Informational New AIAG PFMEA Process - Excel Template Attached
Bill Levinson
Industrial Statistician and Trainer
The new AIAG manuals are definitely worth reading; there have been significant changes since the 1990s. Guidance on the occurrence and detection ratings is better, and they also look at severity ratings for the process (e.g. potential risk to workers, continuity of operations) as well as the product.
toniriazor
Hello all,
can someone please explain what is the main reason to replace RPN with Action priority ? How Action Priority is better than RPN ?
Thank you in advance.
Bill Levinson
Hello all,
RPN is the product of three ordinal numbers. A failure mode with severity = 10, occurrence 4 and detection 5 has a RPN of 200, as does one with S=4, O=5, and D=10. The latter can at most annoy the customer while the former can kill him. Action Priority gives the severity the biggest weight, followed by occurrence, and finally detection. This stresses that it is best to eliminate or mitigate the failure effect, next best to prevent it, and finally to detect it before it can actually cause trouble.
One thing I am uncomfortable with is the proposition that you can have a S=10 failure mode with a Low action priority with O and D ratings of greater than 1 (although they must be relatively low).
toniriazor
hello again thanks for info.
at the company where I work we are far from using new PFMEA approach and far from replacing RPN with AP.
How exactly will this become mandatory? Maybe update of customer specific requirements ? Any thoughts about this ? How in the past such transition was managed ?
Pau Calvo
I have been hearing the transition to AP for the last few years in some seminars regarding FMEA.
In my actual company, Tier 2, none of the customers have required the implementation yet but in a previous company that I have work a customer ask for this evaluation even before the last version of FMEA handbook was released.
It would depend of how many new projects, how many customers make the transition and how often you review and update the FMEA that you will reach the point to change the FMEA evaluation for all the customers.
My recommendation is to follow your customer requeriments and have a template prepared with the new evaluation method and a Action Plan of implementation.
This way you will not get surprises and your answer to your customer will be agile.
bobdoering
Stop X-bar/R Madness!!
Generally, you customers will tell you when they will begin demanding the 1st edition AIAG/VDA approach. However, you will want trained on it ahead of time, because the resources you will need to complete one is much, much greater and you won't want to struggle through it on your own with a deadline to submit closing in.
toniriazor
thanks for answers
i think no new analysis on existing projects need to be done right ? Can you just carry on with current PFMEA and change the RPN with AP and mitigate risk for failures with high severity, occurrence and finally detection or you need to start from scratch with enterely new PFMEA ?
I also think the company should be informed well in advance if the customer is requesting risk analysis based on the new handbook for upcoming projects although customers not always care about their suppliers and might forget this "small" detail.
K Where to put product and process characteristic in PFMEA (AIAG Manual 4th edition)? FMEA and Control Plans 6
L PFMEA (Process FMEA) issue about lower RPN - AIAG 3rd edition page 55 FMEA and Control Plans 13
S PFMEA Form - What forces you to use the AIAG form for Process FMEA? FMEA and Control Plans 4
A PFMEA new AIAG FMEA and Control Plans 0
Z Failure Mode Identification in PFMEA according to AIAG FMEA Rev.4 FMEA and Control Plans 6
D AIAG FMEA 4? Ed. Explanation: Relationship between PFMEA and Special Characteristics FMEA and Control Plans 8
G AIAG PFMEA (3rd edition) Severity Rankings - Define a "portion of the product" FMEA and Control Plans 3
M PFMEA Detection Evaluation Criteria - Visual Check - Page 52 of the AIAG FMEA manual FMEA and Control Plans 2
O AIAG VDA DFMEA Template Required FMEA and Control Plans 2
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 2
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 5
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
S AIAG CQI Auditor Qualification and 3rd Party Certification Requirements General Auditing Discussions 2
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
D FMEA-MSR in the AIAG-VDA Aligned Handbook - What is it? FMEA and Control Plans 5
bobdoering AIAG VDA FMEA Handbook - 2019 - something familiar about this.... FMEA and Control Plans 37
S New AIAG FMEA Process - How to complete the new format FMEA and Control Plans 32
C Detection Action for Failure Effects - AIAG 4th Edition Layout FMEA and Control Plans 5
S I have just purchased the all new Core Tools Software (CTS) from AIAG IATF 16949 - Automotive Quality Systems Standard 37
J AIAG PPAP: 2.2.11.3 Acceptance Criteria for Initial Study (page 9, 4th edition) APQP and PPAP 1
M Is there a published List of AIAG members requiring IATF certification ? IATF 16949 - Automotive Quality Systems Standard 2
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I AIAG 2018 Quality Summit - Is it worth it? IATF 16949 - Automotive Quality Systems Standard 3
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
G AIAG FMEA - Major customers of the FMEA process FMEA and Control Plans 3
R Information on the roll out of the new harmonized DRAFT FMEA AIAG/VDA manual IATF 16949 - Automotive Quality Systems Standard 4
H Prerequisites for AIAG APQP/PPAP Certification Exam Training - Internal, External, Online and Distance Learning 2
xfngrs What are the VDA equivalents to AIAG manuals? VDA Standards - Germany's Automotive Standards 1
Marc When will Revision 5 of the AIAG FMEA Manual be released? FMEA and Control Plans 93
S Pre-release version of the upcoming AIAG FMEA Revision 5 FMEA and Control Plans 1
C PPAP Rejection for "MSA-GR&R are not using the latest AIAG format" APQP and PPAP 9
kedarg6500 Excel Spreadsheet for AIAG Example wanted Excel .xls Spreadsheet Templates and Tools 3
N AIAG 4th ed. FMEA Manual "Fit" Changed to "Appearance" - Fit severity? FMEA and Control Plans 2
G AIAG CQI-Audits and Auditor Training ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
B New to Metrology and told to complete Gage R&R with AIAG compliant software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
M Where to buy AIAG Manuals ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
S Service Parts PPAP AIAG Manual - Opinions APQP and PPAP 4
L AIAG B-10 Labeling Standard vs. VDA 4902 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
xfngrs New AIAG Special Molding Assessment CQI-23 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 17
O Any recommendations on good book on Control Plans besides AIAG? FMEA and Control Plans 3
Stijloor AIAG Layered Process Audit 2nd Ed. (CQI-8) is now available. IATF 16949 - Automotive Quality Systems Standard 1
K 4th Edition AIAG FMEA Occurrence, Severity and Detection Criteria for Plastics FMEA and Control Plans 1
