No Formal Design Process - Audit Finding - Help with Section 7.3 of ISO 9001:2008
JaneB
#11
Depends upon the tribe and quality of the knowledge..........The Inuit have designed and built a pretty successful boat (qajaq or kayak) for a long, long time without a documented process
But y'all surely aren't claiming the Inuit are certified to ISO 9001, are you? Which I just somehow think Sidney was referring to. ;)
What is needed here I think is better info from the OP as to what the specific finding of the auditor was and what it actually said. Otherwise there is some risk of fiercely arguing over theoretical points (I do concede yours, Randy), based on inadequate info, which while interesting and entertaining may not be particularly enlightening to the OP..
smryan
Perspective.
#12
I concur with Randy here. My company was sucessfully designing and making product long before the ISO cert. When they went for the ISO cert the choice was made to document everything - mostly to have easy evidence to point to for the auditor. Not a "have to", but as headache avoidance. Certain documentation, like the design process, have been rather vague out of necessity.
As the company grows, new engineers are added, and a new product line has developed, the need for detailed documented procedure has been a necessity to make sure that all the appropriate documentation gets done... makes it easier for someone who wasn't born in the tribe to have some written directions. Now that we are considering the TS16949 cert the existing process needs to become much more structured than it is. The documentation is in place, but the detail needs to be amped up considerably.
K
KENWALTON123
#13
All, thanks for your feedback.
To clarify, we have controls in place for design and meet all requirements of NBIC and ASME, but I assume the auditor was looking for "The Book" of how we get from point A to point C. Maybe I'm mistaken, but from my conservation with the auditor this is what I believe he was looking for. I was hoping to determine how others prove they comply with section 7.3, how do you document this?
#14
As Randy and others have pointed out, there is no explicit "shall" with regard to having a documented system. In terms of practicality, however, I don't know how you would fully control a design process without documentation. You may have discovered why documentation makes sense. If you couldn't demonstrate control to the auditor--show him that your system has requirements that control the effectiveness of the process--you're left with saying, "Trust me, it works," which an auditor is unlikely to accept as evidence.
On the other hand, if you can demonstrate that the designers understand the requirements and follow a standard process, the auditor would be wrong if he insisted on documentation.
Sidney Vianna
Post Responsibly
#15
So did the vikings. But I don't see any business consultant guru promoting the tribal knowledge approach to running an organization.
JaneB
#16
Jim has captured the key points here. And reading that along with the excellent example smryan gives, should get you thinking.
If your process isn't clearly defined at the moment (and it sounds like it might not have been if you couldn't convince the auditor), it won't be robust enough to cope with stresses, including growth - eg, in size, products etc.
But if it is clearly defined, and your auditor is saying no, I want to see a written procedure, he's wrong. There is no requirement for a documented procedure in 9001.
That said - one way of approaching it, if you decide some documentation is necessary, is via a flow diagram, just setting out the main steps, decision points, and capturing what records are generated at which points (a good way to make sure you meet the requirements for records). A one-pager for example.
Finally - remember the purpose of having requirements in the first place! Because it's good practice, fosters a consistent approach, and enables both identification of problem points and improvement.
A Formal Way for Documenting Design Input Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Formal Q Self Assessment - Problem with assigning Product and Process Customer and Company Specific Requirements 1
M MDR - Is a formal GSPR Procedure required? EU Medical Device Regulations 20
V Manufacturing without a Formal Drawing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R MDR Software Rule 11 Formal Interpretation EU Medical Device Regulations 7
I Bench Testing & Pre-verification vs. Formal verification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Formal written response to a corrective action? Nonconformance and Corrective Action 9
J When to Take Formal Action on a Supplier Supplier Quality Assurance and other Supplier Issues 7
S Forecasting and Material Planning - Are formal procedures required? Document Control Systems, Procedures, Forms and Templates 3
Q Is there a formal process for disputing a 483 for a medical device company? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Is a formal review after OQ (in Process Validation) required? Qualification and Validation (including 21 CFR Part 11) 2
A Auditor threatening Formal NC and CA for not enough PA Preventive Action and Continuous Improvement 23
M Continuous Improvement Log vs. Formal CAPA System Preventive Action and Continuous Improvement 3
N The formal definition of Domestic Environments in in CISPR 11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
W Is formal training required for Internal Auditors? Internal Auditing 7
R Auditing a process outside the realm of the formal Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A 483 Response Letter - Are there any Special Formal or Content related Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 16
P Acquire formal USFDA Inspector for USFDA Inspection Preparation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M ISO TS 24971 Updates and formal objection of the European Commission to ISO 14971 ISO 14971 - Medical Device Risk Management 24
L Formal Resource Request Form example wanted Document Control Systems, Procedures, Forms and Templates 3
J Supplier Quality Management System (QMS) Audit - Formal Documented QMS does not exist ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
T TS16949 Certification withdrawn - What should be included in a formal appeal request? IATF 16949 - Automotive Quality Systems Standard 3
H Formal Quality Qualification - What qualification(s) would be the best? Professional Certifications and Degrees 10
A Difference between formal and informal Kaizen Lean in Manufacturing and Service Industries 6
L Is it required to write a formal corrective action on any nonconformance? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 29
A No Formal Documented Performance Evaluation for Contractual Personnel ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
J Does Management Review need to be a Formal Meeting? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
C ISO 9001:2008 Contract Review for a business that doesn't have formal contract review Contract Review Process 11
M Formal SQAM requirements interpretation training Customer and Company Specific Requirements 5
Hershal Formal complaint to Europe regarding beer..... Coffee Break and Water Cooler Discussions 43
P Formal Quality Control Agreement with specific suppliers - Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Sterile Field - Legal/formal definition US Food and Drug Administration (FDA) 4
J Formal CS1 Notification Letter Ideas and/or Template needed IATF 16949 - Automotive Quality Systems Standard 14
K Is formal Internal Auditor training required for ISO 17025:2004 - Clause 4.14.1 ISO 17025 related Discussions 5
V GAGE R&R Formal definition/ formulas for master's thesis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Training Needed for Registration - Is Formal ISO Training Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
C Does a small typo in a procedure require a formal change notice? Document Control Systems, Procedures, Forms and Templates 22
E FDA - Audit - Response - Observation form 483. Do we now receive a formal letter? US Food and Drug Administration (FDA) 5
I Internal Auditor Training - Does TS 16949 Require Formal Training or Certification? Internal Auditing 19
H Placed in the position of implementing ISO 9001:2000 but have no formal training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Sidney Vianna Official ISO Interpretations - A Formal Process for ISO9001 Interpretation Requests ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
B Can formal document control requiring QM signoff live with continuous improvement? Document Control Systems, Procedures, Forms and Templates 21
A Quality Audit Report - Report Format and some Formal Sentences General Auditing Discussions 22
CarolX Request for Formal CA - To Issue or Not to Issue Nonconformance and Corrective Action 15
Z The requirement of 'a formal training program for R&M' - 4.18 Training QS-9000 - American Automotive Manufacturers Standard 3
I When to start a formal corrective action as a follow-up action after audits General Auditing Discussions 11
U QS 9000 Audit - Trainer of internal auditors not having formal training QS-9000 - American Automotive Manufacturers Standard 6
Marc Quality Records and Forms - No formal forms Records and Data - Quality, Legal and Other Evidence 0
B When is a Formal Corrective Action Necessary? Nonconformance and Corrective Action 11
