Nadcap Certification for Printed Boards Assemblies
davidmxli
Hello.
My name's David.
This is the first time that I post anything in Elsmar Cove Forum, and I hope I'm doing it right, I couldn't find anything similar to my doubt.
Okay, the thing is that in our company, we mainly manufacture cable and harnesses assemblies, but we also make, in less proportion, some printed board assemblies. What we do is pretty simple: we buy printed boards from approved suppliers, and we then add them capacitors, resistances, some soldering, some bonding and varnishing.
The question is: Which type of Nadcap certification will be the appropiate or applicable one for this kind of process?
I was thinking maybe AC7120, but I'm not sure, becase it talks about circuit card assemblies, with programs loaded, CAD/CAM, verification of softwares, etc., and we don't actually perform that kind of processes, and for the items of the AC7120 that does apply to us are practically the same from AC7121 (receiving, storage, manual soldering, inspection, rework, etc.), and we hace that certification, but aparently it is not enough.
I really hope you can help me, because the Top Manager is all over me asking when will be this certification audit take place, what will we need, etc., but I'm not even sure which cert do we need, or even if we need another one different from AC7121.
Thanks in advance!
P
PaulJSmith
Hi, David!
Welcome to The Cove!
...AC7121 (receiving, storage, manual soldering, inspection, rework, etc.), and we hace that certification, but aparently it is not enough.
Whoever told you this (customer?, auditor?, random guy?) should surely be able to tell you why your current certification is inadequate, and what you need instead or in addition to that cert. I would start there.
...and maybe a PO review?
davidmxli
Hello to you Paul!
Yes, I know, that was my first thought, but the customer has been a little cryptic with this subject, and also, I checked the Customer's PO and their supplier's manual, but it only calls out for "required Nadcap certification for any special process such as electrics/wiring", which is where, I believe, my process fits.
Let's just say it's a very special customer, but I think that if I can refute the need of a new cert (because of the current one we already have), maybe they would not ask us that as a requirement.
Sidney Vianna
Post Responsibly
Welcome to The Cove.
You really should be asking your customer to precisely specify the approval you are expected to attain. Theirs is the only answer that really matters in this case. In terms of speculative opinions, I would definitely think AC7120 is the most appropriate program for you.
http://www.pri-network.org/nadcap/accreditation/
Electronics
The Electronics Task Group (ETG) conducts audits to demonstrate compliance to the following:
AC7119 – Printed Circuit Boards
AC7119/1 – Rigid Printed Boards
AC7119/2 – Flexible and Rigid-Flexible Printed Boards
AC7119/3 – High Density Interconnect Printed Boards
AC7120 – Printed Circuit Assemblies
AC7121 – Cable and Harness
Ready to begin the accreditation process? Then log on to eAuditNet
For more information on the Electronics Task Group, please contact:
Bill Dumas Senior Staff Engineer +1 724 772 8673
Susan Frailey Staff Engineer +1 618 615 4478
DarrellH
Hi David,
the kind of PCB assembly you describe does not sound particularly suited to Nadcap 7120, that standard is written around automated assembly via SMT & reflow ovens, where you can only control the process via temp profile / solder paste thickness / speeds etc, etc,
Have you looked at IPC-610? this is an inspection standard which your operators should use to verify the quality of thier work.
I would
1. Familiarise yourself with both IPC and Nadcap requirements
2. Decide which is of greatest benefit to your customer
3. Have a "grown-up" discussion with your customer
if necessary get an industry expert involved.
dsanabria
Once again - let the customer dictate what is appropriate.
Communication with the customer is your next step and ask them for guidance and what requirements you need to comply with... don't loose sleep over this one - let the customer decide this for you.
O NADCAP AC 7108 - Subcontractor Laboratory Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Zinc Plating Process NADCAP Certification Guidance please AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Nadcap Certification for Soldering Iron? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
N Basic requirements and steps involved to get NADCAP Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B What are the basic Nadcap certification requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R Does AS9100C require you to have NADCAP certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J PRI - NADCAP Certification requirement - AS9100 audit first before NADCAP audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
J NADCAP Root Cause - Misinterpretation of Checklist Requirement Various Other Specifications, Standards, and related Requirements 5
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
J NCR- Failure of contract review process - NADCAP audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
N Nadcap AC7101/2 Rev. E Section 3.2 - Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
blackholequasar Looking into Nadcap for the first time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
A Nadcap Accreditation Fee AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M NADCAP mentoring program AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S NADCAP approval for Conventional Machining and Chemical processes - need assistance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
DuncanGibbons How does AS 9100D correlate or differ from NADCAP accreditation? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B AS9100 - Are special process suppliers required to be NADCAP accredited? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
N Responding to NADCAP nonconformance - Control of External Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q NADCAP NDT (specifically RT) - Calibration of eye loupe reticle & optical comparator AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J NADCAP - Supplier Special Processes Certifications Manufacturing and Related Processes 1
Q NADCAP NDT (specifically RT) - Checklist AC7114 Rev. K, section 8.1.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M NADCAP Chemical Processing: Question about testing sub-contractor requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Nadcap HT Auditor Advisory 17-003 Advice needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Double Thermocouple - Two types, same sheath (AMS2750/Nadcap) Manufacturing and Related Processes 9
I NADCAP In Manufacturing Facility with Small Laboratory - Measurement & Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R NADCAP AC7108 - Tank Ambient Room Temperature Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Is it required to have first AS9100 before obtaining Nadcap? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
H NADCAP Audit Nonconformances - Vacuum Furnace Load Sensors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Where can I find the NADCAP Audit Criteria for all the processes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Future as an AS9100/NADCAP Auditor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
E Nadcap Major Audit Finding Question - Effectiveness of our RCCA AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
E Nadcap - Tooling Control - Major Audit Finding (Question) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Nadcap Processor PO (Purchase Order) Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S Implementing TS16949 from AS9100 and NADCAP Other ISO and International Standards and European Regulations 7
T Nadcap AC7004 - Going for AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
JoCam NADCAP Initial Audit Cancellation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
O NADCAP Nonconformance for Timer not used for Time period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Kronos147 Nadcap AC7112 & AC7112/3 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Does 17025/NADCAP allow deferring Calibration Start Dates on Gages which are Stored? ISO 17025 related Discussions 10
S AS9100 and Nadcap vs. NAS412 (FOD program) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K Nadcap (AC7107/7 C, paragraph 6.1.b) NCR - Machining Tensile Specimens AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P NADCAP Certified - Heat Treat Continuous Belt Driven Oven question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A NADCAP AC 7101/03 Heat Treatment Process Acceptance Tests AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Are Outside Calibration Companies required to NADCAP Certified? General Measurement Device and Calibration Topics 6
J Nadcap finding Inadequate Procedure and Inadequate Root Cause Analysis Nonconformance and Corrective Action 4
JoCam Nadcap AC7120 (Audit Criteria for Circuit Card Assemblies) - Acceptance Criteria AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
JoCam NADCAP AC7120 Rev A to B Documented Procedures Requirements Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Major NADCAP Magnetic Inspection Nonconformance - How to answer it? Nonconformance and Corrective Action 2
E Starting Nadcap Accreditation and making an Implementation Timeline AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
JoCam NADCAP Accreditation - Customer Requirements and Scope AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
