New Gauges calibration certificate shows deviations from the measurement uncertainty
K
KnoKsuKaO
Hello all,
we are certified according to ISO/TS 16949.
We ordered a new gauge on which we kept a calibration sheet by accredited laboratories. Unfortunately, calibration certificate shows deviations from the measurement uncertainty.
I would like to ask, because these are a new gauge we can use these gauge or what we can do so that we can use?
Thank you.
Re: Gauges calibration
Can you explain what "deviations from the measurement uncertainty" means specifically? Uncertainty is only one factor in evaluation of calibration results, and a lot depends on the things that the device is used to measure.
Kales Veggie
People: The Vital Few
Hello all,
Thank you.
That depends. What accuracy do you need for the characteristic you are measuring?
K
KnoKsuKaO
Deviations from the measurement uncertainty, which is mentioned on the calibration certificate.
Uncertainty of measurement: + / - 7,6um
actually measured deviation: 0 0 0 -4 -2 -5 -9 -6 -5
What effect might the uncertainty have on your measurements?
N Calibration Certificate Requirements for Pressure Gauges General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
L Calibration of Plug Gauges - Tolerancing General Measurement Device and Calibration Topics 1
W Duplicated Gauges want to reduce calibration General Measurement Device and Calibration Topics 2
J IATF 16949 Cl. 7.1.5.2.1 - Gauges (Measuring Jigs) Calibration/Verification Records IATF 16949 - Automotive Quality Systems Standard 6
B Calibration Status of Gauges for Training Only ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Sequence and Frequency of Calibration for Thread Gauges General Measurement Device and Calibration Topics 2
N Calibration Method of Dial Thermometer Gauges General Measurement Device and Calibration Topics 7
K Calibration Overdue on Customer-owned Gauges Calibration Frequency (Interval) 5
P Internal Calibration for Laser Temperature Gauges Manufacturing and Related Processes 3
E Calibration of Calipers, Mics, Height gauges - Recommended Gage Block Types General Measurement Device and Calibration Topics 7
B Method for Calibration of Thread Plug Gauges General Measurement Device and Calibration Topics 13
Manix Do Gauges used for Maintenance of the Facilities Require Calibration IATF 16949 - Automotive Quality Systems Standard 5
H Calibration of Measuring instrument, MRP gauges in machining General Measurement Device and Calibration Topics 2
V Calibration of Pin Gauges General Measurement Device and Calibration Topics 2
B Calibration of "Z" class ring gauges internally using a CMM General Measurement Device and Calibration Topics 5
R Setting Calibration Tolerance on Gauges - Oven Calibration and Stepped Plug Gage General Measurement Device and Calibration Topics 10
C Calibration Standards and Typical Accuracy Requirements for Force Gauges General Measurement Device and Calibration Topics 3
R Adjustable c-type gauges and calibration - Small job shop General Measurement Device and Calibration Topics 2
N Seeking Procedure(s) - Methodology: Calibration of Pin Gauges General Measurement Device and Calibration Topics 9
Geoff Cotton ISO 6H Go Screw Plug Gauges Calibration to ANSI / B1.16M vs BS 3643 General Measurement Device and Calibration Topics 5
B Published standards dealing with calibration of pressure and vacuum gauges? General Measurement Device and Calibration Topics 5
D Calibration - An old textile plant with a gazillion gauges on our machines General Measurement Device and Calibration Topics 1
V Calibration for Solid Length Gauges General Measurement Device and Calibration Topics 2
J Do Process gauges need to be in Calibration control system? QS-9000 - American Automotive Manufacturers Standard 2
J Calibration, should we.... Go-No-Go, thread, pin, and ring gauges QS-9000 - American Automotive Manufacturers Standard 2
J Using ring gauges General Measurement Device and Calibration Topics 2
D Different limits for new and worn gauges General Measurement Device and Calibration Topics 2
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
S Acceptance criteria for gauges General Measurement Device and Calibration Topics 8
S ISO 5356-1 - 22 mm ring gauges and test laboratories for an Anesthetic connector Other Medical Device Related Standards 1
K Guard-banding and relaxed acceptance for dimensional gauges General Measurement Device and Calibration Topics 1
S GRR on ID with set of pin gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
V How to Calibrate Ring Force Gauges Service Industry Specific Topics 1
E Do you need a Certification to Calibrate Gauges? General Measurement Device and Calibration Topics 2
E MSA of Attribute Gauges Signal Detection Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L TiN Coated Thread Plug Gauges General Measurement Device and Calibration Topics 12
P Is MSA needed once or once a year for Verniers, Micrometers, Gauges, etc? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
S Offline Laboratory Scale Gauges for Min Max Diameter of Round Steel Bars General Measurement Device and Calibration Topics 6
S Colour Codes for Vacuum Gauges on Medical Devices? Other Medical Device and Orthopedic Related Topics 3
J Performing Internal Calibrations - Dial gauges, micrometers, height gauges, calipers General Measurement Device and Calibration Topics 8
D Ring Gauges P.D Formula using "Ball Rounded Teeth" General Measurement Device and Calibration Topics 13
S Calibrating Panel Mounted Pressure Gauges located on Hydraulic Test Stands General Measurement Device and Calibration Topics 3
0 Best way to evaluate the differences between 2 gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Acceptance Of Gauges > 10% < 20% Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S Go/No-go Length Gauges - Length checking of beam assemblies General Measurement Device and Calibration Topics 2
