New to PPAP and APQP - Don't really understand what all of it means
dm1030
Forgive me if this has been asked before, but I could not find anything in regards to it. I have "fallen" into the job of PPAP's. Our company does not have many to do, but enough to keep me a bit busy with all the other things I do around here. I have the 4th edition spreadsheets and can enter in the data well enough, but don't really understand what all of it means. Is there a good place to go or info to read where I can get my feet wet in what I am doing?
Thanks for any help you can give. These forums have already answered alot of questions for me.
D.Scott
Re: New to PPAP and APQP
DM, welcome to the posting side of the Cove. There are a lot of good threads dealing with PPAP right here on the Cove. Scroll down on this page to see a list of related threads. One of those might help.
If you are looking for a book on PPAP, contact the AIAG and order the PPAP Reference Manual - Fourth Edition.
If there is anything specific you need help with, just ask.
Dave
Howard Atkins
Forum Administrator
Welcome.
I think that you should demystify the issue.
PPAP is the documentation of the part and process development (APQP).
  1. The index- PSW
  2. There is the design of the process with the flow chart, FMEA and Control plan
  3. There is the verification of the equipment MSA etc
  4. Verification of the part , functional and dimensionals
  5. Validation of the process- Capability study.
Q
qualitygoddess - 2010
You can also try your local ASQ section. http://www.asq.org/sections/index.html to find the section nearest to you. Many times, they can hook you up with a local mentor, someone who is an expert in the topic. Since you are in the 'land of PPAP' in MI, you can probably also find a number of locally available classes on APQP, which will certainly help you. A google search will turn up many. One of the best resources is the Cove's own Marc! I notice he has already posted!
--QG
tony wardle
Registered Visitor
Hi, We also had this same question in mind when we started producing automotive components. Apart from all the good advice on WHAT both APQP and PPAPs are, we learned some valuable lessons. My ramblings may not be as others see it, but rather my own observations on the question at hand.
APQP is the planning phase. Do not try to do this AFTER you have started production purely as a paper excercise because it is a requirement. Do it upfront. APQP is the part where you plan out your program. Involve EVERYONE. Well planned is half the job done successfully. At this point you will almost be looking at a crystal ball, or tarot cards - here in africa we may get a witch doctor to throw the bones. You are looking at what the customer wants, then planning the product build and robust process. We learnt that long involved and complicated process routes cost time and money. KISS.
You will also be looking at DFMEAs and control plans. There are alot of posts on these. Initially you are looking at what may go wrong, and controls for prevention and detection. DO NOT kid yourself that the process is such that nothing will go wrong and that your controls are brilliant. Continually improve wherever possible. Murphy the lawyer, and author of the rule Murphys law is active always. Your prototype is important too. If you do a quick fix to get the prototype out, you have failed before you start. Be wary of cost all the way upto this point as bad design of product or process can cost you dearly. Important too is GIVE THE CUSTOMER WHAT HE WANTED - his spec is law.
So, onto the PPAP. PPAPs are not a "part time" job and are not meant to be done because the system says so. They are invaluable documentary evidence that the part conforms to the specification, that you process is stable, and capable. It is good evidence that you are compliant, and as a living document will tell you when you are going wrong. It is important to determine what level of PPAP submission is required - this will influence the content of the PPAP. If APQP was done well, the PPAP will be easy to compile.
A final word on this - if you need to put your part into the IMDS database, get some help. We had a few issues completing the IMDS statement.
Good luck
jrubio
If you have a doubt ask the Customer Quality Analyst or SQA if they can provide you examples.
Q
Quality Diva
I just moved away from Michigan. I used to work for a company named Sandalwood. One of the things I did in that company was to help organizations (mostly automotive suppliers) to learn, understand and implement effectively APQP/PPAP.
There are several Engineering Services firms in that area that can help you to understand and implement APQP/PPAP in your organization. But as mentioned in other related notes, don't try to do it after the fact, because you will only waste your time and won't get any value from APQP/PPAP.
Pau Calvo PPAP customer requirements in the APQP APQP and PPAP 25
B What is the role of Quality Engineer in APQP and PPAP APQP and PPAP 3
A New Supplier implementation - PPAP vs APQP APQP and PPAP 9
kedarg6500 APQP & PPAP for Process Industry - Concept for Waste to Energy Program APQP and PPAP 0
H Prerequisites for AIAG APQP/PPAP Certification Exam Training - Internal, External, Online and Distance Learning 2
S APQP, PPAP and PSW Question from a Rookie APQP and PPAP 4
M APQP and PPAP for Beginners - Where do I start? APQP and PPAP 48
W Certification on AS9100C - FAI or PPAP? Project Management or APQP? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
I Any recommendations on software for managing the APQP, PPAP, PFMEA, Control Plan etc? Quality Assurance and Compliance Software Tools and Solutions 2
Q Need guidance new APQP and PPAP Process Improvement Software Idea Quality Assurance and Compliance Software Tools and Solutions 1
T APQP and PPAP in an AS9100 plant APQP and PPAP 2
T PPAP & APQP - What other sectors are Adopting/Adapting these Concepts? APQP and PPAP 14
B Frequently asked PPAP, FMEA, SPC, MSA, APQP & 7QC Tools questions for Interviews Career and Occupation Discussions 1
I APQP and PPAP Training Documents wanted Training - Internal, External, Online and Distance Learning 4
P Has anyone ever heard of "Quality Gates" (Volkswagen term?) - APQP and PPAP APQP and PPAP 11
V Latest revisions of Core Tools Manuals from the AIAG (APQP, PPAP, FMEA, SPC and MSA) IATF 16949 - Automotive Quality Systems Standard 3
C What are APQP and PPAP? APQP and PPAP 36
S Are the AIAG document (FMEA, PPAP, SPC, MSA, APQP) guidelines or requirements FMEA and Control Plans 6
P Do Suppliers hire PPAP/APQP contract Auditors - Can I make a living as one? APQP and PPAP 3
W Global Phased PPAP and APQP Training - Please Review and Comment Training - Internal, External, Online and Distance Learning 8
M Information about APQP, PPAP and MSI for TS 16949 implementation (student) APQP and PPAP 1
Q Simple overview of the contents of APQP and PPAP APQP and PPAP 2
A APQP/ PPAP Manual Revision Control APQP and PPAP 2
I APQP Process Review and the Purpose of PPAP APQP and PPAP 13
M Software to Handle All "Quality" Processes? APQP, Control Plan, FMEA, MSA, PPAP, etc. Quality Assurance and Compliance Software Tools and Solutions 1
J When do we do APQP, PPAP etc for both OEM and aftermarket APQP and PPAP 11
W Does ISO 9001:2000 require the use of AIAG (automotive) APQP, PPAP, etc. Manuals? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Share your APQP or PPAP package! Attached is a PPAP template APQP and PPAP 44
M APQP & PPAP - Does Toyota follow the APQP and PPAP process? Customer and Company Specific Requirements 5
U PPAP and AQAP Training - I really want to learn PPAP, APQP, and QS-9000 in detail Training - Internal, External, Online and Distance Learning 3
J What is difference between the goal of PPAP with APQP, thanks APQP and PPAP 4
Howard Atkins GM no longer requires the use of Powerway for APQP and PPAP Customer and Company Specific Requirements 4
I Changes in APQP, MSA, PPAP, FMEA Requirements APQP and PPAP 5
Q Looking for a good PC program for APQP & PPAP packages. Quality Assurance and Compliance Software Tools and Solutions 7
L Does the APQP process end with the approval of the PPAP? APQP and PPAP 5
Q Software solution to manage APQP and PPAP Quality Assurance and Compliance Software Tools and Solutions 3
C APQP, PPAP, FMEA, SPC Procedures? IATF 16949 - Automotive Quality Systems Standard 8
Marc Future of APQP and PPAP in Doubt? 2005 Update APQP and PPAP 26
A APQP audit last week with Visteon and Ford - They want a PPAP Booklet APQP and PPAP 4
Raffy How do I start my APQP and PPAP Procedure? APQP and PPAP 1
H Does Powerway's APQP - PPAP fulfill TS16949 document and data control requirements? Customer and Company Specific Requirements 2
CarolX Value of APQP and PPAP for Small Volumes APQP and PPAP 7
C ISO9001 vs. TS16949 - Do we still need to use PPAP, APQP, etc? IATF 16949 - Automotive Quality Systems Standard 2
D APQP - No two companies conduct their APQP/PPAP activities exactly alike APQP and PPAP 2
S What if none of the customers want APQP and PPAP APQP and PPAP 11
D QS-9000 Implementation: APQP / PPAP Documentation QS-9000 - American Automotive Manufacturers Standard 3
P Simple PPAP / APQP Step-by-Step Process APQP and PPAP 3
D QS9000 third edition - Do APQP, FMEA and PPAP have any significant changes QS-9000 - American Automotive Manufacturers Standard 7
M Looking for PPAP (APQP) type software for our company APQP and PPAP 5
