NDC relates which type of MSA Study
BigTel
I am looking for some help regarding the NDC (Number of Distinct Catagories) number.
My question is, does the NDC relate to all types of MSA study? So far I have seen it used on a type 2 sudy where you have 3 different operators obtaining results. But what about type 1 study etc?
Thanks for your help.
ndc is a metric used specifically for assessing the gauge's suitability for SPC. While it may be calculated for a Type 1 study, unless all of your SPC is done by a single operator, doing so would be misleading. I do not recommend it.
BigTel
We have been asked to look at it as part of our TS16949 assessment.
I have previously only performed type 1 studies to assess the variability of a gauge but I am trying to assess how to (and if I need to) add the NDC calculation into my workings. And what it will give me..!
Stijloor
If you have access to the AIAG MSA manual, ndc is addressed on pages 44-45 and 117. Page 117 provides the fomula for calculating ndc.
ndc is expected to be greater than or equal to 5.
Stijloor.
bobdoering
Stop X-bar/R Madness!!
If you have a valid reason for using a type 1 study (automated gaging with no operator intervention), then ndc is evaluated with the same equation as a type 2 study.
AIAG recommends ndc>=5, however that is only applicable for standard product acceptance usage. For SPC ndc>=10.
To answer "what will it give me?" is an estimate of the statistically significant resolution of the device, under the GR&R test conditions.
BigTel
I have a torque tester which checks the torque produced on a range of air driven screwdrivers. I have capability studies on the drivers but I am trying to do an MSA study on the torque tester itself.
I am using a spread sheet taken from this forum and I am getting an NDC of 0.74..! (My GRR result is 0.099 which leads me to belive I am doing something drastically wrong)
I have used 3 different operators to gain results from the same torque driver, used on the same static torquing point. Have I done something wrong here?
bobdoering
I am using a spread sheet taken from this forum and I am getting an NDC of 0.74..! (My GRR result is 0.099 which leads me to believe I am doing something drastically wrong)
Probably not. But, if you can upload your completed GR&R data sheet so we can look at it, we may be able to help you find some direction as to where the issue is. Also, if you have any manufacturer's specification for the torque tester (accuracy, etc.), that would also be handy.
BigTel
Our torque guns have specs such as 4 to 4.5 NM, or 4.5NM +-0.2
I do understand that I really should be using something with a higher accuracy to do these checks, but I have to use what I have available.!
J Question on very low NDC number with tolerable GRR ratio's Capability, Accuracy and Stability - Processes, Machines, etc. 7
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
bobdoering "nds" or Number of Discriminate Samples - the Necessary Tool to Work With "ndc"! Imported Legacy Blogs 0
L Number of Distinct Categories" or NDC Calculation in MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Is a ndc less than five is also acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R Count NDC from Graphik Sample Range vs R chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B Process Control - Selecting Parts - NDC & Study Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Capability Study => Check %Study Variance and NDC? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B NDC - Gauge R&R Studies with results where NDC = 1 or 0 Manufacturing and Related Processes 1
Y Poor Gage R&R Results - High R&R result and poor ndc value Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Help with NDC (Number of Distinct Categories) Please Six Sigma 2
R ndc=0 and GRR=14% ??? Interpretation - basic question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S Using Range/Tolerance to Guesstimate NDC or % SV? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Conclusions from weird GR&R (Gage R&R) Results - 9 of 12 points have NDC of 1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M MSA Manual asks for NDC higher than 5 - NDC (number of distinct categories) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Impossible to achieve NDC (Number of Distinct Categories) greater than 2 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 28
T Gage R&R Sheet Formula error?! NDC less than 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
V Can Anyone Give a Simple Explanation on ndc (number of distinct categories)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J %Study %Tolerance NDC - R&R Criteria Acceptability when the Tolerance is used Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Gage R&R %Tolerance NDC Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
C Minor NC - NDC of 0.4 yet the system had been accepted with no investigation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
M Minitab number of distinct category (ndc) problems Using Minitab Software 4
S Ndc less than 5 (purchased part) - Auditor suggest I get waiver from customer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S The assessment of ndc figures in MSA studies. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S What is NDC (Number of Distinct Categories)? MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Interpreting my R+R chart - NDC's and Out of Control Limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Can someone clarify "Resolution", "Discrimination" and "ndc"? General Measurement Device and Calibration Topics 4
N Average range of measurement system NDC number Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Tolerance vs. Part to Part - Is it ndc? When using % of tolerance everything is fine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Y Is NDC needed for gage used for ATE? Automated Test Equipment IC Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K During Gage R&R, is calculation of ndc value required? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 24
G Gage R&R derivation with respect to ndc - Lessons Learned Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Please clarify the Rule of 10 to 1 - AND - What is the ndc number? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 66
M Calculation of ndc is 1.41PV/GRR - Origin of this coefficient? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
A Number of distinct categories (NDC) - Non ferrous metal industry Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Resolution, Discrimination, NDC and the Tower of Babel in Metrology General Measurement Device and Calibration Topics 5
S Number of Distinct Data Categories - NDC - AIAG's MSA Manual 3rd edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Discrimination - Use ndc to analyse the discrimination power? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Y NDC (Number of Distinct Categories) - Long Gage R&R Study in MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 76
D Number of Distinct Data Categories:nDC: Where does the constant 1.41 come from? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Performing a MSA as it relates to Calibration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C PPAP Benchmarking as it relates to the Aerospace Industry APQP and PPAP 7
J Software Development Process - How ISO9001 relates to Software Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Which ISO/AS Clause directly relates to Preventive Maintenance of Equipment? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A EA Code 9 (printing) as it relates to 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
T N 286.1 as it relates to 10 CFR Appendix B Part 50 - Nuclear Requirements Various Other Specifications, Standards, and related Requirements 1
Q Excluding Clause 8.2.4 as it relates to Cl 7.6 (Control of Measuring Device) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Definition LCS - What does LCS mean as it relates to purchasing of material? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
K Guidance to Guide 66 as it relates to registration for multiple facilities Miscellaneous Environmental Standards and EMS Related Discussions 1
