"N" and "C" diamond rockwell brales - Does anyone know how these are made?
dbulak
We use an "N" and "C" diamond rockwell brales. Does anyone know how these are made? Someone here says the diamond point is glued in. I called the sales department where we buy them and they were not sure. I have to call back and talk with their techs. Just thought someone would know the answer.
Wes Bucey Closing in on my Diamond Jubilee Covegratulations 0
D ASTM E-18 Annex A3 - Ball and Diamond Indenters Requirements General Measurement Device and Calibration Topics 9
R Diamond Shaped Pins for Molded Plastic parts Various Other Specifications, Standards, and related Requirements 4
R Experience with the diamond shaped go-no/go pins - Question for all General Measurement Device and Calibration Topics 7
N Control Method - Diamond Drill Machining Operation Statistical Analysis Tools, Techniques and SPC 10
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
Q Heat Treat Steel, Rockwell C - Variability in Complex Machined Shapes Manufacturing and Related Processes 7
L Hardness Testing - Rockwell 15T Scale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Geoff Cotton Measurement Uncertainty (MU) of HR-150A Rockwell Hardness Tester Measurement Uncertainty (MU) 1
Q Definition Rockwell Hardness definitions - BW 96 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
Ron Rompen Recommended Rockwell 30T Scale Hardness Tester to verify Incoming Product General Measurement Device and Calibration Topics 1
J Rockwell Hardness Testing Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
J Hardness Inspection Test - Rockwell in Lieu of Brinell General Measurement Device and Calibration Topics 6
A Difficulties in performing MSA on Rockwell Hardness Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
A Calibration of Rockwell Hardness Tester IATF 16949 - Automotive Quality Systems Standard 10
K Rockwell Hardness Testers ? Brand Recommendation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Expiration Date for Standardized Rockwell Hardness Blocks Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J How to calibrate Hardness Rockwell, Brinnell & Vickers Tester machine General Measurement Device and Calibration Topics 5
B Portable hardness testing recommendations - Upper Rockwell B scale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
D ASTM E-18 - We test our rockwell tester using calibrated test blocks General Measurement Device and Calibration Topics 3
P Rockwell, Brinell, Vickers Conversion - Evaluating Aluminum 6061-T6 and 6063-T6 General Measurement Device and Calibration Topics 11
M Hardness Testing - Rockwell C, on 2" OD x 1" ID Tube of SAE 4140 steel Manufacturing and Related Processes 9
D Rockwell "B" test block - Space between indentions - Standard "Wilson" B Test Block General Measurement Device and Calibration Topics 19
K Gage R&R - Rockwell Scale - Hardness using Standard Test blocks Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Rockwell (Honeywell) example manual of ISO 9001 and ISO 14001 combined Quality Management System (QMS) Manuals 5
D Chart - How high the Rockwell Hardness increase after material has been edgerolled? Manufacturing and Related Processes 3
K MSA - Hardness Measurements (Rockwell/ Brinnel / Knoop / Vickers) - How to? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D Rockwell hardness tester - Required Enviromental Conditions General Measurement Device and Calibration Topics 3
S Question About Rockwell Verification Blocks - Testing on the back side of the block General Measurement Device and Calibration Topics 10
D Rockwell vs. Vickers vs. Knoop - Does Thickness Determine the Proper Test? General Measurement Device and Calibration Topics 1
B Additional Calibration needed for C-Frame Rockwell Hardness Tester? General Measurement Device and Calibration Topics 2
S Rockwell Force Testing vs. ASTM E-18 (02 version) General Measurement Device and Calibration Topics 6
