Need help on calibration result analysis
Rachel
Can someone enlighten me whether my analysis is correct for the calibration results? See attached pic.
I only have the relative expanded measurement uncertainty % in the report. From there, I used the formula : Relative Expanded Measurement Uncertainty (REU) = (EU / y) to calculate the expanded measurement uncertainty. And found out that the test result for 4.00 cNm is out of tolerance.
Thanks.
greif
You appear to be comparing the measured value to the uncertainty to get your percentage; this does not make sense.
Comparing the tolerance interval (4.4-3.6) to the uncertainty would make some sense.
You may want to evaluate the ratio of uncert to the tolerance interval first, then eval the measured value and decide if it passes or fails.
A common desired uncert to tolerance range is 4:1
How to Calculate Test Uncertainty Ratio - isobudgets
BradM
Hello Rachel!!
Well... it looks like we might want to look a little deeper into how you're calculating the relative expanded uncertainty values. Your calibration assessment at "4" was spot on, yet it shows a failure.
Was the calibration performed by an accredited organization? They should have listed an expanded uncertainty traceable to an SI unit (like cN.m).
Rachel
Hello Rachel!!
Hi BradM,
This instrument calibrated by an accredited vendor. All these values are taken from their calibration report with only Relative Expanded Uncertainty (%) given. I'm not sure how the vendor get those percentage. They did not list out the expanded uncertainty in the report.
Thus, I can only derived the EU from the formula I mentioned earlier on:
For the measured value 4.00, the EU I calculated is 1.156, meaning +/-1.156
If the EU is taken into account, the result will be 4.00 +/-1.156. I interpreted that as a fail because it falls outside the tolerance limits (3.600 - 4.400)
BradM
I totally understand your scenario. Question... on the calibration certificate, did they not report pass/fail?
If it was me, I would pose this back to them. You paid good money for documentation that should clearly show you what they did and the results.
greif
I was unfamiliar with Relative Measurement Uncertainty; now that I have looked at that I see that it is a measure of "goodness".
It appears that they are not stating that the measured value is out of tolerance, but are stating that the measurement uncertainty is too large for the magnitude of the measured value.
They did not list expanded uncertainty on the report? Is this a 17025 accredited cal lab? Iso 17025 requires the reporting of uncertainty.
Rachel
Unfortunately, they did not report pass/fail. Only a remark in their report: " The user should determine the suitability of the instrument for its intended use."
Rachel
Yes, they are accredited calibration lab. That's why I'm puzzled, they should provide EU instead of REU
R First Time Managing Calibration and Measurement System. Need Help. General Measurement Device and Calibration Topics 19
M Need help in Calibration of Directional Coupler General Measurement Device and Calibration Topics 2
T Calibration and Control - Need help with plug, ring, and thread plug gages General Measurement Device and Calibration Topics 12
C Opening a new Calibration Laboratory - Need help General Measurement Device and Calibration Topics 8
K Need Help With IATF 16949 Audit NC IATF 16949 - Automotive Quality Systems Standard 6
bryan willemot Wanted: in need of start up Lock out Tag out program in Excel or Word, your help is much appreciated Occupational Health & Safety Management Standards 3
T Need 5 why’s help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
T Need help understanding AS6174 clause 3.1.5. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Need help in determining applicable clause for an audit finding (based on AS9120B) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Attempting to Poke Yoke a wire crimping process...need help Design and Development of Products and Processes 3
C I need your help to find the action plan for these quality objectives Misc. Quality Assurance and Business Systems Related Topics 23
G Need Help with Run @ Rate for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 0
F Need help in IMS management review Management Review Meetings and related Processes 3
S I need help in corrective action plan Nonconformance and Corrective Action 15
D Weird spec sheet - need help Measurement Uncertainty (MU) 3
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 52
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
K Screen printing ink and machine selection_ Need help Manufacturing and Related Processes 6
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
S Need help with analysing a survey on minitab Using Minitab Software 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S New to FAIR, need help in filling it out AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R Pls help --- Need expert advice on Video Measurement Measurement Uncertainty (MU) 0
Ajit Basrur Need help to understand HIPAA requirements ISO 13485:2016 - Medical Device Quality Management Systems 25
Z I need help with getting a CFS in China Manufacturing and Related Processes 2
S Need help wrapping my head around confidence vs beta error Statistical Analysis Tools, Techniques and SPC 2
P Received a minor for not having good measureables/goals. Need help with KPIs. IATF 16949 - Automotive Quality Systems Standard 52
A Failed the AS9120B Exam Twice.....Need Help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Ajit Basrur Need help in Conditional Formatting for the entire row Excel .xls Spreadsheet Templates and Tools 3
H Need help on Quality Improvement Plan (QIP) Quality Tools, Improvement and Analysis 5
S Help: Need Control Self Assessment Questionnaire for HR Departmental Functions Process Audits and Layered Process Audits 0
L Need HELP with Internal Audit Program ISO 13485.2003 Quality Management System (QMS) Manuals 3
J Supporting Processes - Internal Audits - Need help settling a debate IATF 16949 - Automotive Quality Systems Standard 4
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
A Need Help With AEA Auditor Related Situational Questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Transformer Overload Test - Need help IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C I Need Help with Drafting Conventions!!! Design and Development of Products and Processes 4
M Need help on QMS Development in an AS9100C certified organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R Need Help on Analysis: How to know potential causality model from historical data Problem Solving, Root Cause Fault and Failure Analysis 5
B Need help tracking training for my business Quality Assurance and Compliance Software Tools and Solutions 3
B Need help with a Control Plan for Encapsulation Mold / Trimming / Forming Tooling FMEA and Control Plans 9
S I need help from all of you bros Oil and Gas Industry Standards and Regulations 1
