NADCAP AC 7108 - Subcontractor Laboratory Certification
O
omartinez
There is a requirement in NADCAP Check list audit AC7108 for sub contractors that carrying out analysis and testing in support of processes.
1.2 Companies carrying out analysis and testing in support of processes to AC7108 must be accredited to AC7108 for the scope of analysis and testing carried out. Should a processor use a sub-contract laboratory for some or all of the analysis and testing in support of their AC7108 accreditation as of (1 year issue of AC7108 Rev C) that subcontract laboratory must be Nadcap accredited for AC 7101 (MTL), accredited by a registration body recognized by MTL, accredited by CP to AC7108/4 or AC7108 for the scope of analysis and testing performed, or approved by Prime customer(s) for laboratory analysis (see AC7108 para 3.5.2)..
3.5.2
Are all solution analysis and process control testing sources approved in
accordance with an internal supplier procedure meeting all contractual
requirements ?
? Compliance Assessment Guidance: NA applies if no subcontract analysis
or testing is done.
? For jobs audited, outside laboratory testing is performed by a laboratory
that is approved to prime customer requirements. If no prime requirement
then one of the following must be met:
a) Any Prime customer laboratory approval (scope does not need to
match).
b) MTL accreditation or any MTL recognized approval (scope does not
need to match).
c) AC 7108/4 or AC 7108 accreditation (scope does need to match).
Im using a sub conttactor for Water analysis. Chloride determination in natural water and treated wastewater , Determination of electrolytic , Determination of metals by atomic absorption in natural
My lab is ISO IEC 17025 certified and ema ( mexican acreditation bodie certifies ) My question is , with certificaction , do I am meeting the Nadcap requirement AC 7108 ?
Thank you for yur help amigos
Charlie947
Hello Omartinez. This is actually my first post here on the cove so Hello Everyone.
I'm not an expert on Nadcap but I do have quite some experience with their type of audits. Could you clarify a few things to see if maybe I can help.
Is the Laboratory you are referring to used only for the analysis of the waste treatment water?
Is the water you are treating be re-use in the chemical process lines or will it be disposed?
O
omartinez
Thanks for your help Charlie947
Yes the test is for waste treatment water.
And the water will be disposed.
Im still concert if with ISO IEC 17025 I meet this requirement.
"subcontract laboratory must be Nadcap accredited for AC 7101 (MTL), accredited by a registration body recognized by MTL, accredited by CP to AC7108/4 or AC7108 for the scope of analysis and testing performed "
Thank you
Charlie947
Omartinez, thank you for the information.
The reason I asked you about the usage/purpose of the water is because AC7108 Para. 1.2 & 3.5.2 is referring to laboratories that are used to analyze the solutions of the actual process and not waste water. I'm not sure which processes do you have but as an example if you have copper plating or cadmium plating and you send out samples of these solutions to analyzed the concentration, then the requirements of AC7108 applies but not if the only use of the laboratory is to analyze waste water. In any case though, ISO 17025 is a recognized standard and is acceptable as a registration body, which does meet the requirements of the AC7108. If you need more help or have any other question, I'll be happy to help. By the way, I also speak Spanish.
Hershal
Metrologist-Auditor
omartinez, in general I agree with Charlie947, in that since your lab is EMA accredited, you likely meet the requirements. However, NADCAP requirements may be their own doing, so a point-to-point comparison may be necessary for them.
One other point. EMA is an ILAC Signatory accrediting body (AB), where NADCAP is a 2nd party auditor. It is an important distinction. NADCAP "accreditation" is not recognized by anyone but themselves and Boeing so far as I know. No ILAC AB on the planet accepts their recognition (which in truth is the correct term for their "accreditation") as equivalent to their own. However, EMA will so accept accreditation from an ILAC AB as equivalent just as other ILAC ABs accept EMA.
O
omartinez
Guys thank you so much Charlie947 , Hershal
I really appreciate your help ! just want to make sure EMA and ISO 17025 are good for Nadcap.....
Thank you
S Latest Nadcap AC 7102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Missed uploading a NADCAP HT checklist Nonconformance and Corrective Action 1
bryan willemot Looking for NADCAP audit Excel spreadsheets template for vendors, specifically heat treat (Vacuum Furnace) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Nadcap - Heat Treatment Proof of Verification question for Digital results AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J NADCAP Root Cause - Misinterpretation of Checklist Requirement Various Other Specifications, Standards, and related Requirements 5
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
J NCR- Failure of contract review process - NADCAP audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
N Nadcap AC7101/2 Rev. E Section 3.2 - Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
blackholequasar Looking into Nadcap for the first time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
A Nadcap Accreditation Fee AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M NADCAP mentoring program AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S NADCAP approval for Conventional Machining and Chemical processes - need assistance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
DuncanGibbons How does AS 9100D correlate or differ from NADCAP accreditation? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B AS9100 - Are special process suppliers required to be NADCAP accredited? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
N Responding to NADCAP nonconformance - Control of External Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q NADCAP NDT (specifically RT) - Calibration of eye loupe reticle & optical comparator AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J NADCAP - Supplier Special Processes Certifications Manufacturing and Related Processes 1
Q NADCAP NDT (specifically RT) - Checklist AC7114 Rev. K, section 8.1.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M NADCAP Chemical Processing: Question about testing sub-contractor requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Nadcap HT Auditor Advisory 17-003 Advice needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Double Thermocouple - Two types, same sheath (AMS2750/Nadcap) Manufacturing and Related Processes 9
I NADCAP In Manufacturing Facility with Small Laboratory - Measurement & Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R NADCAP AC7108 - Tank Ambient Room Temperature Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Is it required to have first AS9100 before obtaining Nadcap? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
H NADCAP Audit Nonconformances - Vacuum Furnace Load Sensors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Where can I find the NADCAP Audit Criteria for all the processes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Future as an AS9100/NADCAP Auditor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
E Nadcap Major Audit Finding Question - Effectiveness of our RCCA AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
J Zinc Plating Process NADCAP Certification Guidance please AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
E Nadcap - Tooling Control - Major Audit Finding (Question) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D Nadcap Certification for Soldering Iron? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Nadcap Certification for Printed Boards Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Nadcap Processor PO (Purchase Order) Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S Implementing TS16949 from AS9100 and NADCAP Other ISO and International Standards and European Regulations 7
T Nadcap AC7004 - Going for AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
N Basic requirements and steps involved to get NADCAP Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
JoCam NADCAP Initial Audit Cancellation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
O NADCAP Nonconformance for Timer not used for Time period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Kronos147 Nadcap AC7112 & AC7112/3 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Does 17025/NADCAP allow deferring Calibration Start Dates on Gages which are Stored? ISO 17025 related Discussions 10
S AS9100 and Nadcap vs. NAS412 (FOD program) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K Nadcap (AC7107/7 C, paragraph 6.1.b) NCR - Machining Tensile Specimens AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P NADCAP Certified - Heat Treat Continuous Belt Driven Oven question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A NADCAP AC 7101/03 Heat Treatment Process Acceptance Tests AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Are Outside Calibration Companies required to NADCAP Certified? General Measurement Device and Calibration Topics 6
J Nadcap finding Inadequate Procedure and Inadequate Root Cause Analysis Nonconformance and Corrective Action 4
JoCam Nadcap AC7120 (Audit Criteria for Circuit Card Assemblies) - Acceptance Criteria AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B What are the basic Nadcap certification requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
JoCam NADCAP AC7120 Rev A to B Documented Procedures Requirements Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Major NADCAP Magnetic Inspection Nonconformance - How to answer it? Nonconformance and Corrective Action 2
