I am new to 17025 and need a little help in proficiency testing. I understand that you need to do interlaboratory comparisons. The confusion comes in reporting of the results since the 2 labs may have different methods of testing. For example we calibrate DC torque wrenches and our method is to test the wrench in 4 positions through the torque range of the tool where as the lab we sent the tool to only test max torque of the wrench. This leads to a different value for degrees of freedom. We also compare the torque reading of the wrench on each sampling to an independent transducer to produce multiple xi, xi-xbar, and Square of xi-xbar readings which are then averaged. The lab we used only compares the torque value of the wrench to the independent transducer until an acceptable Cal Factor is obtained then basis the Uncertainty calculations on the readout of the wrench alone. This causes us not to pass proficiency since they can not achieve the numbers we do. My question is there not a provision for labs having different methods to still obtain acceptable results? We are being required to relax our standards to meet this labs requirements which I find difficult to swallow. This seems to be a flaw since if we adjust to pass with this lab and they go out of business and we have to send the artifact to another lab with an alternate method we will be changing our method again.
Thanks,
Confused
Thanks,
Confused
