NC: Lack of efficiency measurement for scheduling/shipping: clause 5.1.1
howste
Thaumaturge
#11
Tracking shipments using premium freight can be an efficiency measurement because you are relating how much product gets shipped to how many dollars you spent. Maybe I stated it wrong above. How about instead of a percent, you measure pounds of product shipped per dollar?
If your trucks are almost always full, your percent of truckload capacity utilized will be pretty efficient. If you're not at 100% there's still room to improve, and it would be good to know if the percent goes down. Why not measure this instead of something meaningless to make the auditor happy?
By the way, the ISO definition of efficiency is the "relationship between the result achieved and the resources used." The resources don't have to be "consumed" to be used. The resources could be floorspace, dock doors, personnel, time, dollars, etc.
I'm sure the reason the efficiency measurement is required is because OEMs want efficient suppliers so they can reduce part cost. Should it be required? :confused:
Coury Ferguson
Moderator here to help
#12
triner said:
Thank you for your comments. To address your questions, and provide further background:
1) Top Management review - He has clarified his stance on this to be that he will review our effectiveness and efficiency of our key processes. We defined Scheduling/Shipping as a key process. Perhaps that was a mistake.
Well, if it was defined as a key process, then the Auditor maybe right. However, identifying Scheduling/Shipping as critical...how/who was this determined by? I would not remove it as a critical process since there are ways to improve that process by, reducing premium freight costs, and improving delivery times to the customer. I might consider it as a "Quality Objective" rather than a key process (but I am not really sure if TS requires Objectives be established, even though TS was tailored around ISO9001).
triner said:
2) Auditor perscription for efficiency measurement - No he was quite explicit that efficiency was measurement of Output/Resource Input. The example he used was transactions / hour. This same topic came up with this auditor at a sister plant, and he was only satisfied when they developed 6 charts showing schedules per employee hour.
I still feel that the Auditor was only suggesting, even though this came up with the same auditor at your sister plant. That being said, maybe the auditor might have been stepping out of the scope and brought the subjective aspect on this issue, not the objective aspect. Which could be interpreted as telling your company what they shall do and that is not what the standard means.
triner said:
3) Preventative action? Please clarify
I didn't really see the preventative action in the two ideas that came up, but maybe I was reading it incorrectly.
howste
Thaumaturge
#13
I believe the confusion is coming from what you're calling a "preventative action."
In the ISO 9000 definitions (where the terms are defined for TS) a preventive action prevents occurrence of a potential nonconformity. A corrective action prevents recurrence of a detected nonconformity.
Since the auditor wrote it up, there can be no preventive action - it's already been detected. I think what you meant is the action that will prevent recurrence of the nonconformity - a corrective action.
tyker
#14
This is the sort of thread I most appreciate in the Cove, one which raises issues of auditor perception, concentrates on wording of the standard which can easily be overlooked and makes me think about the way my organization performs.
The big issue for me is that I have often seen findings based on "process effectiveness" but hardly ever consider the "efficiency" element as a seperate topic in my thought processes.
Reviewing what we do at my present company we do have both effectiveness and efficiency covered in our monitoring/measurement/review activities but efficiency is concentrated on manufacturing and for other processes is often incorporated as an improvement project.
I realize I haven't expressed this very well (it's early) but, for example, we currently have a project underway to improve our logistics activity. This incorporates measurement of efficiency of the process, setting targets for improvement and planning/reviewing achievements of these targets.
I can demonstrate, via this project, compliance with the TS requirements but when the project is completed our main measurement for this activity will again revert to effectiveness and we'll deploy resources to improve a different process.
The key point is it works for us and our limited resources are used where we see the potential benefits.
I've enjoyed reading all the replies.
Coury Ferguson
#15
Thanks Howste. You are right.
V
vanputten
#16
I think the best response is to not really measure process efficiency but to figure out how to answer the N/C without any improvement. After all, who really cares about efficiency?
Make sure that certification is just a piece of paper.
Regards,
Dirk
triner
#17
Regards,
Dirk
Sarcasm noted.
The efficiency being discussed specifically, is the efficiency of support activities such as scheduling, cost estimating, APQP preparation, etc. NOT the efficiency of the production process. I agree at some point in time, the support function will make fertile ground for improvement, but at this time, my organization and customer will both be best served by focusing on eliminating chronic defects produced by our process and identifying and mitigating areas where failure will cause hardship for our customer. Improving the efficiency of my scheduler so that they can produce a schedule in 1 hour instead of 2 will not benefit the customer.
I believe I will consume more resources creating and maintaining a measurement that will be ignored than I will save by tracking and reacting to that measurement.
I understand the intention of the TS standard. To create a QMS that focuses more on effectivness of the system rather than compliance to the system. However, that intention gets lost when we blindly create meaningless measurements to satisfy a vaguely written sentence.
In your effort to make the certificate meaningful, how have you addressed efficiency measurements for support functions?
V
vanputten
#18
"In your effort to make the certificate meaningful, how have you addressed efficiency measurements for support functions?"
Excellent question.
We have many Profit and Loss meetings. The poeple that attend these meetings look at resources used to accomplish our goals. Efficiency is not really reviewed specific to individual processes.
We have never been audited for efficiency requirements. Never.
I think about this issue with a big grin. "Key processes," "supporting processes", etc. There sure is a lot of variation and interpretation in the conformity assessment world.
Can anyone tell me where the requirements are for key processes and supporting processes?
Regards,
Dirk
howste
Thaumaturge
#19
5.1.1 requires that you review "support processes" for efficiency. I don't know how you can do it without having defined them. There is no reference in the standard to "key processes."
However, the IATF guidance document in 5.1.1 references both "key processes" and "support processes." This is probably where the terms come from. There is no guidance about how to determine what they are...
M Informational From RAPS – 27% Will be Compliant? Survey Highlights Lack of Readiness for EU MDR Medical Device and FDA Regulations and Standards News 0
C Neglect or legitimate deferral? Is excessive workload or lack of resources in a department or a team a valid root cause for a non-conformance? Problem Solving, Root Cause Fault and Failure Analysis 12
K FAA Audit - Major nonconformity for lack of timely calibration of two devices EASA and JAA Aviation Standards and Requirements 5
Q Lack of Awareness in ISO 9001 - Share a Presentation for Employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Minitab Lack-of-Fit Test in DOE (Design of Experiments) Using Minitab Software 4
S Minor Nonconformity for Lack of Job Descriptions in ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 62
V Lack of Fit vs Pred-R-Square. Using Minitab Software 3
L Audit NC - Lack of Effective Corrective Action Process ISO 13485:2016 - Medical Device Quality Management Systems 4
S Corrective Action for Customers Lack/Delays in Payment Misc. Quality Assurance and Business Systems Related Topics 6
J Lack of Measureables in our Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
AnaMariaVR2 Warning letter addresses lack of training/education 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 22
S Lack of Will & Empowerment of Employees Human Factors and Ergonomics in Engineering 15
C Internal Auditor lack of Competence Internal Auditing 76
Jim Wynne Forklift Safety, or Lack Thereof Coffee Break and Water Cooler Discussions 4
P United Break Guitars - Customer (Lack of) Care Coffee Break and Water Cooler Discussions 2
J Measurement Uncertainty (MU) - Genetic Testing Lab - Lack of suitable CRM - ISO 17025 ISO 17025 related Discussions 6
Q Meeting behavior and lack of cooperation of attendees to manager ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
P Lack of 3rd Shift Internal Audit - Major or Minor NC (Nonconformance)? Internal Auditing 17
N Lack of Management Commitment? Surveillance audit is next month General Auditing Discussions 6
A Lack of Quality Presence in Strategic Meetings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Lack of Management Commitment and Cooperation in Implementation of QMS! Quality Manager and Management Related Issues 36
N Raising a Nonconformance for Lack of Competency of Contractor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H Identifying the 7 Wastes and Adding "Lack of Creativity" as the 8th Waste Manufacturing and Related Processes 16
B Consequences for repeat nonconformances - Carelessness, lack of focus Nonconformance and Corrective Action 9
Jim Wynne Americans Love Science But... There is a lack of basic knowledge World News 14
M Broken Gages - Lack of Accountability General Measurement Device and Calibration Topics 11
M Lack of Training vs. Laziness: Failure to Complete Forms and Tags AFTER Training Training - Internal, External, Online and Distance Learning 68
RoxaneB Lack of Registration Body Consistency in Transitioning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Problems with our internal auditors having a lack of motivation Internal Auditing 1
H Effectiveness and efficiency indicators ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Quality, efficiency and effectiveness of daily work routines Misc. Quality Assurance and Business Systems Related Topics 4
M QMS Efficiency KPI as a Manager. IATF 16949 - Automotive Quality Systems Standard 7
M Medical Device News FDA News - 12-09-18 - MD Submissions to Electronic Format to Improve Efficiency Other US Medical Device Regulations 0
U SI 13 - Not Every Process Requires an Efficiency Measure IATF 16949 - Automotive Quality Systems Standard 1
M Effectiveness Measuring and Efficiency Measuring In ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D IATF 16949 Process Measurement and Efficiency Measures Requirements IATF 16949 - Automotive Quality Systems Standard 2
A IATF 16949 - Non-conformity on 5.1.1.2 Process effectiveness and efficiency IATF 16949 - Automotive Quality Systems Standard 5
B IATF 16949 Cl. 7.3.2 - Documented Process (Effectiveness & Efficiency) IATF 16949 - Automotive Quality Systems Standard 7
J Process Effectiveness and Efficiency (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 29
S Can Goals be both Efficiency and Effectiveness? TS 16949 IATF 16949 - Automotive Quality Systems Standard 9
G Reviewing Process Effectiveness and Efficiency IATF 16949 - Automotive Quality Systems Standard 5
M How to measure effectiveness and efficiency of the established QMS as Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
0 Calculation of Contamination Reduction Efficiency Statistical Analysis Tools, Techniques and SPC 4
J Methods to control Efficiency of Corrective and Preventive Actions Quality Manager and Management Related Issues 9
8 OEE (Overall Equipment Effectiveness/Efficiency) Help Lean in Manufacturing and Service Industries 14
R A GRP model that also considers the Preventive Maintenance Efficiency Reliability Analysis - Predictions, Testing and Standards 3
P Risk Management Verification Activities for Implementation and Efficiency ISO 14971 - Medical Device Risk Management 3
V What is best practice to track Quality Teams Effectiveness & Efficiency. Quality Manager and Management Related Issues 4
V How do you monitor the Responsiveness, Agility, Efficiency of Quality Systems? Quality Tools, Improvement and Analysis 3
S Training Efficiency Assessment - Evaluate the Effectiveness (Clause 6.2.2 c) Training - Internal, External, Online and Distance Learning 3
