NC from TS16949 stage 2 audit - Internal Auditing - Auditor did not record evidence
P
puck1263
We were issued an N/C for internal auditing.
Criteria cited was TS 16949 - 8.2.2 The organization shall conduct internal audits... to determine whethere the qulaity managemetn system...conforms to planned arrangement...
Objective evidence cited:Internal audit Checklist form 036 page 1 (audited on 1/23/09) had questions where the auditor did not record the evidence looked at and decision as to compliance as called out on checklist.
So, he found checklists in out internal auditing records where not every question on the list was addressed. Does this matter that every question is answered if the objective of the audit can be ahcieved without it? I tend to agree that proper planning shoudl produce a proper checklist as a roadmap to achieve the audit objectives. Some use the checklist as a question pool.
Thoughts?
ralphsulser
Re: NC from TS16949 stage 2 audit -internal auditing - thoughts?
Checklists are only guides, most times I don't use any checklist at all unless there are some specifics I want to pursue ralating to a previous issue. TS16949 does not require a checklist. Does your internal audit prodedure specify the use of checklists? If so then it needs revised as an option.
Thoughts?
Well, one point of view might be that the internal auditor didn't know if this applied to the audit - could be they weren't 'competent' or missed the question/check on the list.......all kinds of things come to mind.
Did you know the point was missed, in review of the checklist? Was it applicable to the audit scope? If it was in the checklist, who decides when it's not applicable? Did the int. auditor just miss it? Lots of questions.....
This is one of the (many) problems with using 'canned' checklists. IMHO, each auditor should prepare their own. You'd get a better idea then, if they understood the audit assignment.
I probably wouldn't have written an nc before posing these types of clarifications with you, I would have dug a little deeper, but then, I'm not your auditor......
Ted Schmitt
Thoughts?
For those questions not addressed, where they simply not asked or the specific evidence was not recorded? It could have been recorded some where else on the checklist or page. I make some pretty creative records of my audits... arrows, boxes, *, notes etc.... I don´t write the objective evidence always neatly by the question (that is when I actually use a check list...
I agree with Andy and Ralph and think a little further checking should have been done... but we where not there....
Howard Atkins
Forum Administrator
Thoughts?
What was the actual NC, you gave the clause and the finding but not the NC.
Please give it and then I can reply.
P
puck1263
N/C
NC-01 The Internal audit checklist form 036 page 1 is not always
completedly filled out by internal auditors (audit conducted on 1/23/09).
N/C
Unless your company has a documented requirement to always completely fill out the checklist, the auditor is off base.
Howard Atkins
Forum Administrator
Thanks.
This NC is well out of the guidelines of the IATF for a NC.!!!!!
The NC must refer to the standard or your procedure not just rewrite the objective evidence.
P
puck1263
Thanks guys.
Our procedure does not state that it has to be completely filled out. Even if it did, that's not the criteria he cited.......
P
puck1263
Yeah, this is a difficult situation because there were SEVERAL other things the were N/C that were noted that weren't written up. He could have picked any solid one.
This puts us in compromising situation if we protest the one he did write up....he'll remember next time he's here..
We'll probably just write up the corrective action, etc and let it go....even though I don't like it!
M Readiness Review Failed - Stage one audit for TS16949 IATF 16949 - Automotive Quality Systems Standard 7
A Non-conformance logged following a TS16949 Stage 2 audit - APQP Control Plan IATF 16949 - Automotive Quality Systems Standard 15
L Stage One Audit vs. Document Review - TS16949 - Need clarification IATF 16949 - Automotive Quality Systems Standard 5
T PPAP differences between TS16949 and VDA APQP and PPAP 1
G Is ISO/TS16949 Extension Available? IATF 16949 - Automotive Quality Systems Standard 3
B ISO/TS16949 In-House Non-Product Laboratory IATF 16949 - Automotive Quality Systems Standard 3
B TS16949 Section 8.2.2.3 Product Audit - Requirements for various Customers IATF 16949 - Automotive Quality Systems Standard 10
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
tony wardle Lean and TS16949 - Integration Lean in Manufacturing and Service Industries 4
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
B Checklist for ISO/TS16949 for review and comment IATF 16949 - Automotive Quality Systems Standard 5
T TS16949 Process Design Requirements IATF 16949 - Automotive Quality Systems Standard 2
L TS16949 Work Instruction Requirements IATF 16949 - Automotive Quality Systems Standard 7
D TS16949 Annex A versus Toyota MQC's IATF 16949 - Automotive Quality Systems Standard 14
T TS16949 Lead Auditor Training Recommendations wanted Training - Internal, External, Online and Distance Learning 5
M Increase in Major TS16949 Audit Findings IATF 16949 - Automotive Quality Systems Standard 14
D TS16949 requirements for for Directed Buy Customers IATF 16949 - Automotive Quality Systems Standard 5
G Insights into the 2016 Version of TS16949 (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 74
B ISO/TS16949 8.2.3.1 IATF 16949 - Automotive Quality Systems Standard 1
B ISO/TS16949 6.2.2.3 IATF 16949 - Automotive Quality Systems Standard 1
K TS16949 registration for Kitting and Line Sequencing Service company IATF 16949 - Automotive Quality Systems Standard 1
V Procedure to change the Company name in existing TS16949-2009 certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Calibration Certificate "As Found" condition - TS16949 Section 7.6.2 General Measurement Device and Calibration Topics 7
T Reduced Audit days when UPGRADING from AS9100 to TS16949 - Is it possible? IATF 16949 - Automotive Quality Systems Standard 2
T Is there a requirement in TS16949 that PO's show a revision level? IATF 16949 - Automotive Quality Systems Standard 3
G Service Parts Assembly Line and Scope of TS16949 Registration IATF 16949 - Automotive Quality Systems Standard 3
M Comparing the MMOG (v3 or v4) with ISO / TS16949 Customer and Company Specific Requirements 3
B ISO/TS16949 Internal Auditing - How many auditors? Internal Auditing 4
B How to maintain documentation under ISO/TS16949 Clause 4.2.3 IATF 16949 - Automotive Quality Systems Standard 8
M Is a separate ISO/TS16949 certificate required for an extension site? IATF 16949 - Automotive Quality Systems Standard 4
L Scope of TS16949 for Aftermarket Product and a Service Fill Product IATF 16949 - Automotive Quality Systems Standard 2
B Meeting the requirements of ISO/TS16949 Clause 6.2.2.3 IATF 16949 - Automotive Quality Systems Standard 4
W Does TS16949 require MSA on all measurement systems in the Control Plan? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Process Records requirements for TS16949 standard IATF 16949 - Automotive Quality Systems Standard 6
D Include non-automotive in TS16949 Registration Scope IATF 16949 - Automotive Quality Systems Standard 1
R TS16949 requirements for Motorcycle OEM Parts Suppliers (Batteries) IATF 16949 - Automotive Quality Systems Standard 1
C TS16949: Product Audit vs. "Regular Checks" Internal Auditing 1
E Gap Analysis for VDA 6.3:2010 and ISO/TS16949:2009 VDA Standards - Germany's Automotive Standards 5
U TS16949 Internal Auditor Training - Is On-line training OK? Training - Internal, External, Online and Distance Learning 1
D What is your understanding or interpretation of TS16949 7.4.1.2 IATF 16949 - Automotive Quality Systems Standard 6
M TS16949 Control regulation with business partner(Subcontractor) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M TS16949 Design Exclusion when Design is done in a different Facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Help with TS16949 Awareness Training for Employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M TS16949 8.2.2.5 Internal Auditor Qualification IATF 16949 - Automotive Quality Systems Standard 4
N IATF Appeals on ISO/TS16949 Rules - 4th Ed. - Removal of Site Extensions IATF 16949 - Automotive Quality Systems Standard 2
M TS16949 Exclusions - Design & Development is carried out by our parent company IATF 16949 - Automotive Quality Systems Standard 14
D Risk Requirement for TS16949 Feasibility IATF 16949 - Automotive Quality Systems Standard 4
B TS16949 - 7.3 Design and Development Exclusions for a Service Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Will ISO TS16949 be impacted by ISO 9001:2015? IATF 16949 - Automotive Quality Systems Standard 3
F Gap Analysis Matrix for AS9100 Rev C to TS16949:2009 IATF 16949 - Automotive Quality Systems Standard 1
