Need Help on the method of calculating tube wall Within Part Variation
DZ-Jang
Hello Folks:
very glad to discuss with u all here .
Our product were tubes and one of the charicteristics is wall thickness .when I did the G R&R, I can`t fix the point the appraiser measured on the tube axis ,so the result of the G R&R report is not exactly the same as it did in the plants.
I have seen one way of calculating WIV but only if there were maximum and minimum measured ,this method comes from the 2nd edition of the MSA manual.
And I can`t find any formula in the third edition MSA Referenced Manual except a short explain in words.
Can anyone give any suggestions or the method for calculating With-in part var ? Thank you in advance !
Marc
What pages of the MSA Manual are you referring to? Let's start there.
DZ-Jang
Marc .
I d`ont have the English version of the manaul but the Chinese Version .It seems that they r the same . The Manual here of the 2nd edition related r page 64-66. It gives out the formula to calculate the WIV for maximum and minmum value of the characteristic .
thank u
Atul Khandekar
Not sure if I understood you correctly, but how do they do it in the plant? If they are able to fix the location of measurement in the plant, may you should study the method / fixtures used there and try to replicate it. Or try to design a fixture where you can carefully control the location.
If you are using the 2nd edition format, the operator should obtain measurements of wall thickness at various locations (say, 10) along the circumference and/or length. (rotate the tube if needed.) Then use the maximum, minimum and the range of these 10 readings as one trial for one operator.
DZ-Jang
What is the characteristic this Within-Part Variation G R&R evaluated ?
Atul Khandekar said:
Here is a link to a PDF document I found at the AIAG website:
Quantifying the Effect of Excessive Within-Part variation
Atul:
I had seen the similar documents before and what puzzled me is : for which characteristic this 《Quantifying the Effect of Excessive Within-Part Variation》is evaluating ? The maximum ,the minimum ,or the average ? If it is for the later ? why ?
You once asked the measurement method used in the plants . The truth is ,I did the same way as they did in the plants to do the G R&R . They note down the the maximum and the minimum value of the wall thickness in their register ,but the method or how many points should be measured were not stipulated . The operators just use their own way (e.i. one`s experience) to find the maximum and the minimum . I can see some of them find the point quickly while some of them may use longer time.
And I don`t know whether this kind of Experience can be trust in.
I`m waiting :nopity:
Atul Khandekar
DZ-Jang said:
.... They note down the the maximum and the minimum value of the wall thickness in their register ,but the method or how many points should be measured were not stipulated . The operators just use their own way (e.i. one`s experience) to find the maximum and the minimum . I can see some of them find the point quickly while some of them may use longer time.
This is why you should develop a standard measurement procedure that all operators must be trained to follow. Also, you should supervise the study being conducted.
D Need help with Gage R&R method Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
S Need help with analysing a survey on minitab Using Minitab Software 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S New to FAIR, need help in filling it out AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R Pls help --- Need expert advice on Video Measurement Measurement Uncertainty (MU) 0
Ajit Basrur Need help to understand HIPAA requirements ISO 13485:2016 - Medical Device Quality Management Systems 17
Z I need help with getting a CFS in China Manufacturing and Related Processes 2
S Need help wrapping my head around confidence vs beta error Statistical Analysis Tools, Techniques and SPC 2
P Received a minor for not having good measureables/goals. Need help with KPIs. IATF 16949 - Automotive Quality Systems Standard 52
A Failed the AS9120B Exam Twice.....Need Help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Ajit Basrur Need help in Conditional Formatting for the entire row Excel .xls Spreadsheet Templates and Tools 3
H Need help on Quality Improvement Plan (QIP) Quality Tools, Improvement and Analysis 5
S Help: Need Control Self Assessment Questionnaire for HR Departmental Functions Process Audits and Layered Process Audits 0
M Need help in Calibration of Directional Coupler General Measurement Device and Calibration Topics 2
L Need HELP with Internal Audit Program ISO 13485.2003 Quality Management System (QMS) Manuals 3
J Supporting Processes - Internal Audits - Need help settling a debate IATF 16949 - Automotive Quality Systems Standard 4
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
A Need Help With AEA Auditor Related Situational Questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Transformer Overload Test - Need help IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C I Need Help with Drafting Conventions!!! Design and Development of Products and Processes 4
M Need help on QMS Development in an AS9100C certified organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R Need Help on Analysis: How to know potential causality model from historical data Problem Solving, Root Cause Fault and Failure Analysis 5
B Need help tracking training for my business Quality Assurance and Compliance Software Tools and Solutions 3
B Need help with a Control Plan for Encapsulation Mold / Trimming / Forming Tooling FMEA and Control Plans 9
S I need help from all of you bros Oil and Gas Industry Standards and Regulations 1
LRE67 Need help identifying this "thing" Coffee Break and Water Cooler Discussions 9
G Need help on Device Description in the Acceptance Checklist for Traditional 510(k) Other US Medical Device Regulations 2
K Need help finding a book on Documentation Book, Video, Blog and Web Site Reviews and Recommendations 8
J Need help/advice on video editing software etc..... Coffee Break and Water Cooler Discussions 8
L Need Help with Case Study Questions Manufacturing and Related Processes 16
W Help explaining the need for the Process Approach AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ron Rompen Unusual problem with Excel - Need some help Excel .xls Spreadsheet Templates and Tools 7
S Need help on new TS 16949 Rules IATF 16949 - Automotive Quality Systems Standard 5
M Need help with Network Analyzers and which DUT can be Calibrated with it Calibration and Metrology Software and Hardware 2
R Need help on defining scope for Design Verification File for Class III IVD 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
J Help I need your opinion on a News Letter Misc. Quality Assurance and Business Systems Related Topics 15
N Need Help Preparing for Medical Device Quality Engineer Interview Career and Occupation Discussions 2
B Need help on an application we are working on Coffee Break and Water Cooler Discussions 4
S Need help with Project Charter for my Six Sigma Green Belt Project Six Sigma 1
Q Need help on MSA study on a torque analyzer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Need help in adding second location to FDA Registration Other US Medical Device Regulations 4
T A survey on problems during ISMS implementation - need help IEC 27001 - Information Security Management Systems (ISMS) 2
Z My first Gage R&R - Paper/Poly/Foil Material Bond Test, need help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
