Must PFMEA Occurrence Factor be Changed Periodically?
John C. Abnet
Teacher, sensei, kennari
Is it a must to change the occurrence rate regularly? example every month?
Good day @NPD-PFMEA .
No. The occurrence rate should be established by data / information reflecting actual conditions.
The occurrence rate (once accurately established) would not be expected to change until changes to the process are made (which then should trigger a review / update of the PFMEA).
Hope this helps.
Be well.
There were no process changes. But there is monthly change of occurrence, that causes occurrence rate ranking changes every month. is there a rule to revise it regularly?
Occurrence rate is being established based on monthly result of production. Result changes depending in the process reject occurrence and total qunatity. Rating can go from 1 to 3.
Ron Rompen
NPD: Your initial occurrence rate should be determined by previous history of similar parts and processes, and so it shows an ANTICIPATED occurrence rate.
During your PFMEA reviews you can revise the occurrence rate if there is a valid reason (i.e. data) to support it. There is no strict rule that I am aware of which specifies a frequency for review and revision (although many people, particularly auditors like to say annually); you need to determine that frequency for yourself and your company.
I asked how the occurrence factor was originally established. Is the number of occurrences you're seeing changing anything that you're doing with regard to corrective action or acting on the process?
Tidge
Historically, commonly....
  • FMEA ratings are ordinal values that are only crudely related via orders of magnitude (usually I've seen "powers of ten" invoked on a scale of 1-5, but I have seen at least one set of docs scaled 1-10 that was more like "powers of 3"... I think the powers-of-3 docs had some ham radio folks developing those).
Post-control ratings typically only change when
  • A process changes, typically to improve an RPN
  • Something is discovered about the ratings (possibly pre-control ratings as well) that causes a re-assessment of the rating, typically "uh-oh" that makes an RPN worse than initially assessed.
Since the OP is implying monitoring of production output, if the rate of occurrences (of what? Maybe failure modes itself?) is consistent with the post-controls ratings I don't know why you would re-litigate any lines of a PFMEA, as observed consistency with the predicted results of process is probably not worth spending effort on.
I can imagine all sorts of circumstances in which a process exceeds expectations (usually this happens when expectations were abnormally low) but even then I wouldn't be tempted to go back and update FMEA lines... unless of course there was some personal reward... do I get a bonus for reducing RPN ratings in certain FMEA? Is this a notch on a six-sigma belt? I think it's more important to evaluate FMEA lines when the occurrence rates of failure modes are exceeding the post-control ratings. The ratings could have been a (incorrect) WAG, or the controls may be ineffective.
If a PFMEA is created and effectively implemented through appropriately derived controls (the Control plan) shouldnt the occurrence go down? Why would anyone need to plan to adjust the PFMEA? A PFMEA doesn't exist in a vacuum, Unless you created it in one…
Tidge
My assumption is that the ratings (as monitored by an established control plan) being checked during production are the post-control ratings, not just implemented but also verified. If controls weren't implemented and appropriately verified (typically during a process validation), I wouldn't be quick to align a perceived improve in ratings with new and improved ratings on the post-controls side of the worksheet. blah blah correlation blah blah not causation.
C PFMEA RPN rankings - Preventative action must be opened if RPN over 100 ISO 14971 - Medical Device Risk Management 9
M Connection between DFMEA and PFMEA - What must be transferred to the PFMEA? FMEA and Control Plans 9
H Does this clause mean i must be in compliance with AS9100 or is 9001 enough? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Does ISO state in anyway that we MUST keep physical first piece parts? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Y Must Initial importers have any QMS? US Food and Drug Administration (FDA) 1
S How long the QMS must be maintained after device EOL? ISO 13485:2016 - Medical Device Quality Management Systems 6
W Must VDA 6.3 be assigned to certain project? VDA Standards - Germany's Automotive Standards 0
M Must a company be 17025 accredited to perform internal calibrations? ISO 17025 related Discussions 10
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
John C. Abnet Must COPQ always be quantified as a monetary ($) amount? IATF 16949 - Automotive Quality Systems Standard 2
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
A Read instruction manual - What Graphic Symbol must I use? US Food and Drug Administration (FDA) 7
M What kind of instrument that must be calibrated? General Measurement Device and Calibration Topics 3
Q Must product name be listed the same name in FURLS, UDI, GUDID and Company Website? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Customer VDA Audit - We must provide refresher training? VDA Standards - Germany's Automotive Standards 4
J Any diverging opinions regarding audit findings or conclusions must be resolved no later than the closing meeting ISO 13485:2016 - Medical Device Quality Management Systems 13
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
M Which documents must be updated upon product validation? Document Control Systems, Procedures, Forms and Templates 1
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
T Must all Disposable Medical Devices be DEHP Free for MDR? EU Medical Device Regulations 1
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 9
P Quality objectives - must they include CAPA and internal audit topic? ISO 13485:2016 - Medical Device Quality Management Systems 28
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
I Is risk acceptability really needed if all risks must be reduced as far as possible? ISO 14971 - Medical Device Risk Management 6
armani ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
N Must Bioburden Sampling Procedures be Documented? Other Medical Device Related Standards 5
M Contacting a "Must Use" (aka Sole Source) Supplier's Registrar Supplier Quality Assurance and other Supplier Issues 6
T Auditor states my Oven Thermocouples must be Calibrated General Measurement Device and Calibration Topics 18
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
B Must a Design Outsourcing Company have ISO13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
U Must every procedure be proceeded by a policy? Document Control Systems, Procedures, Forms and Templates 2
P Must all parts of a product be RoHS compliant? EU Medical Device Regulations 5
N Must electrodes for Rx/prescription stimulators be Rx only? Other US Medical Device Regulations 2
V Is there an approach to define the "must 'or' should" in supplier audits? US Food and Drug Administration (FDA) 2
F Electronic Signatures (21CFR Part 11) - Must They Appear on Printed Documents Document Control Systems, Procedures, Forms and Templates 9
R What are the "Must Have" Specs and Standards for AS9100 Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
L Must we do Receiving Inspection for everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
U Once upon a QMS - Is a Statement of Uncertainty a must for ISO 17025 accredited labs? ISO 17025 related Discussions 8
C Must we identify steps taken to identify the Root Cause of a failure Nonconformance and Corrective Action 15
Y Must every Process have a Quality Objective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
leftoverture Must the Signature on a Quality Record be Legible? Records and Data - Quality, Legal and Other Evidence 33
N Must Employees Be Evaluated Annually? Training - Internal, External, Online and Distance Learning 19
A Calibration system must meet ISO 10012, ISO 17025 or ANSI/NCSL Z540? ISO 17025 related Discussions 38
D How long must we provide service parts to Ford? IATF 16949 - Automotive Quality Systems Standard 7
E Must Patent Numbers be Shown on Product Labels? Other Medical Device and Orthopedic Related Topics 18
Ronen E FDA Must Have New Authorities to Regulate Pharmacy Compounding US Food and Drug Administration (FDA) 8
