New MSA file using ANOVA - January 2010
Barbara B
#21
I don't know if this is the t-value riosimbolon mentioned, but the 1.662 can be found in your "MSA 3rd Ed with ANOVA.xls" (Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5b: R&R), sheet "Stability", cell U43 (called "t_critical alpha=.05" in U42).
According to the MSA manual the critical t-value should be derived using
t^(-1)_{nu, 1-alpha/2}
(1-alpha/2)-quantile of the t-distribution with "nu" degrees of freedom, "nu" from table C1 (appendix C) in MSA 3rd (formula: see p.89 in MSA 3rd and p94 in MSA4th, resp.)
Table C1 does provide "nu"-numbers for a maximum of m=20 readings within a subgroup and a maximum of g=20 subgroups. At the bottom of the table it is stated that further "nu"-values could be build by using cd (constant difference). For a subgroup sample size of m=5 readings, the "nu"-value for g=20 subgroups is 72.7 and the cd=3.623. To obtain the "nu"-value for g=25 subgroups cd have to be added 5 times to the g=20-subgroups-"nu"-value (because 25 = 20 + 5 subgroups):
nu = 72.7 + 5*3.623 = 90.815
1-alpha/2 = 0.975 (for alpha=5%)
The critical t-value for the bias test with m=5 readings, g=20 subgroups and alpha=5% is given by
t^(-1)_{nu, 1-alpha/2} = t^(-1)_{90.815, 0.975} = 1.9864
But in the Excel file 1.662 is presented as the critical t-value. If alpha is set to 10%, this would be the correct value:
t^(-1)_{nu, 1-alpha/2} = t^(-1)_{90.815, 0.95} = 1.6618
(checked with R and Minitab)
Maybe this occurs due to Excel's use of alpha-values within the function TINV (see "A one-tailed t-value..." on TINV function) which differs from the usual behaviour of statistical software packages?
Best regards,
Barbara
Shuwang
#22
Thank you very much. For be learing MSA, this is the most comprehensive I had seen before. Thank you!
#23
Re: New MSA 4th Ed file using ANOVA - September 2013
After several requests, I have updated my MSA - ANOVA file to the 4th Edition. I included the data sets used in the manual where applicable. The Bias and Linearity tabs include all of the 4th edition changes. However, I made selective changes to the R&R tab. I added the option to use known process variation rather than relying solely on the study variation. I did not add the option to use Ppk. I had limited time, and if you have Ppk, you also have the process variation. I also did not add the multitude of graphs. Frankly, most where simply variants of the existing graphs (i.e., stacked versus unstacked) or in my experience were of limited value.
P
Peter_Tan
#24
The Excel file, named MSA 4th Ed with ANOVA.xlsx, is good for me to learn how to do variable MSA study with ANOVA. But in the file I cannot find the sheet labeled "Graph Worksheet" which is used to format the results in order to generate the graphs summary as shown in instructions tab. May I know where the "Grsph Worksheet" is or let me how to do it to learn more graph analysis? Thanks!
P
Peter_Tan
#26
I got it to unhide the sheet. It is useful for me to learn step by step how to do the graph analysis. Thanks!
Rio BP Simbolon
#27
I already downloaded, I tried that Excel-Anova-program, but how use it if there are more than 3 appraisal,
#28
There shouldn't be a need to use more than three operators. The idea is to select operators who represent the skills of a typical production user of the device, not to test everyone who might use it.
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Bias Linearity Stability MSA Excel File with Formula Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Ron Rompen Need help with MSA/Gage R&R - Seeking Minitab template file/sample GR&R study Using Minitab Software 7
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
Bev D MSA Misc. Quality Assurance and Business Systems Related Topics 46
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA When an Instrument Measures More than One Parameter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O MSA Study for a steel ruler Manufacturing and Related Processes 6
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
G MSA on a Counting System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Test Method Validation or MSA for Batch Manufacturing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA on a process using different fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
L Number of Distinct Categories" or NDC Calculation in MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
Q Doing an MSA on a Climatic Chamber Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
C MSA for Non Manufacturing - Design Validation, Characterization and Qualification Lab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C PPAP Rejection for "MSA-GR&R are not using the latest AIAG format" APQP and PPAP 9
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P Frequency and Sample Size Requirements for an MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A Automated Measurement Machine MSA - Small Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Crimpshrine13 MSA for a part Automated and part Manual Inspection Machine IATF 16949 - Automotive Quality Systems Standard 7
S MSA (Measurement System Analysis) - Process Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B How to do an MSA on an Automated Torque / Angle System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
I MSA related questions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
MSA
