicators of problems or failures.
So with document control ( for example), I'd be more inclined to monitor it rather than measure it. Keep an eye out for indicators, such as a lot of references to problems with it from sources such as audits, user feedback, etc. Unless it's a critical element in a system - electronic drawings produced in an architectural practice for example.
In the Standard, you'll notice that it refers to both activities, but they are not interchangeable (although some people refer to them as though they were). Measurement is usually more time-consuming and expensive to do than monitoring.
Mikishots
#20
Dear Covers,
Clause# 5.4.1 of ISO 9001:2008 requires that Top management shall ensure that quality objectives, including those needed to meet requirements for product, are established at relevant functions and levels within the organization. The quality objectives shall be measurable and consistent with the quality policy.
Does this mean that each and every process ( core and support processes) should have quality objective(s) ?
Yoosuf
I don't see why not. Every process has a reason for existing, and every process would have an expected outcome (otherwise, why even bother with it?).
U Must every procedure be proceeded by a policy? Document Control Systems, Procedures, Forms and Templates 2
K Must every CCP (Critical Control Point) have a (documented) procedure? Food Safety - ISO 22000, HACCP (21 CFR 120) 4
N Must you Sign on every Page of A Calibration Report General Measurement Device and Calibration Topics 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
John C. Abnet Must COPQ always be quantified as a monetary ($) amount? IATF 16949 - Automotive Quality Systems Standard 2
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
A Read instruction manual - What Graphic Symbol must I use? US Food and Drug Administration (FDA) 7
M What kind of instrument that must be calibrated? General Measurement Device and Calibration Topics 3
Q Must product name be listed the same name in FURLS, UDI, GUDID and Company Website? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Customer VDA Audit - We must provide refresher training? VDA Standards - Germany's Automotive Standards 4
J Any diverging opinions regarding audit findings or conclusions must be resolved no later than the closing meeting ISO 13485:2016 - Medical Device Quality Management Systems 13
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
M Which documents must be updated upon product validation? Document Control Systems, Procedures, Forms and Templates 1
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
T Must all Disposable Medical Devices be DEHP Free for MDR? EU Medical Device Regulations 1
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
P Quality objectives - must they include CAPA and internal audit topic? ISO 13485:2016 - Medical Device Quality Management Systems 28
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
I Is risk acceptability really needed if all risks must be reduced as far as possible? ISO 14971 - Medical Device Risk Management 6
A ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
N Must Bioburden Sampling Procedures be Documented? Other Medical Device Related Standards 5
M Contacting a "Must Use" (aka Sole Source) Supplier's Registrar Supplier Quality Assurance and other Supplier Issues 6
T Auditor states my Oven Thermocouples must be Calibrated General Measurement Device and Calibration Topics 18
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
B Must a Design Outsourcing Company have ISO13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
P Must all parts of a product be RoHS compliant? EU Medical Device Regulations 5
N Must electrodes for Rx/prescription stimulators be Rx only? Other US Medical Device Regulations 2
V Is there an approach to define the "must 'or' should" in supplier audits? US Food and Drug Administration (FDA) 2
F Electronic Signatures (21CFR Part 11) - Must They Appear on Printed Documents Document Control Systems, Procedures, Forms and Templates 9
R What are the "Must Have" Specs and Standards for AS9100 Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
L Must we do Receiving Inspection for everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
U Once upon a QMS - Is a Statement of Uncertainty a must for ISO 17025 accredited labs? ISO 17025 related Discussions 8
C Must we identify steps taken to identify the Root Cause of a failure Nonconformance and Corrective Action 15
L Must the Signature on a Quality Record be Legible? Records and Data - Quality, Legal and Other Evidence 33
N Must Employees Be Evaluated Annually? Training - Internal, External, Online and Distance Learning 19
A Calibration system must meet ISO 10012, ISO 17025 or ANSI/NCSL Z540? ISO 17025 related Discussions 38
D How long must we provide service parts to Ford? IATF 16949 - Automotive Quality Systems Standard 7
E Must Patent Numbers be Shown on Product Labels? Other Medical Device and Orthopedic Related Topics 18
Ronen E FDA Must Have New Authorities to Regulate Pharmacy Compounding US Food and Drug Administration (FDA) 8
P Trip to the USA - Must-Eat Food? Holiday Planning Coffee Break and Water Cooler Discussions 57
Colin What QMS Internal Audits must cover and ISO 9001 Internal Auditing 19
R Is insulation between F type applied part and other parts a must? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
D Must Forms be referenced in applicable Procedures? Supplier Quality Assurance and other Supplier Issues 6
U Must We Audit Critical Suppliers? How often? Supplier Quality Assurance and other Supplier Issues 7
S Integrating a Multi-Management System - What documents & records must we have? Various Other Specifications, Standards, and related Requirements 6
R Risks which must be Distinctly Identified - Harm, Hazard, Severity ISO 14971 - Medical Device Risk Management 7
