New Medical Device Accessory with New Function - Is this a major change?
Mark Meer
We'd like to introduce a "fitting kit" disposable accessory that clinicians can use to test out on patients to see if the device is suitable for individual patients.
I'm not clear how the addition of such an accessory would affect the regulatory status (510(k) cleared, CE marked, Canadian MDL). Not sure if it's a major change.
Ultimately, when used for treatment (i.e. if clinician determines the device is a good fit, and issues prescription), there is no change to the way the device is used.
However, with the "fitting kit" accessory (to be used exclusively for assessment purposes by a clinician), the device IS used slightly differently (as the intent is to get an optimal fit, and assess the effectiveness). The patient will never use the "fitting kit" accessory.
So, is this a major change? Can a distinction in intended use be made between the setup as used for assessment purposes (clinician directed) versus patient treatment purposes (after the device is actually prescribed). What would be the regulatory considerations/implications?
Any input/advice much appreciated!
MM
isolytical
See the FDA guide 'Deciding When to Submit a 510(k) for a Change to an Existing Device'. For the accessory, there will be a new use - 'For Professionals only'.
Mark Meer
This is what is not clear to me. Is it a new use? The device itself (when prescribed) is not "For Professionals Only". When used for the therapy it's intended for, the device use has not changed. When used for assessment purposes (with use of the accessory, by a clinician), the way it is used is quite different.
One way to consider it is that the device:
- With the accessory the intended use is as an assessment tool to be used by clinicians to assess if patients are good candidates for treatment with the device.
- Without the accessory then intended use is as a treatment device to be used by patients.
isolytical
"One way to consider it is that the device:
- Without the accessory then intended use is as a treatment device to be used by patients."
Yes, this is correct thinking and also the 'why' there are two 'uses'. Also see the MDD, which makes a clear distinction/definitions for the two concepts. If you are having serious doubts about the path forward call the FDA, the person concerned will gladly answer questions.
T Classification Accessory Software medical device EU Medical Device Regulations 4
B Reprocessing of an accessory for a medical device EU Medical Device Regulations 6
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
dinaroxentool Question about qualification as a medical device or accessory in Europe EU Medical Device Regulations 2
E Under MDR is a medical workstation a medical device or an accessory? EU Medical Device Regulations 5
D Software as an accessory to a Class I medical device EU Medical Device Regulations 4
L Medical Device Accessory - Health Canada guidance / definition on what an accessory is Canada Medical Device Regulations 3
N Medical Device Accessory Classification - Software as a Medical Device Other Medical Device Regulations World-Wide 5
M Commercial tablet as an "accessory" for a medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
F Risk Analysis of a Medical Device Accessory ISO 14971 - Medical Device Risk Management 4
JoCam Non-medical device accessory for a medical device EU Medical Device Regulations 27
I Class I Medical Device Accessory with Actual Risk EU Medical Device Regulations 7
shimonv Feeler Gauge as a Medical Device Accessory EU Medical Device Regulations 3
T Using Risk Management in ISO 10993 - Medical Device Accessory 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
shimonv EU classification for a Medical Device Accessory EU Medical Device Regulations 16
Q South Africa Class I Medical Device Accessory Registration Other Medical Device Regulations World-Wide 1
P EMC requirements for an accessory to a medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
somashekar FDA proposal on Medical Device Accessory Risk Assessment Other US Medical Device Regulations 15
R Medical Device and Accessory Establishment Registration and Listing Query Other US Medical Device Regulations 7
D Software as a Medical Device Accessory Software Quality Assurance 2
K Standalone software - an accessory to medical device? EU Medical Device Regulations 4
K Importance of Medical Device Accessory Design Controls Other US Medical Device Regulations 4
R Regulation Process for Add on Accessory to an Existing Medical Device Other US Medical Device Regulations 1
Q FDA Medical Device Accessory Packaging Requirements US Food and Drug Administration (FDA) 12
Y Medical Device Accessory Labeling Requirements Other Medical Device Regulations World-Wide 1
D Class I and Class II Medical Device Accessory Design Control Requirements US Food and Drug Administration (FDA) 3
Z IEC 60601-1-2 for very simple Medical Device Accessory IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
K USB Charger Adapter/USB Cable - A Medical Device Accessory? EU Medical Device Regulations 2
S Definition Medical Device Accessory - FDA Definition of Accessory Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
J Packaging and User Manual for Medical Device and Accessory CE Marking (Conformité Européene) / CB Scheme 3
S OEM Supplier with ISO 9001 Labels Medical Device Accessory ISO 13485:2016 - Medical Device Quality Management Systems 3
R Dialysis Machine is CE Marked as a Medical Device - Accessory or not? EU Medical Device Regulations 4
D Requirement for Expiration Date on Medical Device Accessory Labeling 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A Software contained in a Medical Device Accessory IEC 62304 - Medical Device Software Life Cycle Processes 3
M Defining what is a Medical Device Accessory and what isn't - Much Confusion EU Medical Device Regulations 8
Y How can an Optional Accessory of a Medical Device be sold alone? Other US Medical Device Regulations 5
T Definition Servicing Activities - Definition - Medical device accessory manufacturer Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
C Medical Device "accessory" - Blood pressure monitor (BPM) power supply EU Medical Device Regulations 7
somashekar Medical device file Vs Role undertaken by the organization ISO 13485:2016 - Medical Device Quality Management Systems 1
M Medical Device Label - Language EU Medical Device Regulations 2
D MDR: Active medical device or not? Medical Information Technology, Medical Software and Health Informatics 4
H Mapping QMS+business processes in a medical device with class I and IIa+b Process Maps, Process Mapping and Turtle Diagrams 0
Aliken Registration veterinary medical device (laser) requirements Medical Device and FDA Regulations and Standards News 0
J CGMP Medical device slide deck Manufacturing and Related Processes 1
M Notification Requirements for Medical Device Raw Materials 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
I Madagascar medical device regulation Other Medical Device Regulations World-Wide 0
R Steam sterilizer medical device reclassification EU Medical Device Regulations 3
G Software Medical Device Classification EU Medical Device Regulations 7
J Robotic arm with a camera, active medical device? EU Medical Device Regulations 12
