Never put an Expiration (Due) Date on a Calibration Certificate
Dan Armstrong
#21
Americans have been bullied into believing that oil changes are necessary every 3000 miles, rather than following the manufacturer's recommendations. Toyota recommends 7500 miles between changes for my Camry under normal service, and 5000 miles under heavy service. Of course, that doesn't mean you don't check the oil level between changes.
ScottBP
#22
The truck I used to have had a check engine light that turned on after 50,000 miles, so I took it to the dealer, and they did diagnostic tests and said there was nothing wrong, that the light comes on after 50,000 miles as a reminder to have it serviced. Then they charged me 50 bucks to turn the light off. :mad: But that's exactly what happens with some electronic test equipment nowadays, it'll actually say on screen that the calibration is due, and you have to send it out to have it reset, whether the instrument is reading in tolerance or not. And some metrology software, such as Fluke's MET/CAL won't let you run a calibration procedure if one of the instruments that it uses and reports on its printed certificates has expired. Imagine if your car wouldn't let you start it if the oil hadn't been changed past its recommended interval! :mad:
JerryStem
#23
We had a major "thing" about this after our latest 17025 audit earlier this year (well, late last year but it took till Feb to conclude.)
My boss/bosses want the date because they think Mr Customer will only return their calibration standards and/or instrument if we have an expiration date. I say nonsense, they wait as long as they want anyway. Some put their own stickers over ours too.
I changed our cert's to have N/A in the Due Date area, with an explanation about how things can affect the calibration over time. But left a space to put a date if the customer wanted it. I thought the bosses agreed to this during the audit.
Boy was I wrong, they threw a fit I had done this. I had to redo about 30-40 cert's with the regular 1yr or 6mo interval and explain why to the customer.
Now we are using the clause that says the customer agrees to it, and basically if it's been going on for 5 years at 1yr intervals, that's what he's agreeing to. I put on the workorder somewhere the description of the item and "annual certification". If they pay the bill, they've agreed to it.
Cheesy, but the bosses are happy. Whatever...
crendfrey
#24
I agree, and thanks to Wayne for raising an interesting topic.
We need to not forget that part of the information we receive from calibration is the "as found" condition, and we should be using it wisely.
The problem, as I see it, is one of education; people need to know that the due date on the label represents a maximum and not an absolute value. This seems obvious, and I think most people understand that there is risk in assuming that devices are properly calibrated when the state of calibration isn't intuitive. But you can't get people to use measurement equipment prudently by masking significant information.
Our calibration forms/ certs (one and the same to us) contain full calibration data as well as the defined user range including min and max user loads and resolutions. They also do contain the contracted intervals of calibration and the month/year of next inspection.
Customer education is the key to care and maintenance of equipment.
Many standards require interim checks of equipment. We also suggest this to our customers who have sensitive equipment.
Type and correct use of the equipment will establish its ability to hold calibration.
Our due dates are simply a statement to the customer we will be back in this month and year to calibrate unless you call us back for some reason. (user suspicion device is off, user broke it:mg:, starting new run and need documentation)
Customer has everything they need on one piece of paper for each scale including when we will be back. This enables them to do their due diligence as required. BTW dates are on stickers as a reminder to customer and apparently auditors and such like to see them.
Rajeeva
Quality Manager, CMQ/OE, CQA
#25
Dear Mr. Wayne,
Thanks for this interesting topic. To be honest, I am not able to take position as I feel both for and counter points are right in their own perspective.
Yes, I do agree that there is no guarantee that the calibration is valid after it leaves the lab and so, the relevance of expiry date is gone. But, I also agree that the expiry dates should be specified on both certificate and equipment as it indicates to the user about the risks involved when the equipment is nearer to re-calibration/ re-inspection.
When we agree that the calibration due date is not required on the certificate & equipment, in one way we are saying that the trust worthiness of that equipment is gone and we are not sure of the results of testing/ measurement. This is not a healthy sign and it results in blame game when process inspection indicates the non-conformance in the product.
Definitely, internal checks are required but one can not apply to all testing/ inspection/ measuring equipment. It should be on case to case basis and depending upon the use, kind and volume of production, the frequency of recalibration could be increased/ decreased.
If any error is detected during the recalibration and at-least we could initiate the corrective action immediately and minimize the damage to the product/ Company reputation and rectify the defective products as we can trace them by specifying the IMT equipment ID # on the quality record. Probably that might be the reason why ISO 9001:2000 Clause 7.6a requires recalibration at specified intervals.
I personally feel that the Quality personnel are best to judge the interval as they know the usage and importance of testing.
Rajeev
K
k_srinivasan66
#26
Calibration status stickers with due dates affixed on instruments is for the user to know when the calibration date is due.
According to 17025, the due date for calibration need not be specified in the calibration report
amanbhai
#27
For my part, I had only the date of calibration/certification put on the label or tag, never a due date. To my mind, the interval between calibration/certification dates doesn't even start until the gage/instrument is put into service. Some gages might lay in a drawer in a temperature-controlled lab for 6 months before going into use. I kept track of usage in a database keyed to serial numbers of each gage or instrument. If the gage got excessive use, it got checked more frequently in-house to confirm it was still within tolerance.
I have had some gages go out of tolerance very quickly. I heard an apocryphal story about employees using a 2-inch micrometer as a nut cracker!
:notme:
Is this formula of not mentining the next due date of calibration is for all kinds of equipment or there is any exceptions?:thanks:
Daniel Walker - 2011
#28
whoa, whoa, whoa.......
17025 standard CLEARLY states that a calibration due date CANNOT be reported on a certificate or sticker unless requested by the customer. If you are putting due dates on the equipment that wasn't OK'd by the customer you are breaking the rules.
I think I saw a thread regarding calibration intervals. Are we not basing our recommendation to the customer on past performance??? If a device is tested every week and it only fails once a year, are we not suggesting that the customer lengthen the calibration interval to 90 or 180 days??
If a device is tested once every 2 years and hasn't passed a test in 10 years, then the customer should be STRONGLY encouraged to shorten their cal interval. It is the customer's responsibility to set the calibration interval. A 17025 accredited lab CANNOT state a due date without the customer's approval.
Also- Are we the only lab that has this statement on our certs?: "Documented results contained within this calibration certificate relate only to the artifacts calibrated on the date listed."
#30
You calibrate artifacts?
I was really expecting to see a funny face after that question, Jim.
Or, wait, this is better....:sarcasm:
I'll bite anyway....
Yes, we refer to items that are in our lab to be calibrated as artifacts. That is, in written procedures and statements such as the one above. Not in daily conversations, of course... We're not that crazy.:bonk:
supadrai Possible to Submit a 510(k) if you have never, do not and cannot produce the device for which you're submitting the application? US Food and Drug Administration (FDA) 4
hockeyhead Existing process never included in AS9100 scope of certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Jim Wynne Some things never change Coffee Break and Water Cooler Discussions 2
N Variable Data Test Never Fails Capability, Accuracy and Stability - Processes, Machines, etc. 9
K 510K statement Questions 21 CFR 807.93 - Discontinued or never released for sale US Food and Drug Administration (FDA) 0
P Retired equipment that was never validated Qualification and Validation (including 21 CFR Part 11) 2
M Is calibration from long ago still valid on never used pipettes? General Measurement Device and Calibration Topics 8
A Receiving paper from the customer and never knowing when it will arrive Quality Manager and Management Related Issues 1
J Validating a stopped test due to never finding any defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R KPI Review Meetings never discusses previous meeting action plan status Quality Manager and Management Related Issues 5
G 10 Things You Should Never Say at the Office Coffee Break and Water Cooler Discussions 7
W How to withdraw a cleared (but never sold in the US) 510(k) Medical Device? Other US Medical Device Regulations 7
Wes Bucey Never give up! Career and Occupation Discussions 1
Marc Lascaux Cave Paintings - Rare And Never-Seen Photos Coffee Break and Water Cooler Discussions 4
sagai Why never to ask favours from the designers Funny Stuff - Jokes and Humour 8
Marc "Prompt Corrective Action" is never prompt and rarely truly corrective Nonconformance and Corrective Action 48
S Why should we never re-use an identification number for a replacement M&TE? General Measurement Device and Calibration Topics 7
Jim Wynne Why You Should Never Depend on Babel Fish for Language Translations Funny Stuff - Jokes and Humour 6
SteelMaiden Some people never learn. Coffee Break and Water Cooler Discussions 4
bio_subbu Never happen in life again??!!!! Coffee Break and Water Cooler Discussions 4
Marc Security Firms Fined Over Never-Ending Subscriptions After Work and Weekend Discussion Topics 0
K Never been this close to a plane crash... Coffee Break and Water Cooler Discussions 38
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
J What to do if equipment IQ and OQ were never signed off ? Nonconformance and Corrective Action 4
Jim Wynne Never believe early news reports Coffee Break and Water Cooler Discussions 7
B Retiring Early or Never? Coffee Break and Water Cooler Discussions 65
Marc Never Give Up.... Funny Stuff - Jokes and Humour 6
C Acceptance sampling should never be used for processes in statistical control Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Never though ordering breakfast was so difficult! Funny Stuff - Jokes and Humour 0
D Unique user ID under ISO 27001 - ID can never ever be reissued to another user? Other ISO and International Standards and European Regulations 7
R LOST...the TV show - Why have we never discussed "LOST"? Coffee Break and Water Cooler Discussions 23
A Never question a drunk Funny Stuff - Jokes and Humour 4
I How many fail ALL ISO 9001 registration audits - How many never make it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 46
C Are Purchase Orders required for 7.4? Company never issues POs and never has. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I Records that never were a document...? Shipping Labels and Computer 'Screens'? Records and Data - Quality, Legal and Other Evidence 7
B Logistics FMEA - Never Have done One - Need Ideas FMEA and Control Plans 12
S Approval For Standard OEM Parts - I am never quite sure how we should submit approval Customer and Company Specific Requirements 3
D 6.2.2 e - Minimum education requirements for workers? Some never went to school! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
R When can you stop root cause analysis - Is the answer never? Problem Solving, Root Cause Fault and Failure Analysis 6
Marc ITS - Intertek - Fraud? NEVER!!! Philosophy, Gurus, Innovation and Evolution 4
A Can a US manufacturer put export only products on a CFG? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Hiring Decisions - How much effort do you put into the hiring process these days? (7/2020) Misc. Quality Assurance and Business Systems Related Topics 6
C Is it required to put"Rx only" on the home page of an app? Medical Device and FDA Regulations and Standards News 4
V What plans have been put in place to achieve quality objectives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G What information to put on measurement Dimensional Results APQP and PPAP 7
bryan willemot Looking for a good CoC to put with my certification sheets when we send parts Document Control Systems, Procedures, Forms and Templates 1
Z Do we still have to put UDI if we have DI and lot number seperately on our product ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D QMS Documentation Process - I want to put all the Process SOPs to a QMS system Document Control Systems, Procedures, Forms and Templates 3
C What are rules to notify customers if IATF cert is put on hold? IATF 16949 - Automotive Quality Systems Standard 2
C IATF 16949 : 2016 - How put in place a Containment for this kind of Major NC IATF 16949 - Automotive Quality Systems Standard 14
