New AS9102 Rev B--CA vs UAI--purist vs. pragmatic
Will you face a similar issue with UAI vs CA on FAI?
  • Yes, my organization has similar situations
    Votes: 0 0.0%
  • No, my organization would never have a similar issue.
    Votes: 0 0.0%
  • Total voters
    1
B4Quality
I've recently been asked (as an external internal audit resource) to weigh in on the more "specific" wording in regards to Nonconformance Handling. My sense is that the intent of the Standard has not changed from Rev A to Rev B, although the changes in wording may imply a stricter requirement. I spend more time in statistical process capability assessment than FAI, so bearing with the ludicrous premise that 1 "representative" part can be a valid way to establish whether a process is capable, here is the question on which I'd very much appreciate some Forum member opinions:
[FONT=&quot]AS9102 Rev B Requirement Excerpt[/FONT][FONT=&quot]: 4.4 Nonconformance Handling[/FONT]
[FONT=&quot]a. The FAI with design characteristic nonconformance(s) is ?not complete?. An FAI with noted nonconforming design characteristics may have Form 1, ?Part Number Accountability?, (see field 19) signed and shall be noted as ?FAI Not Complete?.[/FONT]
[FONT=&quot]?[/FONT]
[FONT=&quot]c. The organization shall implement corrective action(s) and perform a partial FAI for all affected characteristics on the next production run, after implementation of the associated corrective action(s). If the partial FAI does not clear all identified nonconformances, the FAI is still ?not complete? and the requirement to complete the FAI is still in effect.[/FONT]
[FONT=&quot]Context[/FONT][FONT=&quot]: In an AS9100 Revision C QMS, the nonconforming design characteristic(s) would be dispositioned per 8.3 Control of Nonconforming Product. A possible disposition per 8.3 is ?Use As Is (UAI)? if authorized by the organization responsible for design, and if required by contract, by the customer.[/FONT]
[FONT=&quot]The next consideration, per 8.5 Corrective Action, would be to determine if corrective action is warranted. Corrective actions are to be ?appropriate to the effects of the nonconformities encountered? and the requirement includes ?evaluating the need for action to ensure the nonconformities do not recur.?[/FONT]
[FONT=&quot]Question[/FONT][FONT=&quot]: What if, in the UAI scenario above, the nonconformance investigation performed by the organization responsible for design (and approved as required by the customer) determines that the associated product realization processes do not need corrective actions and that there is sufficient confidence (based on investigation/analysis of the NC) that the product realization processes are capable of producing conforming parts. Would the FAI then be considered complete, without the need for an additional production run?[/FONT]
In a pure sense, of course "corrective action" should always be pursued. In a pragmatic sense, if a customer orders a handful of parts, all are built at once in the pre-production run and there won't be another order for many months or even a year or two, should the FAI (and potentially shipment) be held up for a minor dimensional NC that will not affect form, fit or function? And further, let's say the customer agrees to open up the tolerance band and allow a drawing change, does the supplier still have to wait for a "next production run" to complete the FAI?
Stijloor
A Quick Bump!
Can someone help?
If your questions were answered here, please consider helping others.
Thank you very much!
dsanabria
While I enjoy the reading - you went to deep in this requirement. Block 19 is used on form 1 and it is for the purpose of notifying customer, auditors and those interested that during the production aspect an NCR was written (Form 3) and thus the block "NOT COMPLETE" is checked.
The interpretation of that blocks means that if it is checked then a "DELTA" or partial FAIR per AS9102 has been done and should be attached.
It would also indicate that corrections were made to the process and no additional NCR would be produced by this process for that particular issue.
S AS9102 - Clarification - PO asking for an Assembly at Rev B (Print at Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Does anyone know when AS9102 Rev B will be released? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
O AS9102 (rev.a) First Article Inspection Requirement Quality Manager and Management Related Issues 1
D AS9102 and proprietary info AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M AS9102 Form 1 Questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
briteme4 AS9102 FAIR Requirement AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
briteme4 AS9102 First Article Inspection - do I need a second reviewer and signer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B AS9102 - 3D printing a special tool required for assembly (counterfeit risk?) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
P AS9102 Form 3 Inclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Conformal Coating & AS9102 - Is conformal coating material a COTS part AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B AS9102 COTS Form 1 vs. 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B AS9102 Supplier Flow Down Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L AS9102 Form 1 Section 13 Detail or Assembly Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
W FAIR to AS9102 additional documentation Document Control Systems, Procedures, Forms and Templates 5
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
R AS9102 - Are FAIs against a Customer Red-Lined Drawings Allowed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 - What needs to be Bubbled on a Contract or Purchase Order AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9102 Form 2 Information - Special Processes - Plating AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M AS9102 Training - Seeking third party agency that provides online AS9102 training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C AS9102 FAIR Form 1 Content Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Qualification Builds & Process Changes (AS9102 - First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R Accounting for Alternate Parts in AS9102 FAIs for Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S When to switch from a Partial AS9102 back to a Full AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S AS9102 Aerospace First Article Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R When is a new AS9102 report required for Outsourced Processing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M AS9102 Form #3 modification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G AS9102 Design Supplier Part Number vs. Customer Part Number AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
WCHorn AS9102 Paragraph 5.3-5 - Lapse in Production - FAI Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
C Customer Documentation Errors when completing an AS9102 FAIR AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
W AS9102 Requirements - What information from the PO should be included in the FAIR? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S AS9102 Interpretation on Form 2 field 6 - Specification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
