New edition of IEC 60601-1 - Risk assessment to determine the liquid - 11.6.3
celia4237
In the subclause 11.6.3, how to use risk assessment to determin the liquid type, volume, duration and location of the spill.
That is a common problem, how to use risk management to determin test parameter?
Marcelo
Re: Question about new edition of IEC 60601-1
This is, i think THE main problem with using the new series of IEC 60601 standards: how to use standards requirements in conjunction with a risk management framework.
Well, trying not to complicate too much: the requirements of safety standards are risk controls options for manufacturers. So, in in the first place you would have to identify hazardous situations (in my present view, i would derive the hazardous situation from a requirement on a requirements management process or from a further hazard identification process ), estimate risk, define that the risk of the hazardous situation is unnaceptable using your risk acceptability criteria, and then you would need to apply a risk control option. This is where the standard requirement would come in. You have a lot of technical options to control the risk, but the safety standard requirement is the easiest because someone has already though about it. Then you would have to implement the control, and verify the implementation and effectiveness of the control measure. If you did not use the safety standard requirement, you would have to create a "test" to verify both. As you has used the easiest way, things just happen to be a little more easier, because, besides giving a risk control measure option (the requirement itself) the standard also give you the way to verify the implementation and effectiveness (the test method). Only problem is, some test methods parameters can vary, because of different environmental conditions for example...so, you only need to define the right parameters to verify the implementation and effectiveness of your risk control measure option.
All this information, surely, will need to be in your product risk management file.
celia4237
mmantunes, thank you very much. It is really a good response and gives me some useful guide.
It is really interesting for me in the process of learning IEC 60601-1.
Tiago Alfenas
Good afternoon, Celia.
I'm new to the 14971 area, I came across this requirement 11.6.3 and I do not know how to treat it.
Could you give me an explanation of how you did it? Thanks for listening
Al Rosen
Tiago, this thread is over 10 years old and celia is no longer active. I would suggest that you start a new thread.
T IEC 60601-1 vs IEC 60601-1-2 4th Edition Other ISO and International Standards and European Regulations 1
Ed Panek Transition to IEC 60601 4th Edition - Risk Analysis and test submissions CE Marking (Conformité Européene) / CB Scheme 2
O IEC 60601-1-2 4th edition transition deadline Dec 31 2018 CE Marking (Conformité Européene) / CB Scheme 1
T IEC 60601 3.1 edition Gap Analysis wanted IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
T List of Tests - IEC 61010-1, 3rd edition and IEC 60601-1, 3.1 edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
T What is PESS? Cited in Edition 3.1 of IEC 60601, clause 14.1 note 2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
G What edition of the IEC 60601-1 standard is required? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
T Is a new edition of the IEC 60601 in preparation for 2019 (Amendment 2)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Using IEC 60601-1 2nd Edition for "Evaluations" IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E IEC 60601-2-25 Reference to 60601-1 2nd Edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R IEC 60601-1 4th Edition - Is a "Red-line" version available? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
P FDA's deadline for IEC 60601-1 3.1 edition compliance - Aug 1, 2016 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E IEC 60601-1 3?EDITION IN VENEZUELA and COLOMBIA IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
L IEC 60601-1 Amendment 1 3rd Edition and Brazil ABNT NBR IEC 60601-1:2010 IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
M Reducing cost of IEC 60601 3rd edition testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
B Did UL 60601-1 change when the IEC 60601-1 standard changed to the 3rd edition? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
L IEC 60601-1 3rd edition Clause 9.2.2 Trapping Zone (Acceptable Gaps) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Recognition of and Transition to IEC 60601-1 3rd Edition in Korea IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J IEC 60601 Third Edition Labeling Requirements - Section 5.2.2.1 (g) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Which IEC 60601-1 Edition applies in different countries IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B When is Compliance required for 4th edition IEC 60601-1-2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
E FDA Implementation Date for IEC 60601 - 3rd Edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
T Infusion Pump and IEC 60601 2nd edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
N IEC 60601-1 , 3rd edition and the FDA - Special 510k to my updated Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 40
S Are you struggling with your IEC 60601-1 3rd edition testing lab? IEC 60601 - Medical Electrical Equipment Safety Standards Series 16
A Essential Performance in IEC 3rd edition of the 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R IEC 62133 to satisfy 60601-1 3rd edition - What happen to 60086-4 Other Medical Device Related Standards 18
J EMC (Electromagnetic Compatibility) Requirements - IEC 60601 3rd edition Clause 17 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
thisby_ IEC 60601-1 3rd edition Transition Period - US vs. Europe US Food and Drug Administration (FDA) 5
M Rework Devices placed on the market - IEC 60601-1 Requirements 3rd edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
T IEC 60601-2-27 - Comparison of 2nd to 3rd edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
W Is there an IEC 60601 3rd Edition 1st Amendment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B IEC 60601-1 3rd Edition adoption - I cant find this standard on the ISO page Reliability Analysis - Predictions, Testing and Standards 9
I Acceptability of Existing Devices complying to IEC 60601-1 2nd Edition after Jun'2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
R Switching Power Supplies Certified to IEC 60601 3rd Edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
B IEC 60601-1 2nd Clause 17 and 3rd edition - Electrical Isolation IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Current Products on the Market and IEC 60601 3rd Edition Safety Re-Test Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
M 60601-1 3rd Edition Compliance with Particular Standards & Equivalency IEC/EN stds EU Medical Device Regulations 6
E Retrofitting Risk Management for IEC EN 60601 3rd Edition Compliance IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
J Acceptance of IEC EN 60601-1 3rd edition in China China Medical Device Regulations 8
J IECEE Guidance Document for ISO 14971 Risk Analysis - IEC EN 60601-1:2005 3rd edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M UL (Underwriters Laboratories) Publishes IEC 60601 3rd edition FAQs IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
H IEC 60601-1 3rd Edition Certification - New Products Only? IEC 60601 - Medical Electrical Equipment Safety Standards Series 25
B IEC 60601 3rd Edition - Test Report Form UL uses for testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
J IEC EN 60601 3rd edition CF vs. CFD IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
L When IEC 60601-1 2nd edition can not be used for CE mark medical device application? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M IEC 60601-1-3 2nd Edition (X-ray Radiation Protection) IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
C Relationship of IEC 60601-1-6:2006 vs. IEC 60601-1 3rd Edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A IEC 60601-1 3rd Edition Recognition in Canada IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
T Harmonization date of IEC 60601-1 , 3rd Edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 135
