New to AS9100 Rev. C - Setting KPIs and FAI Reports
P
phillips25m
Hi to all may I introduce myself, my name is Mark and I am an owner of a small grinding Company. We have been told by four of our customers we need to gain AS9100. We have just gone through stage two of our Audit and gained very minor NC against us, which I have worked on and sorted the majority out. But the last two I seem to be struggling with. The first is KPI and the measuring of them, I have only identified three, which are on-time delivery, Non-confirming parts and quotations returned in time. As our company is only a small process and not a complete manufacturing company, we never really had the tools to monitor the on-time delivery. This was a guesstimate to be plain which was set at 95% in the ISO system. But in AS9100 I was given an Excel spreed sheet with a graph which is very nice:applause: We were asked to transfer the information from the job cards we had to see how it worked. But because our customers never gave deadlines on P/O our dates required were filled in ASAP which counts as being on time! So we ended up with a total of 98% on time. I have been told that's what we should put for this years target? So just done the first month and we have not hit that target? People have told me it is up to us to set our desired level for on time deliveries? Can anyone tell me other wise :notme:
The second is 7.5.1 I have been told we must produce a FAIR? Our customers never ask for them, however, some people say I have to have them and be able to do them if I am required to because the standard says you must . And other people are saying "because we don't design we don't need them because grinding is such a small operation" :argue:
Any help would be greatly appreciated.:thanks:
Michael_M
Re: New to As9100 Rev C - Setting KPIs and FAI Reports
I have uploaded an excel spreadsheet that may be able to help with the FAI. I automated allot of the typing so it becomes easier.
Note: On page 1, I protected most of the cells that do not get changed much (Box 10 on page 1 for example). You will want to put your data in where it belongs then protect the fields.
I type all the data on the last tab "all" and then excel places the data on the correct page. I do this so when I type the same data in frequently it autotypes it and I don't have to retype the same info over and over again.
  • First Article Inspection forms AS9102 For upload.xlsx
Big Jim
Unless you can justify a reason not to do 7.5.1.1, and claim it as an exclusion, you need to do it. You will probably have a hard time justifying it satisfactorily to your certification body.
7.5.1.1 is often referred to as first article inspection, but don't confuse it with the requirements of AS9102, which is a more involved first article than 7.5.1.1 requires. Since there is often confusion on the topic, I suggest you get a copy of AS9102 so you can compare it to what little there is in 7.5.1.1.
In essence you need to select a representative sample from the first production run and make the assessment, mostly through measurements, that the process and documentation are sufficient to ensure that subsequent parts will continue to meet requirements.
If you think that is a pain, be happy you are not making automotive parts where they require a much more detailed system, that of PPAP.
You need to do it. You might check around with other grinding shops (or possibly machine shops) to see how they do it.
ckillam3
Allow me to also highly recommend a review of AS9101 as the AS9100 auditor will be following this verbiage in his/her work.
Mikishots
Tracking your on time delivery is not an exercise that is solely for keeping auditors happy or for filling up an empty spot in your KPI list; the point of having it is so that you can trend your performance, tell if and when it's going sideways and continually improve it. If the customer simply wants it ASAP, it should make zero difference to you in your trending of OTD.
I'd start by benchmarking a build. When things go right, how long does it take to build it? Do you have any idea? Once that build has been examined and defined, what are some things that you can do to improve the delivery time without compromising the quality (and vice-versa)? The point is to always work towards being faster and better - time is money and poor quality is expensive. Even your long-term customers that have been fine with "ASAP" in the past will be pleasantly surprised when you are able to provide their product quicker each time without a loss in quality, and you will be more profitable by being more efficient.
Big Jim
Tracking on-time delivery really tells you just how effective your quality management system is behaving overall. It will not pin down the exact cause of a problem, but a low number it is an early indicator that something is amiss and needs to be found and corrected. It is a far more valuable indicator than many people give it credit for.
Mikishots
I haven't disagreed with this.
P
phillips25m
Thanks for the replies, i am looking into it a little further, All our KPI's are as follows, On time delivery, Right first time ( non-conforming parts), New customers over a year period and Return of quotations in a time limit. So we are only measuring 4 KPI's. Please take into account we only employ 8 people( big in terms of a specialized stand a lone grinding shop)? So AS9100 is a bit much for our size ? Considering we only carry out a process and we do not make anything from scratch??:notme: All in put welcome :thanx:
Big Jim
I call on a two person company that has been successfully registered to AS9100 for about four years.
You can make it as hard to manage as you want.
Four KPIs don't have to be hard to do, unless you want it to be.
D AS9100 Rev D - Clause 8.7 Control of Non conforming outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100 News AS9100 Rev. E? Any news? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C AS9100 Rev D 8.1.1 & APQP - Operational risk management process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R AS9100 REV D gap analysis matrix AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
bryan willemot Documenting past problem history for fasteners for AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Definition of "Sensitive Products" Clause 8.5.4 (c) in AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M AS9100 Rev D and Pin Gages General Measurement Device and Calibration Topics 7
S General Awareness Training for AS9100 Rev.D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P How To Transition From AS9100c to AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C AS9100 rev D 8.5.1 c 2 - Defining the Machine in-process frequency per ANSI/ASQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
P AS9100 rev D Quality Manual wanted - 2017 Quality Management System (QMS) Manuals 4
A AS9100 Rev D - Procedure for Product Safety & Control of Counterfeit Part (Format) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9100 Rev. D - Question about 8.4.3 (k) - Supplier Certificates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M AS9100 Rev. D Transition Audit - Number of Audit Days AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q AS9100 Rev.D Transfer of Work - Procedure and form templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A AS9100 Rev:D in Spanish - where can I find a Spanish version? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
O How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Auditors? Risk Management Principles and Generic Guidelines 22
A AS9100 Rev D - List of Required Procedures Document Control Systems, Procedures, Forms and Templates 5
B AS9100 Rev D - Traceability of Consumables AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AS9100:2016 (Rev. D) Required Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 19
J AS9100 Rev D Quality Manual Rewritten - Feedback Appreciated Quality Management System (QMS) Manuals 13
K AS9100 Rev. D Transition - Internal Audits & Gap Analysis Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B AS9100 Rev D Quality Manual - How are you organizing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
B AS9100 Rev D Sequence and Interactions of Processes - How in depth do I need to go? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
D Design and Development Procedure example and Template wanted - AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
O Guidance and/or assistance on Transition to AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Mikishots Definition Issue - "Issue" vs. "Risk" in ISO 9001:2015 and AS9100 Rev D (Definitions) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
howste AS9100 Rev D Clause 10.2 - Is Cause always required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 39
Kronos147 Quality Manager's Role in AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M AS9100 Rev. D - Can anyone recommend a good reference book? Book, Video, Blog and Web Site Reviews and Recommendations 7
T What is the Rev C equivalent for an RABQSA AS9100 Certified Lead Auditor course? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
G AS9100 Rev. C - Records created and/or maintained by Suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
F Gap Analysis Matrix for AS9100 Rev C to TS16949:2009 IATF 16949 - Automotive Quality Systems Standard 1
R AS9100:2016 Rev. D - Status and Information - May 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
D Calibration Requirements for AS9100 Rev C Calibration Frequency (Interval) 5
Sidney Vianna AS9100 Rev.D - The revision work has started AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
A AS9100 rev C Skill Examiner Audit to complete my RABQSA Auditor certification Career and Occupation Discussions 3
J Corrective Action Review - AS9100 Rev. C Requirement AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
N Meeting AS9100 Rev C Requirements - Major help wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 27
D We received our AS9100 Rev C. certificate! Thank you! AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K Implementing AS9100 Rev C - Electrical Harnesses and Cable Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G AS9100 Rev C QMSM (Quality Management System Manual) Template Required AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T AS9100 - Upgrade to Rev C - Design & Manufacturing Plant AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
G Please recommend preparatory reading for AS9100 Rev C Lead Assessor Course AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
D New to AS9100 and have a REV C Audit scheduled in Feb. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
S Is it required to upgrade an AS9100 B Procedure Manual to AS9100 Rev. C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C AS9100 Rev C Clause 8.5.2 - CAR (Corrective Action Request) Format AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M AS9100 Rev C - Determining, Providing and Maintaining" Infrastructure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J Audit Days Requirement for AS9100, Rev C Re-Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Upgrade Audit vs. Reassessment Audit (AS9100 Rev B to Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
