Necessary or Unnecessary Redundancy in Procedures
x-files
In every our procedure we have lots of redundant text. There are two specific procedure structure clauses:
* Terms&Definitions and
* Reference documents
In „Terms&Definitions” we over and over again explain what is QMS, IMS, EMS, EHS, OH&S, information, procedure, form, record, aspect, etc, etc, etc, … even when such term are not mentioned in a procedure. Mostly there are just few procedure specific Terms&Definitions.
In “Reference documents” (besides the really procedure needed documents) we always reference the full titles of: PAS 99, ISO 9000, ISO 9001, ISO 9004, ISO 14001, ISO 14004, OHSAS 18001, OHSAS 18002, OHSAS 18001, Manual QMS, Manual EHS, National law 1, National law 2, 3, 4 etc. In almost every case, the procedure never explicitly needs any of the listed documents to be applied itself. All the requirements are already implemented in the procedure.
External auditors (SGS), when they see our lists in Reference documents, few times jokingly said: „We wonder why you also didn’t mention The State Constitution (Low)“, with obvious observation that’s needless.
Internal auditors (and our EX consultants) said that’s necessary for these to be listed in the procedure.
The fact is that these well known items are explained and are explaining during regular trainings about IMS, and are considered as necessary base knowledge in employee contracts and job descriptions.
I myself would exclude these from procedures, and make them as compact is they could be. Furthermore, I could add appendix to “Document control procedure” and list commonly used and prefered “Terms&Definitions”, if it's so necessary.
So what do you think of that, what are you practices?
Best regards,
Vladimir
TPMB4
I've also heard of people using cut and paste quality manuals which virtually copy the first 3 sections of the ISO9001 standard - terms and references, definitions, etc. I have a copy of one partly written for my employer that was done by some guy off his own bat. It struck me that the writers of these don't understand fully what is needed and are perhaps covering their backs by putting everything in it.
Just my observations and opinion. I don't know the answer for your company, but my feelings are that you think these things are not needed and would like to get rid of them as much as possible. Good luck with that as I suspect the bosses like what consultants say and will stick with them even if they are wrong. There will be someone along shortly to give you good advice on this I'm sure.
x-files
For now, I use very simple experiment to determine what’s needed for the procedure. I strikethrough a word/sentence/paragraph/item from text and analyze how that affected the integrity of document (for usage and compliance with standards). I also discussed with users about that. They want a procedure to be as much an integral things as it’s possible. But if the procedure lists 50 additional documents that they never saw, or are almost irrelevant for the process, they start considering a procedure as a document like something too generalized or some kind of recommended document not mandatory. Funny, but true. This attitude is promoted by procedures which are created by copy/paste of relevant ISO 9001 sections, with no details.
In ?Terms&Definitions? we over and over again explain what is QMS, IMS, EMS, EHS, OH&S, information, procedure, form, record, aspect, etc, etc, etc, ? even when such term are not mentioned in a procedure. Mostly there are just few procedure specific Terms&Definitions.
In ?Reference documents? (besides the really procedure needed documents) we always reference the full titles of: PAS 99, ISO 9000, ISO 9001, ISO 9004, ISO 14001, ISO 14004, OHSAS 18001, OHSAS 18002, OHSAS 18001, Manual QMS, Manual EHS, National law 1, National law 2, 3, 4 etc. In almost every case, the procedure never explicitly needs any of the listed documents to be applied itself. All the requirements are already implemented in the procedure.
External auditors (SGS), when they see our lists in Reference documents, few times jokingly said: ?We wonder why you also didn?t mention The State Constitution (Low)?, with obvious observation that?s needless.
Internal auditors (and our EX consultants) said that?s necessary for these to be listed in the procedure.
I myself would exclude these from procedures, and make them as compact is they could be. Furthermore, I could add appendix to ?Document control procedure? and list commonly used and prefered ?Terms&Definitions?, if it's so necessary.
Best regards,
Vladimir
There are no general rules, but I think it's usually best to have a single QMS glossary, perhaps in the quality manual, but somewhere where it's readily accessible. For abbreviations there should be a general rule that they're spelled out on first use in the text. For example, "...the Environmental Management System (EMS)..." and then use the abbreviation thereafter in the document.
For document references, I think it's best to reference only the documents that are germane, such as forms or work instructions.
The worst offense of procedure writing is usually wordiness, and if words can be eliminated without loss of clarity or meaning, they should be eliminated.
x-files
Thank you for the the very constructive advices. You've just accented the pure truth: "[...] The worst offense of procedure writing is usually wordiness [...]". Our procedures are now full of useless words, like when a young pupil wants the homework essay to be stretched "on three pages", considering that as the primary goal.
somashekar
An other way you can look at procedures is a 3 column approach.
You have a procedure title on top and below have the 3 columns. The first being the inputs which captures all the necessary inputs which will include also the reference of the very procedure. The second is activity which details in bullet points what specific activity and how it is to be done using the inputs. Pictures where required can also be inserted as visual aids (perhaps in all the 3 columns). The third is the outputs what will capture the activity deliverables and you can also include records requirements, as records form a valid output from an activity.
Try your own procedure as an example to see if this makes sense and can take out the redundancy ...
K
kgott
We are all free to make things as difficult and costly or as easy and as efficient for ourselves as we wish.
If there is a good reason for doing as you do then do it. Did the auditors ever explain why they believed all the references and definitions were necessary?
Be guided by what the relevant standard says eg 9001 etc. While its a bit cryptic all that you need to know about procedures etc is in them.
I have never been able to understand why people abbreviate words then provide definitions of abbreviations. Why abbreviate anyway? I can only conclude that some people consider words to be prohibitively expensive to write or say.
F
Frankie11
I am in the process of integrating our qms documentation with our HSE documentation and have found similar redundant text.
I would add to x-files' list 'Responsibilities'. I often find every procedure has the same thing under this heading:
The CEO is responsible for ensuring the quality management system is implemented and maintained.
The [process owner] is responsible for implementing this procedure and reviewing as necessary...
Employees are responsible for understanding and following this procedure..
etc.
Jen Kirley
Quality and Auditing Expert
etc.
Listing the CEO would generally be appropriate for the process in which the CEO has inputs. Management review comes to mind, and the quality manual also. But every procedure? No. A single organizational chart can accomplish as much.
As for definitions, I would try to provide a very easily accessible guide for users, in the QA manual as Jim said or maybe on an intranet page or even a poster. In a given procedure I would list definitions for the acronyms the procedure lists in its process steps and/or appendixes/attachments. Try to keep it simple.
somashekar
Adding a line for responsibility in the procedures is not uncommon.
My take here is that the responsible person has to be the user of that document and not that he has to know about his responsibility from that document.
Responsibility and authority are defined and communicated at personnel level and training level before coming to operational level where procedures become useful.
Q Is Establishment Registration Necessary? Other US Medical Device Regulations 1
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
M Is it Necessary to Use Health Canada Form when Reporting? Canada Medical Device Regulations 1
K ISO 13485 clause 8.5.2 'Any necessary CA shall be taken without undue delay' ISO 13485:2016 - Medical Device Quality Management Systems 11
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
E How do you determine if hipot is necessary for a cable product? Manufacturing and Related Processes 8
T HF testing / Summative evaluation for MDDS class I necessary? Human Factors and Ergonomics in Engineering 2
V 3 PQ lots mentioned as requirement in PPAP. Is this necessary? APQP and PPAP 2
G Best Practices for IT auditing - Is a session-id necessary for a complete audit trail? IEC 27001 - Information Security Management Systems (ISMS) 0
B Is it necessary to conduct product audit of entire product which is manufactured in the company as per IATF IATF 16949 - Automotive Quality Systems Standard 4
R Clinical Trial to sell in the EU - Necessary or Not? ISO 13485:2016 - Medical Device Quality Management Systems 5
K GDPR - Is it really necessary for the DPO(s) to be knowledgeable to Data Privacy Law? IEC 27001 - Information Security Management Systems (ISMS) 3
D How to ensure independence and authority necessary to perform QM tasks ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
bobdoering "nds" or Number of Discriminate Samples - the Necessary Tool to Work With "ndc"! Imported Legacy Blogs 0
S Is an index necessary for DMR or DHF? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
H Change of a medical device sterilization dose - New 510(k) necessary? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Time necessary for all Risk Management activities ISO 14971 - Medical Device Risk Management 2
M Risk Identification and Risk Assessment for any Process - Is it necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
P Necessary Compliance Documentation for RoHS and REACH REACH and RoHS Conversations 5
C Change Order necessary to document FMEA Updates? FMEA and Control Plans 1
J Is a Laboratory Scope Necessary if... IATF 16949 - Automotive Quality Systems Standard 15
S Is a GR&R necessary for Weighing Scale? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Procedures necessary for things such as the floor cleaner or weigh scale ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
V Certified Internal auditor is necessary? ISO 9001 requirement? Quality Management System (QMS) Manuals 4
T Is it necessary to Audit our CARs and SCARs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Biocompatibility - why are animal studies necessary? Other Medical Device and Orthopedic Related Topics 11
N Is Notified Body approval necessary for small changes to IVD IFU? CE Marking (Conformité Européene) / CB Scheme 7
G Plant Relocation - Is it necessary to perform FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
A Is IEC 80601-2-60 necessary for Dental Laser? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Necessary trainings for FAR 145 certification Federal Aviation Administration (FAA) Standards and Requirements 3
H 510k Submission - Is Risk Management necessary? US Food and Drug Administration (FDA) 2
M Is Notification of the Test Laboratory always necessary for Supplier Changes? IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
S Certificate Suspension Necessary in case of No Production? ISO 13485:2016 - Medical Device Quality Management Systems 4
A Cosmetic Spec - Convincing Management Visual Inspection Standard is Necessary Manufacturing and Related Processes 5
GStough Is A Re-Audit Necessary after Disaster Recovery? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N Internal Audit of the Training System - Corrective Action Necessary? Preventive Action and Continuous Improvement 16
P Is it necessary to show Model Number on the Labeling (meter box, label and manual)? Other US Medical Device Regulations 3
M Retroactive Training Records Necessary? ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 3
T Necessary test documents for Class II Medical Device Hardware and Firmware ISO 13485:2016 - Medical Device Quality Management Systems 9
somashekar How to Determine the Necessary Employee Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M IEC 60601-1 testing for device with its own 2V battery power supply necessary? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Documents necessary for registration of a Medical Device EU Medical Device Regulations 2
P Is it necessary to perform Root Cause Analysis for each failed part? Problem Solving, Root Cause Fault and Failure Analysis 16
L Approved Parts Listing- ISO 13485- Is an approved parts listing necessary? ISO 13485:2016 - Medical Device Quality Management Systems 9
M Is it necessary to record all nonconforming products? IATF 16949 - Automotive Quality Systems Standard 12
P Is it necessary to consider ISO 22002-1 for the implementation of ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 3
M ISO 10993 - Repeat tests necessary if colour changes slightly? Other Medical Device Related Standards 11
Q Is an actual document for Roles and Responsibilities necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K RC14001:2008 - Audit of Internal Audit: Is this necessary? ISO 14001:2015 Specific Discussions 16
