Re: NCR, Containment action, CAR
As one example, here's how we do it:
Our NCRs are paper forms readily available around the shop. Upon discovery of a NC, the NCR gets written and, when necessary, immediately walked over to engineering for their input. This could be accomplished over the phone too. The form has a section for engineering instructions (or deviation acceptance). With that input, the correction and containment is done and annotated in the NCR.
The QM raises the CAR in our issue tracking system whenever it is convenient, and likely well after the emergency action is past. It is not mandated to file the Corrective Action Request immediately. When the Request is filed, then the info in the NCR gets loaded into the system and is available for the subsequent analysis.
Root Cause analysis and CA determination may take a several days or even weeks after the original NCR.
Good luck!
Pancho
Second case:
We are installing and equipment and noticed that the hole diameters on equipment for anchors were wrong located.
From here we need maybe not inmediately, but in 1 or 2 days the solution, the guy on the site can´t decide what to do, he needs the Engineering support to define it, Its clear is not inmediate.
What procede in this case according to iso or common practices?
Don´t you think is a lot o burocreacy, raise a NCR, then wait for the QM raise
a CAR, then the responsible department to design and implement the solution?
What to do in this case? regarding the procedures, to keep what recordS?
Should we bypass everything, pick-up the phone,call the Engineering dept
ask for a quick solution, implement it , and thats all.
Tha papers, those available, gathered after?
Good luck!
Pancho
