Need 5 why’s help
TacitBlue
We received a finding: 7.5.3 in AS9100. No process to document minor changes to a procedure.
Let me give you background, the auditor first identified a document which showed a minor change on the doc change history on the doc itself. The auditor looked at our uncontrolled minor change log and did not see a recording for the minor change to that document in the log. We failed to record the minor change for that doc. The auditor then asked if we had a procedure for recording minor changes. The auditee was unable to provide our work instruction because they forgot we had a work instruction for minor changes, so it was never provided. The auditor then looked over our main document control procedure and the auditor did not find any procedure for recording minor changes or any reference to our minor changes WI or log because we never included that information in the procedure. Therefore, we got the CAR.
How could I write a professional and solid 5 why’s to show cause and effect for this finding?
Jen Kirley
Quality and Auditing Expert
Sigh. Having a previous life as Document Control Queen, my heart is with you.
Let us dissect this.
1) What was this minor change?
2) What does your document control procedure say about managing minor changes? For example: an edited hyperlink, changed business name/icon in the header, paragraph numbering.
It is worthwhile to build into your document control system a means to manage administrative changes. If you don't want to do that permanently but you allow yourself the ability to make a temporary change, this temporary change might be leveraged to suspend (for a short time) typical controls so a minor change (we might call it a "nuisance change" if it is widespread) can help you get the job done without landing yourself in audit trouble.
Do you allow your system to make temporary controlled changes?
TacitBlue
Hi Jen,
We failed to record a simple update to a document. I believe it was wording.
at the time of the finding we didn’t have anything referencing process for minor changes in our doc control procedure. However we have since included the requirement for processing minor changes and the logging of those minor changes within our doc control procedure.
we have an internal uncontrolled work instruction and log for minor changes so yes we allow such changes. However minor changes are only recorded for controlled documents.
in fact we had the wi and log prior to the audit. Just wasn’t part of our procedure. Now it is.
Jen Kirley
Hi Jen,
It seems as though you have addressed the issue. Planned arrangements for document updates are important. I have seen many document control processes that are very confining: small (administrative) changes are not planned for, and temporary changes are not planned for. It seems okay to describe your systems' previous lack in the response to this nonconformity, especially since you found it was worth actually fixing.
This issue doesn’t warrant using such an approach. Correct it and move on. External auditors tend to see everything as an iceburg.
TacitBlue
Nonconformance FINDING: Our department made minor change to a document, but did NOT log the minor change in the minor change log.
Why: the personnel responsible did not record the change in the log.
Why: the personnel forgot to log the minor change.
Why: they were not held accountable to record the change.
Why: the manager was unaware of the minor change needing to be recorded.
Why: there is no internal requirement as part of the minor change process to notify the manager of a pending minor change.
Root cause: Our internal document control procedure does not state a manager notification or minor change requirement.
Corrective Action: Internal document control procedure will be revised to include minor change process requirements including manager notification.
Will this be accepted by the technical reviewer??? The only thing that I am question is whether the issue was really because the personnel forgot to do it and how we can prevent them forgetting again in the future? For example, even if we included the minor change requirements as part of our doc control procedure, how would that prevent the personnel from forgetting to log the minor changes? That’s why I am thinking the important part of this is not so much that our minor change requirements be included as part of our doc control procedure, but that we have a trigger to the manager to ensure the logging actually gets completed. Right?
With the greatest respect, you have taken on a monster, which you must now feed. You are attempting to fix something by treating it as a systemic issue, when it should have simply been corrected. The auditor should have audited your system, not created a monster. As a result, you will have to feed the monster, including worrying about the completeness of a 5Why and its acceptance.
First: did you talk to the person who ‘forgot’ to log the finding? As a reviewer I would not accept the ‘5why‘ because it reads like it was created in a vacuum.
Second: and more importantly I’m not sure this a finding requiring anything more than simplifying your procedure. Why isn’t noting the minor change in the document history enough? Why do you have to ‘double‘ record it? This path is a more effective approach to truly solving the ‘issue’.
Third: how can you prevent anyone from forgetting? Everyone forgets; it’s built into our nature. The only way to prevent forgetting is to error proof the process. Simplification is one way, electronic barriers and paths in documentation are another. You don’t need a trigger to a mananger - you are making the process more complicated with more opportunities for failure.
I would recommend taking a deep breath and thinking about this in a different way.
T Need help understanding AS6174 clause 3.1.5. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R First Time Managing Calibration and Measurement System. Need Help. General Measurement Device and Calibration Topics 19
C Need help in determining applicable clause for an audit finding (based on AS9120B) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Attempting to Poke Yoke a wire crimping process...need help Design and Development of Products and Processes 3
C I need your help to find the action plan for these quality objectives Misc. Quality Assurance and Business Systems Related Topics 23
R Need help on calibration result analysis Measurement Uncertainty (MU) 17
G Need Help with Run @ Rate for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 0
F Need help in IMS management review Management Review Meetings and related Processes 3
S I need help in corrective action plan Nonconformance and Corrective Action 15
D Weird spec sheet - need help Measurement Uncertainty (MU) 3
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
K Screen printing ink and machine selection_ Need help Manufacturing and Related Processes 6
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
S Need help with analysing a survey on minitab Using Minitab Software 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S New to FAIR, need help in filling it out AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R Pls help --- Need expert advice on Video Measurement Measurement Uncertainty (MU) 0
Ajit Basrur Need help to understand HIPAA requirements ISO 13485:2016 - Medical Device Quality Management Systems 25
Z I need help with getting a CFS in China Manufacturing and Related Processes 2
S Need help wrapping my head around confidence vs beta error Statistical Analysis Tools, Techniques and SPC 2
P Received a minor for not having good measureables/goals. Need help with KPIs. IATF 16949 - Automotive Quality Systems Standard 52
A Failed the AS9120B Exam Twice.....Need Help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Ajit Basrur Need help in Conditional Formatting for the entire row Excel .xls Spreadsheet Templates and Tools 3
H Need help on Quality Improvement Plan (QIP) Quality Tools, Improvement and Analysis 5
S Help: Need Control Self Assessment Questionnaire for HR Departmental Functions Process Audits and Layered Process Audits 0
M Need help in Calibration of Directional Coupler General Measurement Device and Calibration Topics 2
L Need HELP with Internal Audit Program ISO 13485.2003 Quality Management System (QMS) Manuals 3
J Supporting Processes - Internal Audits - Need help settling a debate IATF 16949 - Automotive Quality Systems Standard 4
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
A Need Help With AEA Auditor Related Situational Questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Transformer Overload Test - Need help IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C I Need Help with Drafting Conventions!!! Design and Development of Products and Processes 4
M Need help on QMS Development in an AS9100C certified organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R Need Help on Analysis: How to know potential causality model from historical data Problem Solving, Root Cause Fault and Failure Analysis 5
B Need help tracking training for my business Quality Assurance and Compliance Software Tools and Solutions 3
B Need help with a Control Plan for Encapsulation Mold / Trimming / Forming Tooling FMEA and Control Plans 9
S I need help from all of you bros Oil and Gas Industry Standards and Regulations 1
LRE67 Need help identifying this "thing" Coffee Break and Water Cooler Discussions 9
G Need help on Device Description in the Acceptance Checklist for Traditional 510(k) Other US Medical Device Regulations 2
K Need help finding a book on Documentation Book, Video, Blog and Web Site Reviews and Recommendations 8
J Need help/advice on video editing software etc..... Coffee Break and Water Cooler Discussions 9
