New AS9120 Questions - Distributor - Is 7.5.1 applicable?
ACEQuality
Hello Everyone!!
We have been registered AS9100 for the last 6 years but we are currently switching to the AS9120 because it is more suitable for this company. We are a distributor only, we do no production or service (at least i think, depending on how it is defined).
So that brings me to my question, 7.5.1, is it applicable? We bring parts in, label them and ship them out. We also do a small amount of kitting. We provide a service, but is service in the standard defined as servicing? Thank You.
ACEQuality
Also while going through this, I dont see any First Article requirements. In our old AS9100 manual we stated as a distributor we do provide FAI. That being said and since the Purchase Order calls out for it, do i pass this requirement down to my vendor? I know these are all questions that are probably first hand knowledge and I am sorry to waste some peoples time, but I am in crunch time and wanted to see if i could get these few things cleared up. Thanks!
Big Jim
I believe that you cannot claim 7.5.1 as an exclusion.
AS9120 is a bit unique in that it lists what you cac claim for an exclusion. 7.5.1 isn't in the list.
Further, as a distributor or "stockist distributor" your product is distribution. This distribution must take place under controlled conditions.
howste
Thaumaturge
AS9120 does not have first article requirements. However if your customer requires it, and you accept the order, then you need to do it anyway. In any case where the customer doesn't require a first article, you don't.
I disagree. The requirements for exclusion (clause 1.2) are the same as in AS9100. The difference is that in AS9120 clause 1.1 it states that 7.1, 7.3, and 7.5.2 are always excluded.
Agreed. In this case it's service provision. It could also be splitting packages into smaller quantities or repackaging, if that's done by the company.
ACEQuality
First off, thank you all for responding, I just dont have anyone here in this small company to bounce these questions off of.
If we were to accept an order requiring the FAI, and our manual says we do not perform FAI, then would I then pass this requirement down to the manufacturer, or would I be required to perform the FAI. My understanding of FAI is that on the first run of the part must list materials, technical data (were applicable), and test data. All information we, as a distributor, would not have. If we were required, I assume we could list physical characteristics matched to the drawing?
Thanks again.
raybor
FAI goes much deeper than simple physical characteristics. It verifies all processes, certifications, receiving of primary part, handling, production, testing, packaging, etc., etc.. Basically from "input to output" (final product). I have found that most major component suppliers will willingly forward FAI authorization and documentation when requested. So, as a distributer, just ask them. I hope that they have a positive answer.
ACEQuality
Thats what I would assume since we as the distributor have no idea where the raw materials came from or functionality of the part. That is something only the manufacturer would know. Our large customers require first article at times and want us to provide it and we would just pass this request down to the manufacturer. Though we have run into a customer that wanted our company's FAI which after several weeks back and forth we just couldnt provide. That is why I had asked if literally we could even complete such a document. Thanks guys for your responses.
N From 0 to AS9120 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
T Was Just told we could ONLY buy material for AS9100 customers if the DISTRIBUTION house is AS9100 / AS9120 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
Q AS9120 7.5.3.2 Control of Documented Information - Audit Nonconformance AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 20
Q AS9120 Vendor of ESD Monitoring Equipment needs to be in the Approved Supplier List? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
A AS9120 External Provider Registry Scope of Approvals AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
howste AS9120 Rev B has been released and is available for purchase - November 2016 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
B AS9120 Internal Audit Scheduling & Planning AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
M Does AS9120 (aerospace first article inspection) apply to all customers AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
H AS9120 stockist now able to work with Airbus sub contractors? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
G AS9120 Purchase Department Performance Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
G AS9120 - What should we be expecting once we set forth into becoming certified? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
TrivialSublime TUV Rheinland voluntarily suspending their ANAB accreditation to AS9100/AS9120. Registrars and Notified Bodies 19
N Do I need to certify to AS9100 or AS9120? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
J Verification of AC0056A requirement during AS9120 audit AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
P Parts Salvage, Overhaul and Resale - AS9120 Registration question AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
L Registration to AS9120 Rev. A timeline AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
C As9120 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
M Purchasing Process - AS9120 Clause 7.4.1 - What do they want?! AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
Sidney Vianna AS9120 Revision A has been released AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 14
M AS9120 Requirements for for Freight Forwarders (eg no batch splitting) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
M AS9120 Certification Process AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 14
F Should I remove references to AS9120 / ISO 9001 from my Quality Manual and QMS? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
S AS9120 Request AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
V Interesting quiz, case studies or exercises for AS9120 needed AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
V Has AS9120:2002 been replaced by AS9120:2005? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
V What Training is Required to be a Qualified AS9120 Internal Auditor AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 14
Sidney Vianna AS9120 - Should planning of product realization be excluded? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
A Upgrading from ISO9001:2000 to AS9120 - Difficulties? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 17
V Can anyone explain the extra requirements of AS9120 vs. AS9100? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
Marc AS9120 - Designed for aerospace suppliers known as "stockist distributors" Design and Development of Products and Processes 3
P EN/AS9100 vs. EN/AS9120 - Can we be both? EN/AS9100 Requirements Exceed EN/AS9120? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
Sidney Vianna AS9003 and AS9120 - First Accredited Registrars for AS9003 and AS9120. Various Other Specifications, Standards, and related Requirements 5
Sidney Vianna AS/EN/SJAC AS9120 - Aerospace Requirements for Stockist Distributors - Now available AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
M Quality Metrics Questions Lean in Manufacturing and Service Industries 2
K FDA Premarket Cybersecurity Guidance - 4 questions Other US Medical Device Regulations 2
A Some questions about voluntary consensus standards in traditional 510(k) submission US Food and Drug Administration (FDA) 6
T AMS2570E certification equipment questions AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
Mr Roo ISO 9001 - 7.1.3 Infrastructure - questions concerning evidence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
M Medical Device Identification & Codes - Article 27 Requirements questions EU Medical Device Regulations 1
Q Asset / Tooling Management - Two Questions Manufacturing and Related Processes 3
Q VDA 6.3 questions vs IATF 16949 clauses VDA Standards - Germany's Automotive Standards 0
I Questions to ask when auditing for Organizational Leadership and Planning for the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO13485:2016 name and ownership changes questions ISO 13485:2016 - Medical Device Quality Management Systems 2
C CQA Test Questions Bank General Auditing Discussions 1
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Informational EU – EMA revised guidance – Questions & Answers on Implementation of the Medical Devices and In Vitro Diagnostic Medical Devices Regulations ((EU) 201 Medical Device and FDA Regulations and Standards News 2
M Informational EU – MDCG 2019-6 v2 Questions and answers: Requirements relating to notified bodies Medical Device and FDA Regulations and Standards News 0
Ed Panek Relevant questions on Substantial Change Form CE Marking (Conformité Européene) / CB Scheme 3
K Beginner in ISO 45001 here! Three questions Occupational Health & Safety Management Standards 6
