No Nonconformances issued from audit activity
selena15
Hi Cove
i have a confusion
" i found out an audit report without any Non conformance. Just some observations which is included, indeed, some NCs. when i asked about the NC and why i wasn't highlighted to the auditees. I receive the answer that as well as this is the first time this area was audited and there is no procedure written, the Auditor prefered to not give them a Non conformance and told me that in the next audit, he will verify the observation and in case of it wasn't fixed; he will issue a Non confomance.
Is it allowed to proceed like this. i know that when you don't have a procedure or any evidence to audit against it; we should audit the process.
if this is the first audit in one area; is it okay to take it like this :confused:
thank you in advance
:thanx:
Sidney Vianna
Post Responsibly
Re: no NCs issued from audit activity
Just another example of ineffective internal audits. Likely, due to people being thrown in the internal audit process without being competent for performing the tasks at hand.
Jen Kirley
Quality and Auditing Expert
Hello Selena, I have some questions.
Was this an internal audit?
If there is no procedure for the process, is a procedure required by the standard?
Which standard are you auditing against?
Were the observations written against element(s) of the standard? If so, which ones(s)?
What were the write-ups for?
selena15
Hi ladies and gentlemen
sorry for the late
Jennifer; it was an internal audit. these area was audited against the standard ISO 9001, good practice of the organization and the procedures relating to this process. The procedures required by this standard is documented but our issue remain the huge resistance when we deployed the procedure.
This is the reason that some people present when they get this kind of behave as described in this thread. When i asked the auditor why there is no NC presented as this to the auditees; he explained to me that they prefer sometimes to take it easy and prefer to let something in order to win the important thing, mean the deployment of procedure first and they think that they won't get nothing if they make it tough since the first step. The method worth what it's worth :frust:
The elements of the standard concerned is in the chapter 7.2, mainly the 7.2.1 & 7.2.3 and many points relating to how the presentation of the goods to the customer and marketing.
I hope that it is more clear
I want to highlight one point, i wanted to know if there is any reason which can justify to not show the NCs to the auditee ? :confused:
Al Hector
Hi Selena,
For me is not logical. Why do they do internal audit?
If they find nonconformities or observations (opportunities for improvement- or whatever you call them in your internal audit procedure) the auditee is the first to be informed because “The management responsible for the area being audited shall ensure that any necessary corrections and corrective actions are taken without undue delay to eliminate detected nonconformities and their causes.”
I think that your auditors must be retrained.
Off Topic I also have XY chromosomes inside:)
Alin
selena15
Hi Al
The procedure of audit is correct; and they informed the auditee durant the closing meeting about the NC detected, not as NC; but as observation which should be improved :notme:
I'm Agree that some retrainning is requested
Sandra Gauvin
I would agree with Alin....a nonconformance or observation should be viewed as an opportunity to improve and not as being too tough. By taking the 'easy' approach, the importance of the audit findings may appear diluted....it's always better to find a nonconformance internally than have an external auditor find it.
Sandra
BradM
I hope I have understood everything correctly.:)
You have procedures in place that upper management has approved. An internal auditor found objective evidence that the procedures are not being followed. Instead of documenting and issuing the non-conformance, they... simply don't. The reason is due to "pressure" and such.
1. The internal auditor should always call it like they see it. If there is an NC, it should be issued and acted upon. There will always be interpretations and such in auditing, but if the evidence is there, it should be responded to.
2. If the procedure is bad, rewrite it. If it is not necessary, remove it. But if management agrees it needs to be in place, then they should be notified when the organization is not following it.
If this NC is soft-peddled, so will the next one, and so on. I believe Internal Auditing can be one of the strongest components of any quality management system, if it is correctly embraced and utilized by management.:)
Antonio Vieira
Involved - Posts
Now in fact we have some new procedures in registration audits.
In the first audit (1st visit), which mainly documental auditing, the auditor will not write any nonconformance. He will only write the situation founded without the word nonconformance.
In the 2nd visit (normally 2 weeks after the first visit), it’s a normal audit.
Jen Kirley
I agree with Brad. :agree1:
Here was a very telling point:
You later suggested the auditors need to be retrained. I would like to caution you against a hasty move toward correcting auditors' behavior. Instead, it seems there is a cultural force that they hesitate to press against. A retraining could do more damage than good, if they feel they are being somehow punished for something not in their control. :whip:
It's time to back up and revisit the procedure. If it is not correct for the overall needs, change it. If it is correct but receives no departmental support, I suggest the auditors may not be the people who need "retraining."
:2cents:
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 24
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
G Differences - Nonconformances vs CAPA, Corrections vs Corrective Actions ISO 13485:2016 - Medical Device Quality Management Systems 16
R Extension of product nonconformances - Construction project Nonconformance and Corrective Action 7
I Audit Nonconformances - Can reported corrective actions be incomplete? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J EU ISO 13485:2016 Recertification Audit - Effect of 10 Minor Nonconformances EU Medical Device Regulations 2
W Closing of Stage 2 Audit Nonconformances AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M User Errors and Product Nonconformances Nonconformance and Corrective Action 22
K Notified Body - Minor Nonconformances - They have withheld all certificates General Auditing Discussions 3
Q Several Nonconformances with same Root Cause with just one CA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V 21 CFR 820 Compliant way to use Kaizen to address Nonconformances Nonconformance and Corrective Action 9
N Nonconformances in the Construction Industry Nonconformance and Corrective Action 6
T Perishable Tooling Supplier - Nonconformances and Metrics AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
H NADCAP Audit Nonconformances - Vacuum Furnace Load Sensors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L Internal Audit Nonconformances - Your opinion? Internal Auditing 8
M Supplier Nonconformances - Key Points to ask a Metal Stamping Supplier Supplier Quality Assurance and other Supplier Issues 7
L Insurance to cover for nonconformances ? Misc. Quality Assurance and Business Systems Related Topics 2
T Defining Nonconformances in a Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C ISO 9001 Nonconformances an how to handle them ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Second Registrar Visit to Confirm Major Nonconformances Fixed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L Definitions for Minor & Major Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
F Response to ISO 13485 Audit Minor Nonconformances ISO 13485:2016 - Medical Device Quality Management Systems 6
M Seven Document Review Nonconformances Document Control Systems, Procedures, Forms and Templates 9
J KPI for time to close NCs (Nonconformances) Quality Manager and Management Related Issues 17
R Internal Audit Cancellation when Nonconformances are Found Quality Manager and Management Related Issues 13
J Question about GM special requirement - Open Major Nonconformances IATF 16949 - Automotive Quality Systems Standard 2
K CAPA Training for Process Nonconformances Nonconformance and Corrective Action 2
A Nonconformances and Rework in a Machine Shop Nonconformance and Corrective Action 6
Fender1 Nonconformances that do not require Corrective Action Nonconformance and Corrective Action 21
C Who does the Analysis of Nonconformances and other Data Analysis? Nonconformance and Corrective Action 23
T NonConformances as a Tool to Measure Employee Performance Nonconformance and Corrective Action 21
A Surveillance Audit Result - Multiple Audit Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Suspension of ISO 9001 Certificate - Major Nonconformances Identified ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
B The Distribution that represents the Severity of Nonconformances Nonconformance and Corrective Action 2
L Non Conformance Register (aka Tracking Nonconformances and Corrective Actions) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J How many Major Nonconformances could let the Audit be Terminated? General Auditing Discussions 9
R ISO 13485 Surveillance Audit Nonconformances and Report Help Needed ISO 13485:2016 - Medical Device Quality Management Systems 9
A ISO 14001 Surveillance Audit Nonconformances ISO 14001:2015 Specific Discussions 6
J Corrective Action Timeframe for Internal Nonconformances Nonconformance and Corrective Action 14
R Is it useful to adapt PFMEA's with nonconformances? FMEA and Control Plans 4
P Boss doesn't want Nonconformances called Nonconformances in Internal Audit Reports ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
C System Root Cause and CA (Corrective Action) for ISO 13485 Audit Nonconformances ISO 13485:2016 - Medical Device Quality Management Systems 3
M Can a KPI (Key Process Indicator) be created against Nonconformances? Nonconformance and Corrective Action 8
J Certification Body follow up on clearing Audit Nonconformances Registrars and Notified Bodies 4
M NCR and Cost Collection - Capturing nonconformances in the field Nonconformance and Corrective Action 1
Q CTC (Critical to Customer) vs. CTQs (Critical to Quality) Nonconformances Nonconformance and Corrective Action 6
A Escalating Minor Nonconformances into Major Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D NCRs (Nonconformances) allowed during ISO 9001 Recertification Audit General Auditing Discussions 21
P Is Blaming Operators for Nonconformances correct? Quality Manager and Management Related Issues 62
C CB Client Contract Agreement - Identifying nonconformances - AS9100 Registrars and Notified Bodies 7
