No Calibration Due Date on a Calibration Certificate unless requested by a customer?
ScottBP
An auditor wrote up a finding during a recent audit, because we put a due date on a certificate for an item that we calibrated for an external customer, but couldn't provide evidence that the customer requested that due date.
Now we have another customer that didn't say anything about a due date on their service request, so we asked them and they didn't know (actually it sparked a bit of a controversy).
What's the best way to advise our customers that if they don't specify a due date, they won't get one on their certificate? Would we be covered if we suggested a due date and they agreed to it in writing?
Mikishots
Re: No due date unless requested by the customer?
I'd be curious as to the exact wording of that finding, and which standard clause was said to be violated. Are you able to share?
BradM
Scott, are you doing work against 17025? I believe there is a clause in there. I'll look.
Michael_M
When I send thread gauges out for calibration, the company had a checklist (Company general, not for each specific gauge). One of the options was calibration cycle, if none were checked, it states that calibration will default to 12 months.
Could you use something like this. Have a single form for each customer with the option for calibration interval or if none are chosen, it automatically defaults to #####
BradM
IS0 17025 5.10.4.4. covers the due date.
However... not sure if this helps:
http://www.a2la.org/faq/printable17025explain.cfm
Our calibration laboratory is ?captive? and part of a larger original equipment manufacturer (OEM). The items manufactured by our company are accompanied by a calibration certificate generated from our laboratory, however the recipient of this equipment is not known at the time of calibration. Our company would like for us to include a recalibration interval on the calibration certificates, but since the ultimate recipient of the equipment is not known, we cannot obtain their prior approval to include this interval. Is it still alright for us to include it on the calibration certificate? 12/06/2007
5.10.4.4
2005
In the case of captive or internal laboratories, the ?customer? is most often considered to be another department within the larger, overall organization. As long as there is a documented understanding and approval from that other department within the organization, then the laboratory may include a recalibration interval on the calibration certificates that they issue to that department. If the cal certs are ultimately intended to meet the A2LA Policy on Measurement Traceability (P102), then they must be appropriately endorsed and must meet all ISO/IEC 17025 requirements. If the OEM intends for their equipment to meet P102 when it is ultimately sold to their customers, then they must include the original, unaltered and endorsed calibration certificates with the equipment.
Hershal
Metrologist-Auditor
Re: No Calibration Due Date on a Calibration Certificate unless requested by a custom
Scott, simply put, you can SUGGEST any cal cycle - BUT - if issued as an accredited certificate, then the cal lab should not put a recall date unless agreed by the customer.
Hope this helps.
dv8shane
If you do written quotes as part of contract review, you could state" that unless requested otherwise by the customer the standard manufacturers recommended interval will be used". Once they sign off on the quote your covered.
H
Hanr3
Does the customer know what the calibration interval should be for thier application?
Do they understand calibration interval? Some customers don't understand and expect you to know the answer, your the expert they hired.
Do they verify that the current calibration interval is acceptable?
How do you put a cal due date without knowing thier process/application? You can recommend one, but what are you using for the basis of your recommendation? Industry standard? History? The best basis is statistical data. Do you have that data for their application?
Yes, you need to have a conversation with your customers and you need to document the customers requirements. There are numerous ways to document this information, and several have been posted. Realize, there are customers out there who know they need 17025 Certified equipment, however they have no clue what that means. The person cutting the po, may not be the one who has the need.
John Broomfield
ScottBP,
As a cal lab, specifying the "due date" or reporting the "as-received condition" are both additional services for which you can charge your customers.
Even if the customer does not realize this, the customer relies on their cal lab (as the expert in the relationship) to determine if these additional services are required.
The due date may be determined arbitrarily or as a result of a study (based on a history of as-found condition reports). Again these are opportunities for the cal lab to sell further services according to the needs of their customer.
Best wishes,
John
O
oldcodger
Do you have gauges like the ones that were lent to you by your customers? If your customer wiil not specify the number of days between calibration, document their refusal and calibrate their gauges on a similar schedule as your own gauges--and of course document the calibration.
S Calibration Due date-Critical Connie General Measurement Device and Calibration Topics 16
W Next Calibration Due Date Calibration Frequency (Interval) 5
G Is the calibration due date of equipment used to be on calibration certificate ISO 17025 related Discussions 38
X When a Gage is past the Calibration Due Date General Measurement Device and Calibration Topics 6
A Calibration Requirements after Exceeding the Calibration Due Date General Measurement Device and Calibration Topics 8
M Done date & due date on calibration stickers General Measurement Device and Calibration Topics 12
G Calibration grace period after due date Calibration Frequency (Interval) 14
H How to get the Calibration Due Date? Calibration Certificates Calibration Frequency (Interval) 11
D Extension of Measurement Device Calibration Due Date. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
Wayne Never put an Expiration (Due) Date on a Calibration Certificate Calibration Frequency (Interval) 41
D Late calibration (Calibration Past Due Date) - What do I do now? General Measurement Device and Calibration Topics 32
M Can Calibration Due Date start upon issuance of the device to production General Measurement Device and Calibration Topics 11
R Calibration Cycle: Calibrate When Issued OR Calibrate by Due Date? General Measurement Device and Calibration Topics 7
S Calibration Due Date - How can I word my procedure? General Measurement Device and Calibration Topics 38
G Informational Is Past due calibration a non-conformance if tagged "Do Not Use"? General Measurement Device and Calibration Topics 9
J AS9100D Clause Brain Fade - Tool was past due for Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Example of Calibration Due Reminders to Leads, Managers & Directors General Measurement Device and Calibration Topics 3
W Calibration Recall or Due Dates - Latitude Calibration Frequency (Interval) 14
T Calibration Laboratory Temperature/Humidity goes out of tolerance due to Power Loss General Measurement Device and Calibration Topics 9
N Auto email reminder sent to customer - Calibration Due Notices Calibration and Metrology Software and Hardware 5
E Possible escapes due to caliper out of calibration Calibration Frequency (Interval) 4
K Attaching calibration due dates to gages - Sloppy technicians IATF 16949 - Automotive Quality Systems Standard 17
M Calibration is due, but the tool has not been used. Calibration Frequency (Interval) 11
D Validity of ISO 17025 calibration waivers due to proprietary procedures ISO 17025 related Discussions 4
P Calibration Stickers or Other Methods of Identifying when Gages are Due? General Measurement Device and Calibration Topics 32
Mikey324 External calibration - Finding in our 3rd party audit General Measurement Device and Calibration Topics 54
L A certificate of conformance used to support a calibration General Measurement Device and Calibration Topics 6
A AS9100 - 7.1.5.2 In-House Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
B UV-A and Illuminance meter Calibration Setup General Measurement Device and Calibration Topics 0
S Calibration Related Posters General Measurement Device and Calibration Topics 2
F Quality Control in Electrical Calibration ISO 17025 related Discussions 0
C Narrow definition of IMTE or calibration possible? ISO 13485:2016 - Medical Device Quality Management Systems 8
dhuot1990 In-House Calibration Program - Biotech Industry General Measurement Device and Calibration Topics 3
M Reference part calibration or verification General Measurement Device and Calibration Topics 12
M Calibration of equipment IATF 16949 - Automotive Quality Systems Standard 4
Q Gage calibration / tracking software General Measurement Device and Calibration Topics 5
C Should resolution be included in uncertainty budget for digital caliper or micrometer calibration? Measurement Uncertainty (MU) 5
Q Request Calibration Info Calibration and Metrology Software and Hardware 16
R Calibration Log - Archive Manufacturing and Related Processes 2
U Calculate acceptance of equipment reading after calibration General Measurement Device and Calibration Topics 2
D Question on Documented Calibration versus ISO 17025 Accredited Calibration ISO 13485:2016 - Medical Device Quality Management Systems 2
U Calculate acceptance of calibration reading Measurement Uncertainty (MU) 1
D Air hood calibration ISO 13485:2016 - Medical Device Quality Management Systems 1
K Ground Bond Test for Class I Medical Electrical Equipment - calibration problems IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Calibration/Verification Report Durometer ISO 17025 related Discussions 2
S Medical device equipment calibration Qualification and Validation (including 21 CFR Part 11) 1
J Scrap Material Scale Calibration Required? IATF 16949 - Automotive Quality Systems Standard 21
S 7.1.5.2.1 Calibration/Verification Records IATF 16949 - Automotive Quality Systems Standard 6
K Is Calibration Required for Non-Adjustable Commercial Inspection Devices? General Measurement Device and Calibration Topics 11
F Calibration in GPC/SEC General Measurement Device and Calibration Topics 1
