Need advise on Root Cause analysis for printing issue
F
ffemt1
My department is having a lively discussion about the root cause of the problem and I need some expert advice on how to get over the hump. Here is the situation.
We have printing press A that takes printing plates that transfer ink to the paper. When plates are made they require register marks to make sure all of the colors are in register. For whatever reason we need to switch a job to press B after the first set of plates are made. To do this we must make new plates and there is a requirement that for this job, but not all jobs that are switched, “special” register marks are used. The need for these special marks is rare. Well, you guessed it, we did not use the correct marks and printed the job incorrectly.
Now for the root cause.
1. One investigation path takes us down the road of why were the special marks not used. Do we take time to find and implement ways to insure the correct marks are always used? If we can find a way that is foolproof, the problem is eliminated.
2. Second path goes a little further and asks are there a ways to eliminate the need for special marks? (Yes, standardize equipment but might need to spend money and we never like to do that.)
3. Third path goes further and takes us down a different road of why did we have to switch presses in the first place. Is there a way to eliminate the need to switch presses? There may be but it probably takes some preplanning and with extremely quick turn times there are other considerations, like the availability of the correct size paper for the press.
:confused: All are good solutions but isn't there always a best solution? My opinion is that this is like a rework that is done incorrectly. The root cause could be that you did the rework wrong and if you find a way to do it right from now on everything is OK but that is not the actual root cause. The problem is that you were put in the that position in the first place.
Opinions?
Michael_M
Sometimes a root cause can have multiple reasons, not necessary 'the best'. When this is the case, correct the multiple reasons. Sometimes a CA will even show another potential failure. This can be corrected with a preventive action.
However going a bit further into the CA. Were the (setup) instructions antiquate to the job's and to the two different machines you were using? Did someone verify the printing was correct before 'going into production'?
I am not familiar with printing or printing presses so my additional questions my not apply.
insect warfare
QA=Question Authority
We have printing press A that takes printing plates that transfer ink to the paper. When plates are made they require register marks to make sure all of the colors are in register. For whatever reason we need to switch a job to press B after the first set of plates are made. To do this we must make new plates and there is a requirement that for this job, but not all jobs that are switched, ?special? register marks are used. The need for these special marks is rare. Well, you guessed it, we did not use the correct marks and printed the job incorrectly.
Opinions?
From what you describe, the fundamental issue seems to be a lack of resources. Obviously, if you have sufficient resources (ability to produce/burn plates faster, enough presses to expand flexibility, the correct paper always in stock based on demand, etc.) coupled with good engineering controls, you could say with a high level of confidence that this problem would never recur. Sometimes effective solutions do cost more money than we would like to admit, but the good ones always realize when a more expensive option may be the most viable solution and will fully act to implement it in a timely manner.
I happen to have a little experience in this field, and it is never easy to solve these kinds of problems when there are so many variables to contend with (customer demands, job prioritization, job setup parameters, ordering supplies, press maintenance, operator safety, etc.). In the printing industry, pure reaction to customer's demands can quickly become the nature of the beast, and can leave you in "firefighting" mode all day long if you let it.
Brian :rolleyes:
Ronen E
Problem Solver
Moderator
My opinion is that you can't identify the "best" solution (assuming there is one) before establishing what makes a given solution better or worse. For example, most companies would like to fix their problems while minimising costs. You've hinted that your company is among them. So, ranking the possible solutions may include each solution's associated cost, preferably also taking account of the likelihood of complete solution / durability.
Contrary to response #2 above, I think that implementing more than one effective CA (eliminating one root cause) is not necessary. The important word is "effective". If the action does eliminate the root cause, and it can be demonstrated by objective evidence that this actually removed the possibility of recurrence (or made the chances remote), it should suffice. If the associated risk is high, perhaps some redundancy is required (implement >1 CAs), but otherwise implementing several CAs for a single problem would be - IMO - a waste of resources.
Cheers,
Ronen.
P ISO13485 Clause 7.2.1 (d) Additional Requirements - Need advise ISO 13485:2016 - Medical Device Quality Management Systems 2
C Need advise to make judgement to take job offer Career and Occupation Discussions 9
E Digital Height Gauge Gage R&R - Need Advise and Help Quick Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Need Advise on upcoming ISO 9001:2000 Surveillance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
H Need advise on formats to use when writing procedures Document Control Systems, Procedures, Forms and Templates 14
J Japan registration need manual without temperature reading Japan Medical Device Regulations 0
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
R Need for an Importer outside EU? EU Medical Device Regulations 0
T Do I need to add non-product related service providers to my ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
A Need career advice on QMS & HSE (No hands on experience) Career and Occupation Discussions 6
B Need assistance with documents CE Marking (Conformité Européene) / CB Scheme 2
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
Ashland78 Need to show evidence in accordance with QR-11012 and SPB-00001-09 Customer and Company Specific Requirements 5
E Does IVD need to integrate with hospital IT infrastructure? Medical Information Technology, Medical Software and Health Informatics 2
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
S In Need of GIDEP Guidance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Do employee training records need to be controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D What evidence to I need to supply as a remote location in relation to manufacturing sites? IATF 16949 - Automotive Quality Systems Standard 10
T Non API products need to comply to API Q1? Oil and Gas Industry Standards and Regulations 3
G Need journal and reference of abnormal bar chart SPC Statistical Analysis Tools, Techniques and SPC 4
MSeibert47 Daily Quality Topics - Need Ideas Please! Food Safety - ISO 22000, HACCP (21 CFR 120) 18
W Do Reference materials for IATF need to be 17025? IATF 16949 - Automotive Quality Systems Standard 15
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
Melissa Risk Management Process, How far do I need to go? ISO 14971 - Medical Device Risk Management 11
F Need Quality Manager advice. Quality Manager and Management Related Issues 6
T Do we need an SOP for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Do CTQs need to be equipment specific? FMEA and Control Plans 8
K Do Contract Manufacturers need a complaint procedure? Medical Device and FDA Regulations and Standards News 9
K Screen printing ink and machine selection_ Need help Manufacturing and Related Processes 6
D Do employee training records need to be centralized? IATF 16949 - Automotive Quality Systems Standard 10
H Need of EU Representative Designation for Turkey? EU Medical Device Regulations 3
H If we use agile - do we still need to document TF as a waterfall just for the notified bodies need? IEC 62304 - Medical Device Software Life Cycle Processes 2
briteme4 AS9102 First Article Inspection - do I need a second reviewer and signer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Furnace repaired - Do I need a new initial TUS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
J Need a contract monitoring Tool General Information Resources 0
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 3
W 17025 and NIST handbook relationship (need advice) ISO 17025 related Discussions 8
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
Ed Panek Immediate need for 80601-2-56 Consulting expert. PM me for details Career and Occupation Discussions 0
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 6
K Interesting Discussion "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
