NDC (Number of Distinct Categories) - Long Gage R&R Study in MSA 3rd Edition
I noticed that in the MSA 3rd edition manual, there's a step to calculate ndc (number of distinct categories) for a long GRR study.
What exactly this ndc number try to achieve ? Could anyone care to explain the meaning of ndc ?
N
newlingd
This is covered in Chapter I - Section E, under discrimination. The explanation seems quite clear to me.
If the number of categories is 5 or more then there is no issue.
Cristi?nC
YKT:
As far as I can understand, this number is related with the "practical resolution" or the "practical discrimination" of a measurement instrument. The concept is not very difficult to grasp, but trying to explain WHY is calculated in the way that it is calculated, is another thing...
Here is my understanding with regard to NDC index:
Measurement Instruments have physical limitations to "discriminate" between different parts (i.e. give different values of a dimension for parts that are actually different). An example: The discriminative power of the scale that my wife has in the kitchen is 5 gr. By using this device it will be impossible for me to "discriminate" between packs of flour wheighing 1.010 gr, 1.007 or 1011 gr (eyeballing & rounding is not allowed!). All these three packs will be considered as having the same weight when actually it is not true. The three packs are in "the same category". In this way we start to talk about "categories"
The NDC tells you how many categories your measurement system (MS) is able to diferenciate considering your process variation.
If your NDC = 1 then your MS is useless.
If the NDC = 2 then your MS can only distinguish between two categories ("small" and "big", for example). (useless too)
If NDC = 3 then you have small, medium and big, and so on...
Automotive industries recomend a value equal or greather than five, if I remember well... The greatest the NDC the better.
Of course the term "category" is not physical or tangible. It is an "abstract category".
I hope this helps a little...
Regards.
trueposition
I read your thinking about the 'ndc'. I love your example, but I want ask something:
In you example, the scale's discriminative power is 5 gr!
And your flour packs weight's are 1.010gr, 1.007gr and 1.011 gr.
Can the example more clear if I use 5.010gr, 5.007gr and 5.011gr?
What do you think? Because I want to insert your example into my MSA instruction! :)
Best Regards,
trueposition
Cristi?nC
Great you like the example!
Perhaps there is a slight misunderstanding, caused by the decimal separator we use here in Brazil. 1.010 gr means 1 kilogram and 10 grams. Ok?
If the discriminative power of a scale is 5 gr, it is almost a SIN to use it to weight a part that weights more or less 5 gr. Agree?
Regards!
krishkaar
We conduct MSA on heat treated parts using a Rockwell Hardness and Vickers hardness scales.
While we conducted MSA, we observed that the result shows acceptability (that is less than 10%), but in none of the seven studies, we could get NDC anything more than 2.34.
Where is the catch??
if you post your data we can give an exact answer.
however, my experience says that the most liekly reason is that the parts you measured don't have much variation compared to the spec limits. NDC is calculated using the variation of the parts you selected for the study. In perfroming a Gage R&R you should have parts that span the full range of variation that you are trying to address. if the R&R is fro acceptance testing then the parts should span the full tolerance range (and even be a little out of spec if possible) If you are assessing a sytem that is to be used for troubleshooting or for SPC then the parts should span the full range of variation of the process as it is. (be that large and out of spec or small and perfectly centered)
krishkaar
Yes.
The tolerance available is very limited.
For example, one of the products - it is specified that hardness should be 60-64 HRC.
Is this range adequate to provide the NDC needs??
Yes.
again posting your data is the only way for us to truly answer your question.
However, from this info, I would say that you simply do not have the resolution necessary for this tolerance to calculate a meaningful NDC. If your resolution is low (you are reportign hardness as an integer 60, 61, 62, 63, 64) you will have what is known as "chunky" data.
but without your actual data I can not give you a better answer...
DCB0427
I'm having trouble with my Gage R&R. Basically my NDC is 1 which is not sufficient. I'm not sure I quite understand how to get that number up. I've attached my minitab gage R and R report. Can someone please help me? I'd appreciate it very much! :D
L Number of Distinct Categories" or NDC Calculation in MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
B Help with NDC (Number of Distinct Categories) Please Six Sigma 2
M MSA Manual asks for NDC higher than 5 - NDC (number of distinct categories) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Impossible to achieve NDC (Number of Distinct Categories) greater than 2 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 28
V Can Anyone Give a Simple Explanation on ndc (number of distinct categories)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Minitab number of distinct category (ndc) problems Using Minitab Software 4
S What is NDC (Number of Distinct Categories)? MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
A Number of distinct categories (NDC) - Non ferrous metal industry Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Number of Distinct Data Categories - NDC - AIAG's MSA Manual 3rd edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Number of Distinct Data Categories:nDC: Where does the constant 1.41 come from? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Question on very low NDC number with tolerable GRR ratio's Capability, Accuracy and Stability - Processes, Machines, etc. 7
bobdoering "nds" or Number of Discriminate Samples - the Necessary Tool to Work With "ndc"! Imported Legacy Blogs 0
N Average range of measurement system NDC number Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
G Please clarify the Rule of 10 to 1 - AND - What is the ndc number? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 66
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Is a ndc less than five is also acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R Count NDC from Graphik Sample Range vs R chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B Process Control - Selecting Parts - NDC & Study Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Capability Study => Check %Study Variance and NDC? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B NDC - Gauge R&R Studies with results where NDC = 1 or 0 Manufacturing and Related Processes 1
Y Poor Gage R&R Results - High R&R result and poor ndc value Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R ndc=0 and GRR=14% ??? Interpretation - basic question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S Using Range/Tolerance to Guesstimate NDC or % SV? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Conclusions from weird GR&R (Gage R&R) Results - 9 of 12 points have NDC of 1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Gage R&R Sheet Formula error?! NDC less than 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J %Study %Tolerance NDC - R&R Criteria Acceptability when the Tolerance is used Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Gage R&R %Tolerance NDC Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
C Minor NC - NDC of 0.4 yet the system had been accepted with no investigation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B NDC relates which type of MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
S Ndc less than 5 (purchased part) - Auditor suggest I get waiver from customer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S The assessment of ndc figures in MSA studies. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Interpreting my R+R chart - NDC's and Out of Control Limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Can someone clarify "Resolution", "Discrimination" and "ndc"? General Measurement Device and Calibration Topics 4
C Tolerance vs. Part to Part - Is it ndc? When using % of tolerance everything is fine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Y Is NDC needed for gage used for ATE? Automated Test Equipment IC Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K During Gage R&R, is calculation of ndc value required? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 24
G Gage R&R derivation with respect to ndc - Lessons Learned Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Calculation of ndc is 1.41PV/GRR - Origin of this coefficient? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
D Resolution, Discrimination, NDC and the Tower of Babel in Metrology General Measurement Device and Calibration Topics 5
C Discrimination - Use ndc to analyse the discrimination power? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Control Number for Class III and IV devices Canada Medical Device Regulations 0
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
K How can Acceptance Number and Reject Number be larger than Sample Size on Z1.4 Table? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
K Why 'FD&C act section number' and 'section number' in the title of the act are different? US Food and Drug Administration (FDA) 1
A Risk Number for each software requirement IEC 62304 - Medical Device Software Life Cycle Processes 7
K Adding the Notified Body Number CE Marking (Conformité Européene) / CB Scheme 2
C Quantifying risk in choosing the number of parts, operators and replicates in a GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
