Need Help With Auditing Suppliers Against ISO 9001
I am new to this forum and am searching for permissible questions to be asked in an ISO 9001 audit. I am very familiar with ISO 13485, but ISO 9001 seems so vague that I am having a difficult time auditing it. Where in the procedure does it state it is permissible for the auditor to review procedures and quality manuals. How can I verify that the supplier is following their procedures if I cannot see the procedure in its entirety? thanks for your guidance
Kronos147
An errant question, does not one audit to the requirements of ISO 9001, rather than 'against' it?
Some auditors have the mentality of 'against' and like writing large numbers of non-conformances, rather than say, find the central theme and issue it there.
I think auditors should be looking for conformity, and then, when non-conformity is identified it, classify it minor or major. Heck, in audits it is more frequent to hear the client say "well that's not right" follow by me saying, "well I'm gonna classify that as a minor NC" more than the other way around.
great question- I have been auditing to ISO13485:2016 for over 6 years and always have been audited by customers and have audited customers (to 13485:2016) as with Medical device it is appropriate. Now I am getting push back from suppliers who are ISO9001 and I am wondering if I am being too controlling. and yes I should have said "to" and not "against". I have never had issues when auditing to 13485 to review their quality manual and procedures, but with 9001 I am now. Thanks for the guidance
Auditing "against" a standard is common usage and does not imply any sort of negativity, no more than me putting a ladder against my house means that my ladder has formed some kind of negative relationship with the house.
Added in edit: I moved the OP's post to its own thread, and in so doing titled it, including the "against" thing. Not the OP's doing.
You still haven't explained why you feel you need to do this. If you want to audit suppliers, you will of course need their cooperation, and if you're asking suppliers to send you all of their documentation prior to the audit, I can understand the reluctance. Talk with suppliers, not as a dictator but as a partner, and find out with them the best way to go about this.
Jen Kirley
Quality and Auditing Expert
Welcome Karen!
We audit suppliers to the requirements of the standard, but also to our own requirements as customers. This tends to allow more of what you are used to; it is true that the revised ISO 9001 has fewer "shalls" which has not been well received by all auditors.
The differences between 2nd party and 3rd party auditing have been a sore spot for a long time. We in 2nd party audits are asked "Where is the requirement?" and the supplier reasonably has a right to an answer to that. I recently issued a nonconformity to a supplier for lack of evidence they had been inspecting their forklifts that I observed in use. When pushed back, I pointed out that the forklifts were moving our product around and the inspection was for things that could impact our product quality: up, down, steering, brakes... My supplier was not happy but I stood my ground and I know my management would approve.
The revised standard starts with risk based thinking. If you see a lack of control with no clear "shall" to point to, you can ask about how they had considered risk in that process/area, and go from there. Be ready to discuss why the issue you raise is important. All of this is less about the standard and more about the end result: consistent good product and service, hopefully with a minimum of waste so we can all get back to happier pursuits like counting profits.
I hope this helps.
chris1price
After coming from ISO13485, you'll find many ISO9001 suppliers may have very brief procedures which make it difficult to audit against (or to). Similarly there is no requirement to have a Quality Manual under ISO9001. Others may use a Quality Manual in place of procedures.
It may be better to consider what you want to achieve from the supplier audit. Typically, this will be to identify significant risks, either to the supplier or to your own company. Follow the typical processes paths (change control, CA, PA, production, inspection, etc) and see how the supplier behaves. Whether or not they have procedures, if they are consistently doing the right things, that is good. If they are inconsistent or missing the obvious steps that you would expect, then that is a problem. If you then go back to the standard, you can usually find a clause that applies.
Was there a requirement? As we all know, the standard definition of "nonconformity" is "non-fulfillment of a requirement."
J New to Internal Auditing - Need help and advice Internal Auditing 5
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
K Screen printing ink and machine selection_ Need help Manufacturing and Related Processes 6
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
S Need help with analysing a survey on minitab Using Minitab Software 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S New to FAIR, need help in filling it out AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R Pls help --- Need expert advice on Video Measurement Measurement Uncertainty (MU) 0
Ajit Basrur Need help to understand HIPAA requirements ISO 13485:2016 - Medical Device Quality Management Systems 17
Z I need help with getting a CFS in China Manufacturing and Related Processes 2
S Need help wrapping my head around confidence vs beta error Statistical Analysis Tools, Techniques and SPC 2
P Received a minor for not having good measureables/goals. Need help with KPIs. IATF 16949 - Automotive Quality Systems Standard 52
A Failed the AS9120B Exam Twice.....Need Help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Ajit Basrur Need help in Conditional Formatting for the entire row Excel .xls Spreadsheet Templates and Tools 3
H Need help on Quality Improvement Plan (QIP) Quality Tools, Improvement and Analysis 5
S Help: Need Control Self Assessment Questionnaire for HR Departmental Functions Process Audits and Layered Process Audits 0
M Need help in Calibration of Directional Coupler General Measurement Device and Calibration Topics 2
L Need HELP with Internal Audit Program ISO 13485.2003 Quality Management System (QMS) Manuals 3
J Supporting Processes - Internal Audits - Need help settling a debate IATF 16949 - Automotive Quality Systems Standard 4
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
A Need Help With AEA Auditor Related Situational Questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Transformer Overload Test - Need help IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C I Need Help with Drafting Conventions!!! Design and Development of Products and Processes 4
M Need help on QMS Development in an AS9100C certified organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R Need Help on Analysis: How to know potential causality model from historical data Problem Solving, Root Cause Fault and Failure Analysis 5
B Need help tracking training for my business Quality Assurance and Compliance Software Tools and Solutions 3
B Need help with a Control Plan for Encapsulation Mold / Trimming / Forming Tooling FMEA and Control Plans 9
S I need help from all of you bros Oil and Gas Industry Standards and Regulations 1
LRE67 Need help identifying this "thing" Coffee Break and Water Cooler Discussions 9
G Need help on Device Description in the Acceptance Checklist for Traditional 510(k) Other US Medical Device Regulations 2
K Need help finding a book on Documentation Book, Video, Blog and Web Site Reviews and Recommendations 8
J Need help/advice on video editing software etc..... Coffee Break and Water Cooler Discussions 8
L Need Help with Case Study Questions Manufacturing and Related Processes 16
W Help explaining the need for the Process Approach AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ron Rompen Unusual problem with Excel - Need some help Excel .xls Spreadsheet Templates and Tools 7
S Need help on new TS 16949 Rules IATF 16949 - Automotive Quality Systems Standard 5
M Need help with Network Analyzers and which DUT can be Calibrated with it Calibration and Metrology Software and Hardware 2
R Need help on defining scope for Design Verification File for Class III IVD 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
J Help I need your opinion on a News Letter Misc. Quality Assurance and Business Systems Related Topics 15
N Need Help Preparing for Medical Device Quality Engineer Interview Career and Occupation Discussions 2
B Need help on an application we are working on Coffee Break and Water Cooler Discussions 4
S Need help with Project Charter for my Six Sigma Green Belt Project Six Sigma 1
