Never been this close to a plane crash...
Randy
#21
It's really dependant on a variety of factors. The deicer only works for the leading edges of the wings and props, in areas of low air pressure ice can still form and disrupt airflow, like under the wing, or increase weight and cause an out of balance situation to occur that can modify the angle of attack by either increasing or decreasing the aircraft vertical attitude along the horizontal plane or roll due to one side being heavier than the other.
There are lots of things, small by themselves, but synergistic in their effect.
The NTSB will figure it out that's for sure
Q
quality1
#22
It really is........Can you imagine what the folks are thinking that didn't take the plane because of the delay?
A few years ago there were some icing problems with the ATR-72 that American and other airlines fly.........similar design to the Dash 8.
Anymore I prefer not to fly in weedeaters (turbo-props)...it's just me, the aircraft are safe I know, but I'll drive a few hours before I fly in one again.
Randy, do you think the design of where the wings sit and being a turbo prop contributed to this type of plane crashes in the past? I cringed everytime I get on one of these mosquitos.:(
K
Kwilson
#23
Several more turboprops landed in the exact same conditions immediately following the crahs on thursday night. According to the reports I have seen today, it may have been pilot error in trying to correct a stall.
Like was previously said, the NTSB will figure it out...
#24
When ice causes a decrease in lift, does it happen gradually or is there a point when the plane suddenly turns into a rock?
It does happen gradually, but the loss of lift is not always the major problem. That can usually be remedied by increasing speed.
Ice can also alter the airflow around control surfaces, thereby changing the flight characteristics of an aircraft. You may not notice it because you are going straight and level, but start a turn or change flap settings and you can suddenly find that you are already outside the parameters where you can do that. When that happens you can go from routine to sheer terror in no time at all.
/Claes
Randy
#25
Naw, the design is well tested..look at the C130 as an example
Turbo-prop? This bird has lots of guts, but even in a no ice situation a stall can be induced that if incorrect pilot input occurs the plane can go down faster. When falling (stall) the normal thought is to pull up, but that actually bleeds off speed faster and decreases lift, what you want to do is drop the nose and level the wings to gain speed and use the energy to help bring you out. Helicopters have a similar problem, folks want to increase pitch to pull up but that can actually bleed off inertia and the blades will stop, you really need to bottom the collective out and build rotor speed which will increase lift.
Of course there is always that point of no return where the old joke of shutting your eyes and putting you head between your knees comes in....been there a time or two.
andygr
#26
Keep in mind that the boots designed to remove ice do not over the whole control surface only the leading edge. Ice can and does build up on other surfaces that can negitivly impact the aerodynamics.
Here is a picture of what the ice build up can look like. The plane that whent down was not in as bad of conditions but it gives you an idea why pilots are warned to limit the amount of time they spend in known icing conditions.
Craig H.
#27
Holy cow. It looks like that wing would have less lift than the average paperweight.
Has anyone else heard reports that the pilot in this case did pull the nose up after the stall warning? Even I know better....
Aaron Lupo
#28
we had an auditor in this week and he was flying a turbo-prop into Newark last night on his way back home to Heathrow. He was a little less than enthused to fly yesterday. Traveling prayers to any who are traveling.
I flew to Newark from Syracuse two days before ona Dash-8, bumpy ride but no issues. I was supposed to take a dash 8 from Indy to Cleveland the next day but the plane never made it, had to turn around. I ended up flying NWA to Detroit instead.
A few months before this on my way to NYC to go to Ireland we had to make an emergency landing when we lost an engine, cabin filled with smoke lots of screaming (not sure what the other passangers were doing). First time in my flying life that I thought we were going to bite the bullet.
SteelMaiden
#29
shoot, I just took a big swallow of my diet Pepsi, now I'm wearing most of it.:lmao: I wonder what will happen when I show up at our Red Cross Blood drive soaking wet? Maybe I'll change into my gym clothes.
Randy
#30
I bit a bullet once, or was it the other way around?:lol:
Smoke while in flight is not fun. Back around '82 or '83 when I was crewing Huey's in the Guard while flying in the rain from Fort Smith to Little Rock our cabin filled up with acrid smoke (phosgene was a component) and sparks started coming out of the overhead circuit breaker panel. It seems like the contracted people who installed our wirestrike protection kit had drilled into some wire bundles and they started to short when they got wet. While I was trying to open the panel and the back doors simultaneously the guys uop front were holding their heads out their windows trying to find a landing spot .....phosgene hits your eyes like pepper spray or CN and you cough pretty good as well. In the end the boys got us to the ground outside of Adkins, AR in the middle of I-40.
Smoke in the cabin with 100 or so civilians....yeah, probably exciting;)
supadrai Possible to Submit a 510(k) if you have never, do not and cannot produce the device for which you're submitting the application? US Food and Drug Administration (FDA) 4
hockeyhead Existing process never included in AS9100 scope of certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Jim Wynne Some things never change Coffee Break and Water Cooler Discussions 2
N Variable Data Test Never Fails Capability, Accuracy and Stability - Processes, Machines, etc. 9
K 510K statement Questions 21 CFR 807.93 - Discontinued or never released for sale US Food and Drug Administration (FDA) 0
P Retired equipment that was never validated Qualification and Validation (including 21 CFR Part 11) 2
M Is calibration from long ago still valid on never used pipettes? General Measurement Device and Calibration Topics 8
A Receiving paper from the customer and never knowing when it will arrive Quality Manager and Management Related Issues 1
J Validating a stopped test due to never finding any defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R KPI Review Meetings never discusses previous meeting action plan status Quality Manager and Management Related Issues 5
G 10 Things You Should Never Say at the Office Coffee Break and Water Cooler Discussions 7
W How to withdraw a cleared (but never sold in the US) 510(k) Medical Device? Other US Medical Device Regulations 7
Wes Bucey Never give up! Career and Occupation Discussions 1
Marc Lascaux Cave Paintings - Rare And Never-Seen Photos Coffee Break and Water Cooler Discussions 4
sagai Why never to ask favours from the designers Funny Stuff - Jokes and Humour 8
Marc "Prompt Corrective Action" is never prompt and rarely truly corrective Nonconformance and Corrective Action 48
S Why should we never re-use an identification number for a replacement M&TE? General Measurement Device and Calibration Topics 7
Jim Wynne Why You Should Never Depend on Babel Fish for Language Translations Funny Stuff - Jokes and Humour 6
SteelMaiden Some people never learn. Coffee Break and Water Cooler Discussions 4
bio_subbu Never happen in life again??!!!! Coffee Break and Water Cooler Discussions 4
Marc Security Firms Fined Over Never-Ending Subscriptions After Work and Weekend Discussion Topics 0
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
J What to do if equipment IQ and OQ were never signed off ? Nonconformance and Corrective Action 4
Jim Wynne Never believe early news reports Coffee Break and Water Cooler Discussions 7
B Retiring Early or Never? Coffee Break and Water Cooler Discussions 65
Wayne Never put an Expiration (Due) Date on a Calibration Certificate Calibration Frequency (Interval) 41
Marc Never Give Up.... Funny Stuff - Jokes and Humour 6
C Acceptance sampling should never be used for processes in statistical control Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Never though ordering breakfast was so difficult! Funny Stuff - Jokes and Humour 0
D Unique user ID under ISO 27001 - ID can never ever be reissued to another user? Other ISO and International Standards and European Regulations 7
R LOST...the TV show - Why have we never discussed "LOST"? Coffee Break and Water Cooler Discussions 23
A Never question a drunk Funny Stuff - Jokes and Humour 4
I How many fail ALL ISO 9001 registration audits - How many never make it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 46
C Are Purchase Orders required for 7.4? Company never issues POs and never has. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I Records that never were a document...? Shipping Labels and Computer 'Screens'? Records and Data - Quality, Legal and Other Evidence 7
B Logistics FMEA - Never Have done One - Need Ideas FMEA and Control Plans 12
S Approval For Standard OEM Parts - I am never quite sure how we should submit approval Customer and Company Specific Requirements 3
D 6.2.2 e - Minimum education requirements for workers? Some never went to school! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
R When can you stop root cause analysis - Is the answer never? Problem Solving, Root Cause Fault and Failure Analysis 6
Marc ITS - Intertek - Fraud? NEVER!!! Philosophy, Gurus, Innovation and Evolution 4
L Have been purchased by a corporate company ISO 13485:2016 - Medical Device Quality Management Systems 7
Louddogsbark When your 13485:2016 certificate has been pulled ISO 13485:2016 - Medical Device Quality Management Systems 2
lanley liao What shoud i do if our company top management has been changed. Oil and Gas Industry Standards and Regulations 8
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
M Has anyone has been through an MDR audit? (3/2020) EU Medical Device Regulations 1
V What plans have been put in place to achieve quality objectives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Richard Regalado ISO 22301:2019 has been published - Nov 2019 Business Continuity & Resiliency Planning (BCRP) 0
D Validation of existing equipment - I have been asked to write a quality assessment for equipment ISO 13485:2016 - Medical Device Quality Management Systems 13
A Would an MRP system that has been in use for over 10 years require validation? ISO 13485:2016 - Medical Device Quality Management Systems 6
R I've been auditing for a CB for 18 years General Auditing Discussions 10
