New MSA file using ANOVA - January 2010
I have revised my MSA 3rd Ed.xls file, which was based on the Average Range method to MSA 3rd Ed ANOVA.xls. As the name implies, it is based on the ANOVA method.
You can find the file attached to my blog entry on Gauge R&R. As described in my blog, I have taken the AIAG ANOVA approach one step further. The file allows you to state the alpha risk for pooling the interaction and the operator effects. Based on the notes that appear by the ANOVA tables, you can select a full ANOVA, one that pools the interaction, or one that pools an insignificant operator term. This is the same approach that I used in my Wheeler's Honest Gauge Study.xls file.:)
DrM2u
Re: New MSA file using ANOVA
Thanks for the file. One question for the general public ... Did anyone submit this type of analysis in a PPAP package and what response did you get from the customer?
bobdoering
Stop X-bar/R Madness!!
The second tab information should be more than satisfactory to meet PPAP requirements - as far as the information supplied.
What is your specific interest? I am not taking any offense, I am simply curious. Do you suspect that customers will question the results, be overwhelmed, ...?
Note: I have validated the results using the Ford SW Validation data set, as well as cross checking with Minitab.
DrM2u
I like the worksheet and find it to be a great tool. Also, thanks for the note on validating the results.
My concern is if the report generated contains too much info for the customer. Many people evaluating PPAP packages are just looking for the 'R&R number' without understanding or evaluating the rest of the information. It is like trying to explain to the average person the margin of error in the results of a survey poll. :confused: Too much info might be overhelming for some customers. I was wondering if anyone exeprienced anything like that by providing detailed MSA reports.
bobdoering
I would just supply the GRR Report tab - just for the reasons you cite.
I agree with both of you. I developed this for internal use, not to provide for PPAP other than the Report sheet, which I sized for 8.5 x 11 landscape.
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Bias Linearity Stability MSA Excel File with Formula Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Ron Rompen Need help with MSA/Gage R&R - Seeking Minitab template file/sample GR&R study Using Minitab Software 7
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
Bev D MSA Misc. Quality Assurance and Business Systems Related Topics 46
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA When an Instrument Measures More than One Parameter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O MSA Study for a steel ruler Manufacturing and Related Processes 6
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
G MSA on a Counting System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Test Method Validation or MSA for Batch Manufacturing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA on a process using different fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
L Number of Distinct Categories" or NDC Calculation in MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
Q Doing an MSA on a Climatic Chamber Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
C MSA for Non Manufacturing - Design Validation, Characterization and Qualification Lab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C PPAP Rejection for "MSA-GR&R are not using the latest AIAG format" APQP and PPAP 9
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P Frequency and Sample Size Requirements for an MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A Automated Measurement Machine MSA - Small Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Crimpshrine13 MSA for a part Automated and part Manual Inspection Machine IATF 16949 - Automotive Quality Systems Standard 7
S MSA (Measurement System Analysis) - Process Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B How to do an MSA on an Automated Torque / Angle System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
I MSA related questions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
MSA
