Newbie Capability question
Bjourne
Seems to be a very intellectual group of guys here :)
I'm new here to this forum(I usually just visit and participate in security forums such as Wilderssecurity and MalwareTips) and I just wanted to know more about Capability study. I am not an engineering graduate but have been exposed to semiconductor manufacturing process way back 2007 as I work in molding department for IC encapsulation. I want to learn more about the process side of things in our company but sad to say there isn't any training available or if there is I am darn busy at the production line(most of the time).
I have some notes that I got from some of our engineers. Some notes that they use for Capability studies but I am having a hard time learning it. Can I post it here so someone might check if I did it wrong...?
This is a sort of self-studying just in case I get the slot for promotion or can transfer to another company...just wanna learn more and not be stuck being a technician. I hope you understand.
Thanks for understanding.
Regards,
Bjourne
dgriffith
Re: Newbie question
. . . just wanna learn more and not be stuck being a technician. I hope you understand.
Regards,
Bjourne
It's good that you want to learn more. Wish I'd learned so much more when I was younger, and I'm still learning.
However, and I'm sure you didn't mean it the way I'm reading it, but I must come to the aide of the technician. I've been stuck being a technician all my life. Good technicians are needed--who the heck else is going to keep engineers straight? Keep them on their toes by catching their errors? Suggest better ways to implement their napkin designs? Turn their plans into working constructs? Test their ideas, calibrate their instruments, machine their parts, and so on. Most importantly, tell them when they're wrong!
Good technicians keep engineers out of trouble, even if they are stuck. :)
And, please, do post your questions here and many will be happy to look at them. There are also many threads with similar topics you can research.
Wes Bucey
Bjourne
Re: Newbie question
I feel the same way when it comes to being a technician. Some times I seem to feel that they are more theoretical rather than actual. I do the dirty work and they the coffee and meetings and meetings and reports. There are times that there are some basic know-how that engineers do not know! Anyway that is the reason that I wanna learn more so if possible when I get out of this job and I have a chance to be at least an associate engineer I'd know what to do :)
Thanks there :)
Bjourne
Welcome to the Cove!:bigwave:
:bigwave:Here's a link to give you a broad outline of a process capability study
For an on-line text (FREE)
is a great resource.
I took the liberty of starting you off with this link to "process capability" in the Handbook: ....
Happy learning!
Hi!
Thanks for the reply guys I really appreciate it! I am downloading the handbook now as I type :) Thanks there!
Bjourne
May I post a question now?
I was reading on a pdf file about Control Charts and I got interested on defects. We have some or a lot of defects at the production line and I read that you can use npChart it. I am in the process of charting the data I have, but something hit me....if I plotted it as correctly and there are outliers or out-of-control points, how can I help improve that particular process from where the defect originated?
The process is stable when there are no outliers right?
So if I have, say, 2 outliers from a given upper limit / lower limit in the npChart how can I control that outlier? Upper limit / Lower limit or Upper Control limit / Lower Control limit...which is correct?
What can be done to eliminate that outlier?
Might you show me some examples please....
Thanks guys :)
So sorry I was not able to post an image of the sample data table I got from work. It's here.
Question: I see that when I post with a link I am reminded of a spam warning...how can I post images from imgur? I got 2 warnings from quoting a reply...I dont wanna be banned so I asked :)
Thanks again :)
the phrase to use is "control limit" not just "limit"...
in the data you posted there is one subgroup that is beyond the upper control limit.
In order to 'control' that you must find the cause and take action to prevent recurrence.
When you have an out of control point, we say that there is an "assignable" cause. In other words either an input factor ahs varied to a level that is different than in the previous subgroups, or there is a new factor tha is present. in theory, assignable causes are 'easier' to determine because they are 'new' or fresh or come from an obvious cause.
the baseline "stable" variation is known as "common cause" variation becase it si the daily , normal variation in the process and improving it typically takes more involved problem solving methods and tools.
Now these are only approximate truths. I have encountered 'assignable cases that were very difficult to understand and fix and common causes that were really very simpel and easy to determine and fix.
None the less, in order to 'control' the defects one must use problem solving methods to understand the cause and correct it....
Bjourne
Thanks for the reply there :)
I think I need to get the findings of what happened first that arrived at that data...Do allow me to get the info from my officemates and then I'll plot the npChart (crudely with Excel) and then post it here. I hope for your understanding guys as really I am a beginner and am really trying to study/learn more :)
E Newbie - 14 Jan 2020 Coffee Break and Water Cooler Discussions 2
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
S Informational Please help this newbie understand ISO 9001 Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
S Thanks from a newbie Coffee Break and Water Cooler Discussions 4
Q ISO 9001 - 3 BIG questions to help a Newbie's Sanity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Food Warehouse ISO 9001 Audit and Newbie Introduction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M A newbie to RM struggling with the policy ISO 14971 - Medical Device Risk Management 1
C A total newbie to AS 9101 needs general help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
K Daily activities of a Newbie ISO Management Rep/Lead Auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
F SPC Newbie looking for Excel Spreadsheet formula for a sample size of 40 components Capability, Accuracy and Stability - Processes, Machines, etc. 8
B Gage R&R Newbie - Everything is Failing! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
N I have 2 groups to compare - Minitab and stats newbie - Please help Using Minitab Software 18
J Certification Audit - Confused Newbie Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
M Newbie in Gage R&R - Gloss Meter and Thickness Measurement Reliability Analysis - Predictions, Testing and Standards 7
G Newbie in IMDS - Please help me understand what I have to do RoHS, REACH, ELV, IMDS and Restricted Substances 4
P Gage R&R with ATE (Automatic Test Equipment) - Newbie here... Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R Newbie, SME, non existent QMS going for ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Newbie, easy to follow guide for organizing/assembling very first PPAP booklet APQP and PPAP 3
O Newbie at PPAP - Need basic PPAP Information APQP and PPAP 2
N Help a newbie to develop a QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
N SPC charts, simple xls sheets and free software - Need newbie information Statistical Analysis Tools, Techniques and SPC 5
L VDA Product Submission Form - Please help a Cove newbie answer a VDA question VDA Standards - Germany's Automotive Standards 12
D Major Advice Needed for Newbie Taking over a System in Shambles ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
L Minitab Newbie Using Minitab Software 1
A APQP Newbie requires guidance APQP and PPAP 5
R QMS Implementation "Newest Newbie"... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J FMEA - What is the relationship between Detection and Prevention? QP Newbie question. FMEA and Control Plans 12
A Seeking: ISO 9001:2000 Internal Audit Checklist for Newbie Internal Auditing 20
R Pre-assessment Audit Worries for a Newbie General Auditing Discussions 11
B Looking for PPAP help for newbie QS-9000 - American Automotive Manufacturers Standard 6
J Statistics and Six Sigma - Newbie Seeking Information and Resources Six Sigma 1
Proud Liberal COMMENT - Newbie Coffee Break and Water Cooler Discussions 1
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
H Capability Data for Paint Thickness on Painted Parts Statistical Analysis Tools, Techniques and SPC 10
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Pre-Production Capability Assesment Reliability Analysis - Predictions, Testing and Standards 5
T Iec 60601 Impedance and current-carrying capability IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
