Need Help with Case Study Questions
L
LOUPEN
I'm near the final stages of a new opportunity in the medical field and my background is ISO based. So I'm a little lost with regards to Installation Qualification (IQ), Operational Qualification (OQ), and Performance Qualification (PQ). I am genuinely confused by the last case study example.
Can someone answer these questions? I would get a better idea of what I need to focus on when replying. I would greatly appreciate it.:thanx:
Steve Prevette
Deming Disciple
It would help to know the context for this exercise. Is this a college course? What textbook(s) and background material were provided?
Also, if you "google" search on "performance qualification" there are a lot of references out there. To me, this is a fundamental quality engineering question of how to approach problem - solving.
L
LOUPEN
This is a case study given to me by a potential employer. Since I have been working primarily in manufacturing that's NON-Medical. So, I need some guidance on how I can answer these questions. Particularly, The last two examples are two areas I'm not too familiar with and I have "googled" various references but, they do not give specific examples on how to solve the "dilemma" exhibited on the case study. Can someone guide me? I'm all ears! Thanks guys!
:thanks:
Steve Prevette
Deming Disciple
Throw out the IQ, PQ, and OQ issue for the moment. If you were faced with a situation that a vendor supplied defective product to you and this resulted in defective product out the door, what would you do? And if you were told the existing monitoring did not catch this internally, but you had to be told by a customer complaint that you had an issue, what would you do? The problem does state there are time and cost constraints for running DOE on all of the combination of tools and combinations. What else could be done. I'd start looking at past data and were they doing some form of statistical analysis of data on hand, and what was it about the vendor's product that caused the problem. And what are the implications for a recall?
L
LOUPEN
Thanks so much for this guidance. I really appreciate it. I think the first thing I would do is apologize to the customer. Then, I would ask for the non-conforming material to be returned for analysis. Check the date code and all quality records for that date. Also, I would check the previous and post error records to see if any established control limits have been lower or higher then normal. I am supposed to be hypothetical for all responses, problems that occurred etc. Am I on the right path? :cfingers:
Steve Prevette
Deming Disciple
Yes, I'd say now you are on the right path. Work through what you would do, and then go back and read again about the Qualifications and see what fits in what context. Keep in mind since this is an operating process, the IQ should have been completed long ago (though a good discussion is - should it have caught this problem, or do we get to assume the problem started after installation).
L
LOUPEN
I think the assumption here would be that a defect slipped through the cracks even after control limits, procedures and inspection points are established throughout the process. Am I left to assume human error? What are the steps?
puttign the IQ, OQ, PQ question back on the table, the case study is incorrect in stating that PQ requires DoEs. PQ is typically the production of 3 sequential lots at nominal process settings. the requirement for PQ acceptance is that the material meets all specified tolerances. if from a special process, a sample is taken for the destruct testing. this is when Cpk calculations are made.
DoE is used in the OQ step to validate the special process. typically a fractional factorial is used for the final validation material which is supposed to be acceptable at all combinations of the input tolerances.
yes it can appear cost prohibitive, but if one uses effective DoE, sample plans, adn leverages past knowledge of common materials and equipment, we can devise effective validation plans. (not having effective validation plans can lead to failures that can have substantial cost effect from recall/scrap to regulatory sanctions.)
L
LOUPEN
Thanks for your input! I agree with you that DoE is needed. But, in this particular case study it's not in play. What are the steps taken to go around it? That is the true question......Unless it's a "trick question"? Thoughts anyone?
T Need 5 why’s help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
T Need help understanding AS6174 clause 3.1.5. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R First Time Managing Calibration and Measurement System. Need Help. General Measurement Device and Calibration Topics 19
C Need help in determining applicable clause for an audit finding (based on AS9120B) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Attempting to Poke Yoke a wire crimping process...need help Design and Development of Products and Processes 3
C I need your help to find the action plan for these quality objectives Misc. Quality Assurance and Business Systems Related Topics 23
R Need help on calibration result analysis Measurement Uncertainty (MU) 17
G Need Help with Run @ Rate for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 0
F Need help in IMS management review Management Review Meetings and related Processes 3
S I need help in corrective action plan Nonconformance and Corrective Action 15
D Weird spec sheet - need help Measurement Uncertainty (MU) 3
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
K Screen printing ink and machine selection_ Need help Manufacturing and Related Processes 6
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
S Need help with analysing a survey on minitab Using Minitab Software 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S New to FAIR, need help in filling it out AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R Pls help --- Need expert advice on Video Measurement Measurement Uncertainty (MU) 0
Ajit Basrur Need help to understand HIPAA requirements ISO 13485:2016 - Medical Device Quality Management Systems 25
Z I need help with getting a CFS in China Manufacturing and Related Processes 2
S Need help wrapping my head around confidence vs beta error Statistical Analysis Tools, Techniques and SPC 2
P Received a minor for not having good measureables/goals. Need help with KPIs. IATF 16949 - Automotive Quality Systems Standard 52
A Failed the AS9120B Exam Twice.....Need Help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Ajit Basrur Need help in Conditional Formatting for the entire row Excel .xls Spreadsheet Templates and Tools 3
H Need help on Quality Improvement Plan (QIP) Quality Tools, Improvement and Analysis 5
S Help: Need Control Self Assessment Questionnaire for HR Departmental Functions Process Audits and Layered Process Audits 0
M Need help in Calibration of Directional Coupler General Measurement Device and Calibration Topics 2
L Need HELP with Internal Audit Program ISO 13485.2003 Quality Management System (QMS) Manuals 3
J Supporting Processes - Internal Audits - Need help settling a debate IATF 16949 - Automotive Quality Systems Standard 4
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
A Need Help With AEA Auditor Related Situational Questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Transformer Overload Test - Need help IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C I Need Help with Drafting Conventions!!! Design and Development of Products and Processes 4
M Need help on QMS Development in an AS9100C certified organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R Need Help on Analysis: How to know potential causality model from historical data Problem Solving, Root Cause Fault and Failure Analysis 5
B Need help tracking training for my business Quality Assurance and Compliance Software Tools and Solutions 3
B Need help with a Control Plan for Encapsulation Mold / Trimming / Forming Tooling FMEA and Control Plans 9
S I need help from all of you bros Oil and Gas Industry Standards and Regulations 1
LRE67 Need help identifying this "thing" Coffee Break and Water Cooler Discussions 9
G Need help on Device Description in the Acceptance Checklist for Traditional 510(k) Other US Medical Device Regulations 2
K Need help finding a book on Documentation Book, Video, Blog and Web Site Reviews and Recommendations 8
