Need Help on choosing dimensional standards / equipment
  • Thread starter Daniel Walker - 2011
  • Start date
Hello all,
I am in the process of expanding the capabilities of our 17025 lab to include dimensional calibrations. I have a couple of questions regarding equipment and standards.
1. What is the best (easiest) way of certifying gage blocks? Horizontal "universal" type machine or vertical comparator? Keeping in mind that I could also do other various gages on the horizontal "universal" machine. I want to be able to do gage blocks up to 20". I realize that once I get over 4 - 5", most vertical comparators wouldn't work. Could I then go to a height gage for blocks in the range of 5 - 20"?
2. What are the benefits of purchasing high grade gage blocks for use in an environmentally controlled lab when I use the correction values of my standards when determining the error for tested items? I could spend $500,000 trying to get gage block standards that have zero error but if I am using the correction values stated on the certificates in my calculations, what's the point?
Forgive my ignorance on this subject. I am trying to educate myself as much as possible before spending the money on equipment and standards. I don't want to over spend for something I don't really need, but I don't want to be stuck with insufficiant eqiupment & standards either.
Any help on this is GREATLY appreciated. I have some follow up questions as well, but I want to take this a step at a time.
dan
BradM
Daniel, first... there is no ignorance of any kind in your query. It is actually a very good question.
As for measuring gauge blocks, I am not the best on that. Wesley and several others here have better knowledge on that than I. Are you going to buy profile equipment for this? That equipment is expensive. However in general, you "zero" out the higher-order standard measure, then calculate the deviation of the U.U.T.
As for the proper gauge blocks... purchase the best you can afford. Don't get three levels higher than your need; you'll have to take a loan out and them to N.I.S.T.:tg: Saying if you purchase standards with the appropriate accuracy ratio, you will not have to worry about using the correction factors, because they will be insignificant. The gauge blocks will change over time; you want that change insignificant as possible.
I have worked with standard situations where we were having to put correction factors and such on the test sheet (actually, they were mass standards). That really got to be a pain, and caused problems. When we got the correct standards, life got better.:D
Too, the better gauge blocks are made with better material, and given appropriate storage/environment, they will serve you well.
NOTE: If I remember correctly, you are in the mass standards/balance business. Just like with classifications of weights, top grade blocks will need to be stored properly.
This is just a gut thing with me... always purchase the best you can afford. You never know what business needs you'll need down the road. You can always have your blocks certified to a lower grade than they are actually rated for, if it is cost-prohibitive.
One more thing... budget to have something to cover your blocks while they are out for calibration.
jfgunn
The first question to ask yourself is how accurate do you want to be when calibrating gage blocks? What kind of uncertainty to you hope to achieve?
Do you need to be the most accurate guy in your area? For example: In my area, there is one guy whose uncertainty is 5 uin at 1 in. There is also Starrett whose uncertainty is 2 to 4 uin at 1 in.
We have a Pratt & Whitney LabMaster Universal which can be used for gage blocks, rings, plugs, thread plugs, length standard up to 12". If you go to A2LA's website, and search for this piece of equipment you will find uncertainties anywhere from 3 to 10 uin at 1 in (I suppose this fact could be talked about in another thread as to consistency in the measurement community). My uncertainty budget works out to 8 uin at 1 in.
If a customer wants to choose the guy in town who has a 5 uin unceratinty instead of my 8 uin uncertainty, I ask the obvious question: "If 3 uin matters, why not go to Starrett?
The labmaster universal requires only a few master gage blocks as it is a long range comparator. you can master with a 0.1 in and 1" block and test anywhere in the range. This makes your gage block purchase much less and your annual calibration cost of those blocks less. You can also purchase two sets in which case you are never out of business when your blocks go out for calibration. Also, the time required to calibrate a set is less than making a compariosn at every point.
Whatever you do, I would suggest trying to calcualte your uncertainty budget prior to getting the equipment. Of course, things like repeatability would have to be estimated, but you can get a good idea if the uncertainty will be what you need before you spend the money.
Total cost estimate: We took a small room and installed a Leibert Precision Cooling system with Electirc Reheats to control temperature and humidity. We put in clean room ceiling tiles and used vapor barrier paint. Purchase of LabMaster with all the fixtures and master gage blocks and modification to room was about $125K.
This does only get you to 12". How much work do you really think you would have over 12"?
I hope this helps.
D Weird spec sheet - need help Measurement Uncertainty (MU) 1
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
K Screen printing ink and machine selection_ Need help Manufacturing and Related Processes 6
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
S Need help with analysing a survey on minitab Using Minitab Software 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S New to FAIR, need help in filling it out AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R Pls help --- Need expert advice on Video Measurement Measurement Uncertainty (MU) 0
Ajit Basrur Need help to understand HIPAA requirements ISO 13485:2016 - Medical Device Quality Management Systems 17
Z I need help with getting a CFS in China Manufacturing and Related Processes 2
S Need help wrapping my head around confidence vs beta error Statistical Analysis Tools, Techniques and SPC 2
P Received a minor for not having good measureables/goals. Need help with KPIs. IATF 16949 - Automotive Quality Systems Standard 52
A Failed the AS9120B Exam Twice.....Need Help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Ajit Basrur Need help in Conditional Formatting for the entire row Excel .xls Spreadsheet Templates and Tools 3
H Need help on Quality Improvement Plan (QIP) Quality Tools, Improvement and Analysis 5
S Help: Need Control Self Assessment Questionnaire for HR Departmental Functions Process Audits and Layered Process Audits 0
M Need help in Calibration of Directional Coupler General Measurement Device and Calibration Topics 2
L Need HELP with Internal Audit Program ISO 13485.2003 Quality Management System (QMS) Manuals 3
J Supporting Processes - Internal Audits - Need help settling a debate IATF 16949 - Automotive Quality Systems Standard 4
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
A Need Help With AEA Auditor Related Situational Questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Transformer Overload Test - Need help IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C I Need Help with Drafting Conventions!!! Design and Development of Products and Processes 4
M Need help on QMS Development in an AS9100C certified organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R Need Help on Analysis: How to know potential causality model from historical data Problem Solving, Root Cause Fault and Failure Analysis 5
B Need help tracking training for my business Quality Assurance and Compliance Software Tools and Solutions 3
B Need help with a Control Plan for Encapsulation Mold / Trimming / Forming Tooling FMEA and Control Plans 9
S I need help from all of you bros Oil and Gas Industry Standards and Regulations 1
LRE67 Need help identifying this "thing" Coffee Break and Water Cooler Discussions 9
G Need help on Device Description in the Acceptance Checklist for Traditional 510(k) Other US Medical Device Regulations 2
K Need help finding a book on Documentation Book, Video, Blog and Web Site Reviews and Recommendations 8
J Need help/advice on video editing software etc..... Coffee Break and Water Cooler Discussions 8
L Need Help with Case Study Questions Manufacturing and Related Processes 16
W Help explaining the need for the Process Approach AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ron Rompen Unusual problem with Excel - Need some help Excel .xls Spreadsheet Templates and Tools 7
S Need help on new TS 16949 Rules IATF 16949 - Automotive Quality Systems Standard 5
M Need help with Network Analyzers and which DUT can be Calibrated with it Calibration and Metrology Software and Hardware 2
R Need help on defining scope for Design Verification File for Class III IVD 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
J Help I need your opinion on a News Letter Misc. Quality Assurance and Business Systems Related Topics 15
N Need Help Preparing for Medical Device Quality Engineer Interview Career and Occupation Discussions 2
B Need help on an application we are working on Coffee Break and Water Cooler Discussions 4
