Newbie, easy to follow guide for organizing/assembling very first PPAP booklet
bfore
[FONT=&quot]I have compiled the information from a previous post of mine from DrM2U and Jim Wynne and made a[/FONT][FONT=&quot] sorta short form guideline to creating my PPAP submission book and a short[/FONT][FONT=&quot] explanation what should be in each section of the book...This could be helpful[/FONT][FONT=&quot] to newbies like me and others assembling a PPAP submission for the first time It has helped me thus far.....[/FONT]
[FONT=&quot]
[/FONT][FONT=&quot]Please correct, add or modify this list in anyway that seems[/FONT]
[FONT=&quot]appropriate...Again, this is for me...but could help some other folks out too!! :)[/FONT]
[FONT=&quot]Pardon me if any of this seems ignorant...i'm most definitely a green horn and trying to[/FONT][FONT=&quot] make my way thru this process and learn it with the help of the folks here at Elsmar...I[/FONT][FONT=&quot] appreciate everyone's input, help, advice
[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]1.[/FONT][FONT=&quot]DESIGN RECORD[/FONT]
-Design record: you need to have a copy of the print(s) for the part you are making, the latest revision specified by the customer, ideally 'ballooned' to cross-reference to the layout report dimensions
[FONT=&quot]2.[/FONT][FONT=&quot]ENGINEERING CHANGE DOCUMENTS[/FONT]
-ECN's: any ECN's showing the change from previous revision to the current one (usually provided by the customer unless you are design responsible)
[FONT=&quot]3. CUSTOMER ENGINEERING APPROVAL[/FONT]
- Customer Engineering approval: if the customer needs to approve anything (i.e. materials, suppliers, components, etc)
[FONT=&quot]4. DESIGN FMEA[/FONT]
- DFMEA: must perform if you are design responsible, otherwise it COULD be provided by the customer sometimes
[FONT=&quot]5. PROCESS FLOW DIAGRAM[/FONT]
- Process flow diagram: YOUR outline of the process or processes employed to produce the product,
from receiving to shipping and anything else in between (i.e. storage, molding, packaging, etc)
[FONT=&quot]6. PROCESS FMEA[/FONT]
- PFMEA: YOUR analysis for each process step; I suggest doing one for each process step if you have processes
common to other product (i.e. receiving, shipping, material handling)
[FONT=&quot]7. CONTROL PLAN [/FONT]
- Control Plan: your controls for each process; use the PFMEA and DFMEA as inputs; follow the same approach as the PFMES (i.e. one for each process)
[FONT=&quot]8. MEASUREMENT SYSTEMS ANALYSIS[/FONT]
- MSA studies: usually gage R&R studies for the inspection equipment used to inspect this product and/or to control process parameters; the MSA manual can guide you through
[FONT=&quot]9. DIMENSIONAL RESULTS [/FONT]
- Dimensional results: full dimensional results report per customer's print; ask the customer for how many parts, usually 1/cavity
[FONT=&quot]10. MATERIAL PERFORMANCE TEST RESULTS[/FONT]
-Material testing, material & component certs (i.e. Dow Chemical laboratory certifying a raw material),
IMDS
[FONT=&quot]11. INITIAL PROCESS STUDIES[/FONT]
-Process capability for normal distribution processes must be from 100 samples (20 subgroups of 5 parts)
randomly selected out of a 300 piece run unless otherwise authorized by the customer quality representative
[FONT=&quot]12. QUALIFIED LABORATORY DOCUMENTATION[/FONT]
- Qualified laboratory: copies of accreditation certs AND scope for any laboratory used for product testing, material testing
[FONT=&quot]13. APPEARANCE APPROVAL REPORT (AAR)[/FONT]
- AAR report: required for parts where final appearance is to be certified by customer (ie. Color, texture)
[FONT=&quot]14. SAMPLE PRODUCT[/FONT]
- Sample product: from significant sample run as specified by the customer
[FONT=&quot]15. MASTER SAMPLE[/FONT]
Master sample: a sample retained on site for reference purposes from the significant sample product run; in addition to the Sample Product quantity, preferably the samples used for “dimensional layouts”
[FONT=&quot]16. CHECKING AIDS[/FONT]
- Checking aids: submit calibration/verification records for any device used specifically to check the part in question Note: the requirement is to submit the device as well as the documentation, if requested by the customer.
[FONT=&quot]17. RECORDS OF COMPLIANCE WITH CUSTOMER SPECIFIC REQUIREMENTS[/FONT]
- Records of compliance with the customer's specific requirements: usually a copy of your ISO 9001 or TS 16949 registration certificate, unless the customer has additional requirements
[FONT=&quot]18. PART SUBMISSION WARRANT (PSW)[/FONT]
- PSW: the completed PSW form; there is a copy on the PPAP manual if needed
O
Oskar_S
2.ENGINEERING CHANGE DOCUMENTS
I have some questions about the text above.
I thought ECN meant that if you make a change in the design and don´t have the time or effort to change the drawings immediately, you write and use ECN until the changes have been recorded in the drawings. On the other hand your way seems also logical if the customers see different drawings each day, you just make a document explaining the difference between the drawings.
In my case we are designing the product yourself and there are no specific customer, can you then skip Customer engineering approval for a new product?
There is no "ECN" category. On the PSW it's referred to as "Additional Engineering Changes," and in the 4th Edition PPAP manual it's (2.2.2) "Authorized Engineering Change Documents." It applies to "...documents for those changes not yet recorded in the design record but incorporated in the product, part or tooling." In other words, it applies to official documentation of changes incorporated in the product but not in the current drawing.
2.2.3 of the manual says, "Where specified by the customer the organization shall have evidence of customer engineering approval." The element applies only if your customer requires their own engineering approval of something prior to PPAP submission.
E Newbie - 14 Jan 2020 Coffee Break and Water Cooler Discussions 2
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
S Informational Please help this newbie understand ISO 9001 Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
B Newbie Capability question Capability, Accuracy and Stability - Processes, Machines, etc. 7
S Thanks from a newbie Coffee Break and Water Cooler Discussions 4
Q ISO 9001 - 3 BIG questions to help a Newbie's Sanity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Food Warehouse ISO 9001 Audit and Newbie Introduction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M A newbie to RM struggling with the policy ISO 14971 - Medical Device Risk Management 1
C A total newbie to AS 9101 needs general help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
K Daily activities of a Newbie ISO Management Rep/Lead Auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
F SPC Newbie looking for Excel Spreadsheet formula for a sample size of 40 components Capability, Accuracy and Stability - Processes, Machines, etc. 8
B Gage R&R Newbie - Everything is Failing! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
N I have 2 groups to compare - Minitab and stats newbie - Please help Using Minitab Software 18
J Certification Audit - Confused Newbie Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
M Newbie in Gage R&R - Gloss Meter and Thickness Measurement Reliability Analysis - Predictions, Testing and Standards 7
G Newbie in IMDS - Please help me understand what I have to do RoHS, REACH, ELV, IMDS and Restricted Substances 4
P Gage R&R with ATE (Automatic Test Equipment) - Newbie here... Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R Newbie, SME, non existent QMS going for ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
O Newbie at PPAP - Need basic PPAP Information APQP and PPAP 2
N Help a newbie to develop a QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
N SPC charts, simple xls sheets and free software - Need newbie information Statistical Analysis Tools, Techniques and SPC 5
L VDA Product Submission Form - Please help a Cove newbie answer a VDA question VDA Standards - Germany's Automotive Standards 12
D Major Advice Needed for Newbie Taking over a System in Shambles ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
L Minitab Newbie Using Minitab Software 1
A APQP Newbie requires guidance APQP and PPAP 5
R QMS Implementation "Newest Newbie"... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J FMEA - What is the relationship between Detection and Prevention? QP Newbie question. FMEA and Control Plans 12
A Seeking: ISO 9001:2000 Internal Audit Checklist for Newbie Internal Auditing 20
R Pre-assessment Audit Worries for a Newbie General Auditing Discussions 11
B Looking for PPAP help for newbie QS-9000 - American Automotive Manufacturers Standard 6
J Statistics and Six Sigma - Newbie Seeking Information and Resources Six Sigma 1
Proud Liberal COMMENT - Newbie Coffee Break and Water Cooler Discussions 1
B Complaint Records - Accessing records on Easy Track Software Records and Data - Quality, Legal and Other Evidence 3
W Does anyone have any experience with the Easy Metric System? General Measurement Device and Calibration Topics 2
B Easy Software Needed for Recording Mainly Attribute Data Quality Assurance and Compliance Software Tools and Solutions 2
Q How to provide evidence of Strategic Direction (Easy) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A EASA Easy Access Rules for Continuing Airworthiness - June 2017 EASA and JAA Aviation Standards and Requirements 0
Q Easy Way of "Implementing" Risk in ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Metrics and Statistics for Improvement - Easy to implement Statistical Analysis Tools, Techniques and SPC 4
Marc How to Live Easy in China on $475 a Month and still be able to Save Money Immigration and Expatriate Topics 2
N Moisture Analyzer Out of Calibration - Easy Way to Confirm Everything Ok? General Measurement Device and Calibration Topics 3
N Tracking Shelf-Life of Materials - Is there an easy way? ISO 13485:2016 - Medical Device Quality Management Systems 2
K An easy way to distinguish Tooling vs. Equipment Design and Development of Products and Processes 7
L Easy Access of Obsolete Documents - Corrective Action help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
G All FDA Regulations in a New Easy Download Format US Food and Drug Administration (FDA) 1
G VERY easy savory baked Thanks Giving party treat Coffee Break and Water Cooler Discussions 0
M How to Implement the QHSE Integrated Management System Easy Steps? Occupational Health & Safety Management Standards 1
smryan EASY Chicken Enchilada dish Imported Legacy Blogs 4
U Easy-Difficult Coffee Break and Water Cooler Discussions 0
